Question about Dryers
My Kenmore Dryer 68332 stopped working. not making any sounds
I took a load out and put the new load in, it wouldnt turn on, and the button didnt make any noise when hit
    Sergeant:
    Champion:
  • 262 Answers
Sounds like the thermal fuse blew take the back off and you will find on the duct work a oval looking piece that has two wires on it pull the wires off and ohm it out with a volt/ohm meter set on ohm if you have continuity thru it then it is good then start looking at the door switch being bad
Posted on Jan 08, 2009
DRYER MAKES HUMMING NOISE BUT WONT START
Sounds like the capacitor on the motor is faulty
Mar 21, 2014 | Kenmore Series 70 80 90 PN281798 Dryer...
Kenmore retractable vent keeps randonly going up and down , sometimes for 6-7 times before it will stop.How do we fix it?
I hope you have the $400 appliance insurance. I had the same problem in a new house purchase. First the downdraft wouldnt work, and then wouldnt stop.
It was a micro switch and motherboard issue. Took four visits by the (insurance paid for) techie to get and fit the right part. Good luck
Mar 08, 2014 | Kenmore 36" Telescopic Downdraft Range...
I have a 70 series kenmore dryer that is new. it has been working, I took out a load and put in another pushed the start button. It ran for about 2 seconds then stopped and will not start. It has power,...
Sounds like you may have tripped the thermal limit on the motor. Although, usually you will hear a loud buzzing sound when you try to start it. Let it set for about 2 hours, and try to restart. If that doesnt work, the only other thing that could stand in your way is a door switch. The door switch is a very easy and inexpensive repair. The motor is quite a bit more. If you have not cleaned the lint out of the inside of your dryer (requires some disassembly of your dryer), that would be a good place to start and will sometimes allow a thermally overloaded motor to work again. Keep in mind, if it is the motor, they only have so many thermal resets before they are just done. There are instructions on this website if you are interested in trying to diagnose this dryer. Please, make sure before you take it apart, you have it unplugged!
Feb 05, 2011 | Kenmore Dryers
When i push the start button i can hear and feel the timer working yet nothing else happens. when i release the start button the timer quits working.door switch is working. i've checked all the connectors...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 06, 2010 | Kenmore Dryers
Location of the thermal fuse on the kenmore gas dryer 80
Feb 03, 2009 | Dryers
Kenmore 3.5 HE front load washer went haywire, doesn't work now..
Yes - the ECU is to blame, and is a common failure with this unit.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Kenmore 43042 Front Load Washer
Kenmore 90 plus series dryer won't work
Sounds like the belt has broken. You could probably also use new drum support rollers. Check out this site which shows how to change a dryer belt:
http://repair2000.com/wpoolbelt.htm
It's not a difficult job if you're comfortable working with hand tools.
Oct 17, 2008 | Kenmore 62872 Electric Dryer
Kenmore HE2 Dryer makes three beeps but wont start
Check your door closer switch. Mine was doing the same and it turned out to be as easy as changing the switch.
Mar 23, 2008 | Kenmore 62602 Electric Dryer
What happens is that the door switch gets turned inside. I just took mine apart because of the same problems listed. The switch has a tab inside that has to make contact with the internal switch. I pulled mine apart and turned it so it made contact...put it back together and it works fine now. After doing all that it seems like you could turn the swith from the outside a quarter turn with a pair of pliers and accomplish the same thing.
Mar 22, 2008 | Kenmore Elite HE4 Electric Dryer
Clothes Dryer will not stop or be quiet
On some Kenmore which is made by whirlpool, there is a resistor connected to the timer control. when the machine is off can you listen to the timer switch and hear it running, making a clock ticking sound? If so, you need a new resistor. Being a dryer, when you open the door and it stops the button needs to be reset before it starts again, right? So I wouldnt be looking at the door switch as much as the start button. It may be the evil one.
Dec 23, 2007 | Kenmore 63942 Dryer
Dryers Logo
51 people viewed this question
Top Dryers Experts
