Question about Dell E156FP 15" LCD Monitor
Dell E156FP Monitor Problem
I am having a problem with my monitor. When I turn it the picture comes up for about 3 seconds and then goes black. If I turn it off and then back on it does the same thing. It continues to get power but the picture will not stay on. Any suggestions on what I can do?
  • jameseng2001 Mar 09, 2009
    Computer boots up and monitor stays on for about 3 seconds and goes off. Turning it on and off , it comes on and about 3 seconds later, it goes off again
If the screen is not completely black (i.e. just very very dim, turn the lights off to see) try using the controls at the bottom of the monitor to reset to factory settings (all settings). I have had this problem with two dell monitors so far and this seems to work.
Posted on Jan 29, 2009
I don't know how to adjust the bright and dark for the screen.
To adjust the brightness and contrast, do the following:
1. Press the either the Minus button and highlight the option you wish to change.
2. Press the Menu button to select the highlighted option.
3. Press the - or + buttons to adjust the brightness/contrast settings.
4. Press the Menu button again to accept the changes.
Click the link below for the documentation on this monitor:
http://support.dell.com/support/edocs/monitors/e156fp/En/about.htm
May 23, 2011 | Dell E156FP 15 inch LCD Monitor
WHO MUCH Dell E156FP INDIA PRICE LIST
being a 15 inch one ...it is about around $100 ..bu I think on Ebay you may get it for less on second hand ..
Mar 17, 2011 | Dell E156FP 15 inch LCD Monitor
Dell monitor E156FPb went black
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Jul 29, 2010 | Dell E156FP 15" LCD Monitor
My dell monitor will only turn on for a few seconds then it goes black. it doesnt turn of it just goes black and I can keep doing it and it will keep going black.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jun 29, 2010 | Dell E193FP 19" LCD Monitor
Monitor comes on for a brief milla second then
hold the power button for 5 sec : if the picture appears replace the button. ELSE check the chimic capacitor if damadged replace with new
Jun 21, 2010 | Dell E173FP 17" LCD Monitor
When i turn the monitor power button on monitor come on for about 3 seconds then screen goes black but power button is still lit. tryed old monitor and it works fine
The picture board on your monitor is bad, since it goes black after three seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 22, 2010 | LG W2252TQ Monitor
Monitor turns on and turns off 2 seconds later
compnerdtuls, You have a monitor with a sick "switch-mode-power-supply" ... It goes into PARTIAL or FULL shutdown mode because it has detected a FAULT CONDITION with itself or the inverter circuit. Why don't you go and watch some productive video clips at youtube to see if you might be capable of doing the repair or contracting out the work needed to bring your unit out of the BLACK SCREEN Of DEATH mode. You may even want to visit (FYI) a site that may have some info on possible cause of your monitor's symptom, www.ccl-la.com/badcaps.htm . I'm 12fixlouie on fixya.
Dec 05, 2009 | Dell E156FP 15"LCD Monitor
Green Screen
There are seveal cause to this issue, but with out seeing what your seeing I recommend that you search youtube on this one.
https://www.youtube.com/watch?v=84HPv6Epknc
Mar 05, 2017 | Dell E156FP 15" LCD Monitor
Dell E156FP 15" LCD Monitor Logo
336 people viewed this question
Alun Cox
