Question about Canon MVX10I Mini DV Digital Camcorder
Canon MVX10i - no picture on playback
Hi, I have a Canon MVX10i. It?s circa 18 months old and used only on 6 holidays. When I insert a tape and press play, I can see the tape symbol showing that the tape is in motion. However there is no picture on the lcd. I tried 11 tapes on which I have recordings and find the same issue. I have tried connecting the camcorder to a tv, but the same issue is apparent - no picture on playback. I found this link (which is the exact issue I am having) but Canon say my model is not listed and I will have to pay to ship the unit back to them and £140 to fix the problem!! This is the last EVER Canon product I will buy. I now live in Spain and it's a real pain trying to speak to the service centres here (lacking as they are in English). Can someone please tell me if I can resolve the problem myself? I am a network and server engineer so amd pretty good at fixing things when I know what to look for. Thanks for your help! Jay
  • jay patel Jun 03, 2007
    Folks,
    Anyone got any ideas for this issue?
SOURCE: No Picture, sound or anything during playback...
cleaning cassette may help - if the picture comes back but soon goes blue screen ? your heads need thorough cleaning or replacement ;
Posted on Jul 31, 2007
SOURCE: Canon ZR100 camcorder blue screen playback, tape eject beeping
no video record and blue screen
Posted on Nov 30, 2008
cpt100
  • 154 Answers
SOURCE: Canon XL2 wont record or playback tapes - grey lines.
The video heads may be clogged. Depending on the severity of clogging, if minor, you can clean the heads with the head cleaning tape other option would be manual and direct cleaning by technician. First, open the tape loading area for dust removal by canned air, clean pinch roller with Q-Tip using denatured alchohol and try it. If it did not do the job. Assigne it to a technician for about $99 for a professional cleaning. Good luck -James. For further assistance by email, go to www.camerarepairjapan.com
Posted on Mar 27, 2009
SOURCE: Grey horizontal lines during playback on camcorder
yes change the tape and also use a head cleaning cassette to clean the cam. chaminda from Sri Lanka
Posted on Jun 25, 2009
Richie_asg1
  • 1036 Answers
SOURCE: Horizontal grey bars across screen.
This sounds like it is the Tape recording function that is at fault. Unfortunately, it's also one of the most difficult to correct without a scope and test jig.
However,
If it is more than 5 years old, it may be suffering from component failure.
In particular the Electrolytic capacitors in these small cams seem to fail first due to temperature and humidity changes. They can leak, dry up or corrode, so it may be worth looking inside at the control boards to spot any physical signs of deterioration.
This shows typical surface mount capacitors - silver cylinders with black segment denoting negative -
Posted on Sep 08, 2009
After recording and replaying, the picture is "sliced up". I've tried cleaning head with dry tape, seemed to help but still there. Trouble is it seems to vary each time I play the same tape.
Do not use a head cleaner - they can damage the heads. Insert a brand new high quality tape and perform a record. Let it record through the entire tape. Then, play back an original prerecorded tape and check playback.
Nov 15, 2010 | Canon GL1 Mini DV Digital Camcorder
My canon camera seems to work fine in record mode. The LCD shows the video and the timestamp, and tape is moving. Yet in playback mode no matter what Tape I use (even if I know the tape has video on it)...
The playback head is dirty. Insert a brand new tape into the drive and perform a record, through the entire tape until it reaches the end. Then play a pre-recorded tape.
Nov 13, 2010 | Canon VIXIA HV30 DV Camcorder
I have a really old Canovision8, E40, 8mm camcorder that doesn't work anymore. What's the best solution to convert the tapes to DVD or to the computer?
You need Hi-8 camcorder/ Hi-8 player to playback your old Video-8 tapes, hook that camcorder/ player with DVD Recorder, play video-8 tapes and burn DVDs directly.
Dec 27, 2009 | Canon ES400V Camcorder
Tape Playback
Try cleaning the tape heads with a DV tape cleaner and see if that works.
Jul 07, 2008 | Canon ZR800 Mini DV Digital Camcorder
Playback Problems
THE FOLLOWING SOLUTION FROM LABBER (CREDIT TO HIM)
I did have a similar problem as above, and has not been able to use the camera for a long time as power turns itself off in less than 2 mins. I tried the solution #3 (by labber) above. which i have copied and pasted below .
1. Take out the tape - mine stayed on longer (without blinking) when the tape was not in.
2. press the menu button (near the viewfinder)
3. Use he wheel on top next to the viewfinderto scroll through the choices
4. Choose "display setup" by pushing the wheel in
5. Choose "C. Rest" by pushing the wheel in
6. Turn camera off
7. Next time you turn camera on you should be able to view tapes and record.
IT DID NOT WORK THE FISRT TIME SO I PUT MY FINGER IN TO TRY TO GENTLY PUSH BUTTON WHEN I TOOK THE TAPE OFF AND THEN TRIED SOLUTION ABOVE AGAIN, AND THIS TIME, IT WORKED. BUT PLEASE DONT INSERT YOUR FINGERS IN AS I DID TRY THE SOLUTION 2 OR THREE TIME IT SHOULD BE OK, HOPE THIS WORKS FOR YOU,
THANKS LABBER
Nov 13, 2007 | Panasonic NV-DS29B Mini DV Digital...
Canon Gl2
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Sep 18, 2007 | Canon GL2 Mini DV Digital Camcorder
Jumpy Playback Through TV
First you should try a couple other tapes to make sure they all do it. It could be tape damage on the tape you are using. If you remove the tape from the unit and look at the part which gets inserted first you will see a small latch on the front side of the door. If you depress the latch you can open the cover over the tape. Be very careful and don't touch the tape! Look at the tape for damage. If it is perfectly smooth, like a mirror, it is OK and the camcorder has a problem. If the tape is OK you probably have a tape path problem or the unit could be dirty. Cleaning the heads would be the easiest solution to try but if you are not familiar with the process you could do more damage than good. If you know how to properly clean the heads, certainly do that first. If that does not solve your problem either a tape guide is not adjusted properly or the tape is not loading fully or properly in the tape path. Either way it isn't going to work until it is repaired. I'm guessing that repair would be beyond your skills. You stated that you bought it off Ebay. You should contact the person you purchased it from no matter what is wrong with it because if they presented it as a working unit they were less than truthful. Good luck.
Jun 24, 2006 | Canon ES550 8mm Analog Camcorder
Canon MVX10I Mini DV Digital Camcorder Logo
67 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
