Question about HP Compaq Presario V2000 Notebook
8 GB SD card
My Compag will not read an 8 GB SD card at all but it reads 1 and 2 GB just fine. Is anyone else having this porblem? Is it just not compatible? Is there any way I can fix it?
  • 404 Answers
Hello, unfortunately SD cards are getting larger and larger capacities and your Compaq is only able to read Max 2Gb.
However there are external card readers that will read your 8Gb.
Hope this FixYa's problem?
Paul 'W'
Onyer~EDson(:0)~[>< U.K.
Posted on Jan 09, 2009
Camera saying memory full but card brand new
Not only the size is important, the manual says SD max 2 GB.
But even a 1GB SDHC card won't work, because the camera is not compatible with SDHC and SDXC.
They used to make SD cards up to 4 GB, but most new cards from 1 GB and up are SDHC and above 32 GB the cards are SDXC. Older camera's can't handle these cards, although they look the same.
To read more and to understand compatibility from device versus Memory card, read this:
Secure Digital Wikipedia the free encyclopedia
Apr 10, 2015 | Samsung Digimax D73 Digital Camera
My lg does not read 2gb sd tell me to insert a new one.Bt it can read 128 mb sd card
Your 2 Gb is not just an SD card, it is a SDHC card. The first 2Gb SD cards, still were SD, but 2Gb was the limit for the FAT 16 and 32 format and for the normal SD cards. The same happened with the hard disks. They developed the SDHC card, and made the new hardware downward compatible with the old SD cards. So in a new camera, you can insert SDXC, SDHC, SD and even MMC cards. But the cameras, card readers and phones, who were made for SD, can't use the SDHC or SDXC cards.
SDHC can work with memories up to 32 Gb and from that on, it is SDXC.
There still should be some 2Gb SD cards around, but not sure you still can fine one. The producers of memory cards now only make SDHC cards and up. Perhaps you only can get some 1Gb cards as SD card, but perhaps nobody will ever make these cards anymore.
I mannaged to buy a 4 GB SD card a few years ago, but that was the last I ever saw in the capacity. 25264488-uil2tdgcy05knvgzh4oup5lj-2-0.png
Nov 01, 2014 | Cameras
What is the maximum SD size that will work with the DSC-4500Z camera?
The manufacturer of your camera specifies SD card compatibility without providing a specific number. This is not uncommon however, as the maximum size for SD cards is 2 GB. Cards that have a larger capacity than 2 GB in the "SD" format are "SDHC". Read the label of these cards (that have a larger capacity than 2 GB) that *look* identical to SD cards, and you'll see that they are in fact SDHC types. The SDHC card can have a capacity of up to 32 GB. A device that is compatible with the SDHC specification should be able to read any SDHC card *and* any SD card as well; because the standard requires "backward compatibility" to the older SD standard. A device that accepts SD cards should be able to read any SD card, *but* if an SDHC card be introduced to it, it may provide unreliable results (from being able to access only 2 GB of the capacity or not recognizing the card at all). Make sure your pictures are safe and don't get lost; use only SD cards in this camera.
I hope this helps!
Jun 08, 2010 | Apex Digital Digitrex DSC-4500Z Digital...
4 GB doesnt work
I believe this camera only supports SD/MMC cards, not SDHC cards. Go to the kodak site to see the detailed specs. Not all devices support SDHC - most new ones do - but some only support the older SD cards.
Jul 18, 2009 | Kodak EasyShare Z710 Digital Camera
Sansa c240 and a 4 GB Micro SD HC card.
Sansa C240 can only read SD cards that are NOT SDHC - that means it can only read up to a 2gb Micros SD card.
Jun 05, 2009 | SanDisk Sansa c240 MP3 Player
Wont read sd card 4 gb
You will have to upgrade your dash to windows 6 if you want it to read higher compacity micro sd cards. This method i free and is the only way their is no unlock code to make the the software compatible, you must upgrade it. once upgraded you can use up to a 8gb micro sd, i have not tried a higher card than that.
Jun 02, 2009 | T-Mobile Dash Smartphone
Palm Tungsten E2 doesn't recognize SD Card Card Info states that no card is inserted Card inserted with device on Card inserted with device off No recognition Kingston 4 GB
The problem is simply that the Tungsten E2 cannot read SD cards larger than 1 GB. However, there is a solution that will enable it to read larger cards. A driver called PowerSDHC is available from that will enable the E2 to read cards of any size. I'm now running an 8 GB SDHC card on my E2!
Feb 17, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Wi-Fi SD card
Hey, id be happy to help :), the reason why your SD wifi card is not getting read by your pocket pc is because. The wifi card you have is probably have was made for a regular computer and is not compatible with your pocket pc. Id recommend for you to find a SD wifi card that is compatible with your pocket pc. And return the one you have now, thanks and I hope this helps!
Aug 29, 2008 | HP iPAQ H2210 Pocket PC
Every time i install my sandisk 4.0 gb sd hc into my computer it keeps telling me to install the card.
Check the specs on your computers card reader... Is it compatible with High Capacity SD cards? Anything over 2 gig is considered High Capacity. I'm quite sure you will find this to be your problem. Insert a 1 gig SD card and I'm sure it will read it fine.
Jul 15, 2008 | Computers & Internet
HP Compaq Presario V2000 Notebook Logo
145 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
