Question about SanDisk Sansa e260 MP3 Player
Retrieval of deleted voice recorded file
I accidentally deleted a voice recorded file (lecture from school) and was wondering if there was a way to retrieve it back?
Thank you
  • robert_logue Jan 09, 2009
    Thank you for the advice.
  • 4 Answers
Maybe, there are programs that retrieve deleted files, but sadly you need to buy them.
this only works if you havn't added any new voice recording (or a lot of voice recordings) or if you havn't reformatted your player.
Posted on Jan 09, 2009
I accidentally erased some files on one folder, then recorded over them. Is it possible to recover them? How? Thank you.
You should connect your recorder to PC and then you can try to recover your files and folders with Easy Drive Data Recovery software:
http://www.munsoft.com/EasyDriveDataRecovery/
It uses unique modern algorithms to recover files that other software either recovers incorrectly or is unable to detect.
Nov 11, 2010 | Olympus WS-110 Digital Voice Recorder
I synced a Tascam DR07 with a computer to see its files. I accidentally deleted those files from the window on the computer thinking they were copied files. They were the files on the Tascam, and now their...
You may try some recovery software to rescue the voice files on your recorder, here are some for your option.
Photo Video Audio Recovery (for Windows)
Photo Video Audio Recovery for Mac
Both programs can also recover video and audio items.
Note: Before your files are recovered, do not attempt to save more files to the voice recorder in case the original files(your recordings) are overwritten.
May 05, 2010 | Tascam DR07 Digital Voice Recorder
Why won't my E100 record voice files as MP3?
well you could get a free wma to mp3 converter
here is one click here
Aug 04, 2009 | iRiver E100 Digital Media Player
How to delete messages on the RCA RP5120 dig. voice recorder
This is a transcript from the User Manual you can find here, along with other documets, Faqs, and software for you digital recorder:
http://www.rcaaudiovideo.com/product.aspx?product=393
Erasing selected file:
To delete a file:
1. Press MENU repeatedly to select a folder (A/B/C/D).
2. Press or to select a file.
3. Press ERASE once and DELETE will fl ash on the display.
4. Press and hold ERASE for three seconds to confirm deleting
To avoid accidental deletion of all fi les, make sure you press ERASE only when you are reading the time duration of the undesired file instead of the remaining
recordable time of the player
Erasing all files in a folder:
To delete all files in a specific folder:
2. While playback is stopped, press repeatedly until ALL appears on the display.
3. Press ERASE and DELETE will fl ash on the display.
4. Press and hold ERASE for about three seconds, all files in the selected folder will be erased completely.
Jul 28, 2009 | RCA RP5010 Digital Voice Recorder
Problems in transferring voice (lecture) files to Mac
WMA is a windows standard. You can get the free components for Quicktime from Microsoft's web site. This should solve your problem.
http://www.microsoft.com/windows/windowsmedia/player/wmcomponents.mspx
Jul 25, 2009 | Olympus Audio Players & Recorders
I deleted a recorded file by mistake from the DWP vn-480 series and am trying hard to retrieve it somehow!! Is there any hope of retrieval???
Unfortunately this recorder model is designed with flash memory and once the files are erased they are gone. There are some companies that do specialize in flash memory recovery (Olympus is not one of them). You can go to google and search for flash memory recovery specialists. However this is a very costly process as it involves sending the device to these companies for them to do the recovery process.
Jun 08, 2009 | Olympus VN-480 PC Digital Voice Recorder
Not playing full recording
Maybe it's the preview play option of the player that you are using. It only plays a part of the recording for you to identify if it is the right recording that you are trying to find because the recorded allows you to record more than one file.
Sep 30, 2008 | RCA RP5010 Digital Voice Recorder
IHP120 20gb multicodecjukebox-voice recording
Sir,
I solved the problem .Actually under the SOURCE title it was under the LINE IN.There were some more options like INT.MIKE, EXT.MIKE, OPTICAL. So i first tried under external mike by connecting to the EXT.mike and selected the source and by removing the external mike switched to Int. mike and changed the source. It automatically picked according to the source and played the recording and saved it in the file and later heard the lecture with the head phone and later converted in to a file in the laptop. Now it is working nicely. A really a good product to make use and it is very much user friendly.
Thanks again.
regards
crsrinivasan
Aug 02, 2008 | iRiver iHP-120 MP3 Player
Deleting voice recordings?
Settings --> system --> Delete record File
See menu tree on p.58 of manual for a visual
Feb 21, 2008 | Samsung YP-U3 MP3 Player
None of the CD burning programs seem to work using the wav. files created by the recorder
maybe, you got those wav. files copy controlled. check out the relevant preferences from the voice recorder menus. if this solution doesn't work, simply convert the files into mp3, then convert them into wav. again. I hope this could help..
Nov 12, 2007 | Olympus VN-2100PC Digital Voice Recorder
SanDisk Sansa e260 MP3 Player Logo
224 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
