Question about InFocus ScreenPlay 4805 Multimedia Projector
Infocus projector connected to Toshiba laptop
Projector is working, laptop is working, cables are connected but I cannot get them to communicate. What is the sequence of the fn & f5 keys?
    Scholar:
  • 167 Answers
The sequence is fn first then f5 simultaneously then release. However the problem may be the resolution setting on your computer's 2nd monitor output may be out of range (too High) for the 4805 Start with 1024X768 and see if that works.
Posted on Nov 29, 2009
HP laptop wont communicate with Sony profector
Connecting an External Monitor or Data Projector
You can switch to anexternal monitor by two methods.1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor.2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCDscreen plus the external monitor or back to LCD screen only by pressing the Fnkey plus one of the function key. Here is a list of keycombinations for some of the laptops :-IBM ThinkPad = Fn + F7HP and Compaq = Fn + F4Toshiba = Fn + F5Dell = Fn + F8
May 02, 2012 | HP Pavilion dv4170us Notebook
Cannot get the Fn-F5 to work on Acer AspireOne
Nov 10, 2011 | Acer Aspire One PC Notebook
What function key will i use to connect to a overhead projector?
Connect you projector using the VGA cable Use the Fn+F5 key combination to toggle the display between the LCD on you laptop and the external Projector
Oct 23, 2010 | Acer Aspire 1640Z Notebook
I can't get a picture when I hook my projector up to my laptop.
HELLO,
If your LCD or DLP projector displays no image, this could be a variety of problems. First, check that the projector has power. On the top of the LCD or DLP projector should be some lights. With power, those lights will be on. If it has power, check to make sure that the projector lamp is firing. If so, go to the source. Make sure that it is connected with a VGA cable or USB cable to your computer, or with an RGB cable, S-Video cable or DVI connection to your VCR/DVD Player. From a laptop computer, the VGA cable should be connected to the VGA out connection, and into the VGA in connection on the projector. Are both ends tight?
If everything has checked out so far, the solution probably lies with the external monitor port. Check this by holding the Fn key on the keyboard, then press the F7 key. (On some computers, the key might be F5 or F3. Try these if F7 doesn't work) Each time you press the Fn / F7 combination, you will cycle your display through the following settings:
* Press Fn / F7 once: The laptop screen only
* Press Fn / F7 twice: The projector port only
* Press Fn / F7 three times: Both the laptop and projector port
* Wait a few seconds after each time you press the key combination to let the LCD or DLP projector refresh. Nine times out of ten this will result in seeing your projected image.
Hope this helpout....
Jun 17, 2010 | HP Digital Projector Vp6110 Multimedia...
Can't get my notebook screan to show
hello,
Indentify the video output options of the computer and the input options of the projector. Most common are VGA and S-Video. use the appropriate cable to connect the two. Your projector may be able to probe its ports to see what signal it is getting.
On your computer. After you make the hardware connection and your projector is set to receive on the correct port, extend your desktop to show on a TV if S-Video, or on a monitor if VGA. To have the screen of your computer to appear on the external screen, use the FN-Fx key combinations. Examine the laptop`s function keys and look for some icon that shows a computer and a screen. Most probably it is the F5 key.
Assuming F5 to be the right key, you press Fn-F5 and an OSD will appear on your computer. You scroll from an icon to the other by pressing F5 while still pressing down the Fn key.
If that does not work, I suggest you check your computer s manual for the right key combinations.
Hope it helps.
Oct 02, 2009 | HP VP6310 Multimedia Projector
My laptop won't recognize a projector
You need to push the function key FN and hold it down then press F5
Aug 20, 2009 | Toshiba Satellite Pro S300M-S2403 Laptop
Need to see display on both laptop and projector
On most laptops pressing the Fn key plus the F5 key (in your model laptop) several times will cause the video to switch to different options
In the various laptops I've used with data projectors it is the same.
If you plug in the data projector and power it up then the laptop then the Windows image will be on the data projector (provided the laptop's screen resolution matches the data projector).
To toggle between the data projector only, the LCD screen, then LCD screen plus data projector, and or back through this sequence, just press the Fn key and the F5 key to get the displays you want .
May 20, 2009 | Toshiba Tecra M10 Notebook
Infocus projector 4805 connected to Toshiba laptop
1.
Connect the external display port on your laptop computer to the projection system, and then turn on the projector. For information about connecting external devices to your laptop, see the documentation for your laptop computer.
2.
Set the display resolution of your laptop computer to match the resolution of the projector system. First, on your laptop, open the Display Properties dialog box by using the Display icon in Control Panel, and click the Settings tab. Then, in Screen resolution area, move the slider to adjust the display resolution of your laptop. If you don't know which setting to choose, try 800 x 600 pixels; this is a common setting for many projector systems.
Jan 08, 2009 | InFocus ScreenPlay 4805 Multimedia...
Connecting to projector
HI-
Try tapping the FN+F5 keys twice, or try FN+F3 keys for acer laptops. MAke sure that cables are connected tightly at both ends.
Hope this helps
Oct 09, 2008 | Computers & Internet
Acer Aspire 3680 + View Sonic Projector
does it work with external monitor ?
the key should be Fn+F5 or Fn+F6
I believe you need to hold fn and press f5 to choose the target (lcd, monitor, lcd and monitor).
Feb 26, 2008 | Computers & Internet
InFocus ScreenPlay 4805 Multimedia Projector Logo
241 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
