Question about ASUS Eee 4G Notebook
Wireless connection i'm trying to connect my new eeepc to my wireless router have been through every option and it just keeps on pending please help !
  • 2 more comments
  • pnebabe Jan 17, 2009
    i have the same problem, im running linux
    i have the sane problem, im running linux
  • james_in_NM Jan 18, 2009
    I cannot connect to open wireless networks. I tried at an airport, a restaurant, and at my friend's house and it just said "pending" - looked like it was never getting an ip address from dhcp.
  • BillW50 May 11, 2010
    Is this running Linux or Windows?
Same happened to me so I gave it a kick start, sort of like jump starting the car.
Wifi should be on. A blue light on your right of your keyboard should be on to confirm that.
That's why you have no luck.
Press FN and F2 together at the same time and a little box will come up with saying it's on. Do the same to switch off..
You got to setup a Local Area Connection through your connection wizard. Restart your computer to get it going.
Turn on all your wireless connect it through your router and hit the wireless networks on your eeepc, it should show your wireless and Lan. Ok, now click on wireless, make sure it's your wireless and not another connection.
Don't forget to restart your computer after you've created the connection because otherwise it won't work.
If you still have no connection, go to your connections left click on wireless once and click on properties. On this page you'll see your IP address and DHCP server, scroll down and you'll see signal strength, that means you can connect but we need one more thing done.
Now go to sharing tab and click on share this connection with local area network connections, boom, boom, restart the computer and remember if you still have a prob then you need to go the TCP/IP page input the DHCP your server name their IP Address at client identifier and then restart.
Linux needs a kick start, but once you get it up and going you'll be surfing in no time. I went to hell and back and figured it all out myself, that's my help to guys, good luck!
Posted on Jan 24, 2009
I am unable to configure the wireless connection on the eeepc 4g. Gets to pending then nothing
now this might seem a silly question but i hope you have a line into the building and a modem/router?
Jul 12, 2010 | ASUS Eee 4G Notebook
Trying to connect to home wifi with netgear router and EEpc G2g
Chekc your security settings, it can be that Eeepc not correctly determine security settings. Try to set all security for your SSID manually.
Apr 19, 2010 | ASUS Eee PC 2G Surf Notebook
Having problems getting asus eeepc to connect to sky wireless network have inputed the correct key just keeps saying pending wireless works as i am on it now
caps lock on wep key,correct key length,re-install OS from F9 w"E"hilst booting if you seriously cannot connect,choose option(F9) every other boot then press "E" then press "B" then proceeed with initial config pages(time,location,passwd,etc)
you might find your wi-fi magically works again
Oct 19, 2009 | ASUS Eee PC 4G Surf
Cannot connect to wifi
i had the same problem with my sisters eeepc so this is what i did
1. if u can: connect the eeepc to your router (internet box) using the Ethernet cable. the local area connection should then connect automatically if not connect through the network program on Linux.
2. if you are connected go to settings tab and then add or remove software
3. wait for the eeepc to find the new software (may take a bit of time), once it has found all new possible updates go to the settings tab in the add/remove software program and scroll down until you find Wireless update/patch or something similar.
4. click install and the ok, it will then dowload the new update (don't take long) and install it
5. once the update has completed it will ask you to reboot the eeepc do this and when you log back on click on the wireless network icon
6. find your SSID and enter any security and whatever
7. you should be online after that
Aug 03, 2009 | ASUS Eee PC 1000H Laptop
No wireless connection
I am assuming you're referring to the Asus Eee PC 701SD... if so, try the following:1. Check the hotspot to see what kind of IP address it is using [are they manually configured, or is there a DHCP server that assigns IP addresses] 2. Check your 701 and make sure its network connectivity conforms with the settings on the hotspot
Jun 18, 2009 | ASUS Eee PC 701SD
Won't connect to wireless internet
Try re-installing the hardware. Your drivers may be currupt. It could also be that the wireless card is not detecting a strong enough signal to connect, try searching for other connections. If the problem presists. It may be a hardware malfunction. In that case you'll need to replace the wireless adaptor. If you still cannot connect, contact your local PC repair shop.
Apr 16, 2009 | ASUS Eee 2G Surf Notebook
Unable to connect EEEPC 701 to BT HOME HUB 2
sometimes the best thing to do is start over.
reset any hubs, routers, switchers, etc.
then (just fro now) remove any firewalls,
or software that may get in the way.
You want to start with a bare minimum configuration and build from there.
eeepc works well with windows networks, the ethernet connection should just work, without additional software.
does eepc connect to other networks?
can other laptops connect to your network?
check all settings: ip address, dhcp or static, passwords, etc.
Try a "wired" ethernet connection, then try the wireless connection. if all else fails, use F9 (or DVD disk to reset/reload the system. i.e. start over.
Mar 26, 2009 | ASUS Eee PC 701 Notebook
Wireless connection pending
I have seen this problem with many of my clients. Here is a way to correct your WLAN connection problem:
1: Choose "Network" in the Internet option, disconnect it and then delete the Connection in the "Manage".
2: Click "Create" to recreate the connection, choose "Local Area Network- Wireless", then Next.
3: Choose "Next".
4: Select Address Type, and then Next.
5: Browse Wireless Networks and then choose the one you want to use, you should see your wireless router/modem and the signal should show "Excellent" or "Very Strong". Choose the mode to be "infrastructure" and the Transfer rate to be "auto", and then Next.
6: Wireless Channel Settings, choose any channel.
7: If your AP is using the WEP or WPA encryption, you need to choose "Enable encryption" and then input the Key and Key index, (If you want your connection secured, you should use WPA and select a key index.) choose Next.
8: Fill in the Name of connection, then choose Next.
9: You can choose the "Connect automatically at system startup" or "Start this connection when finished" if you want, and then choose Finish.
This should correct your connection issues. Good Luck.
Feb 02, 2009 | ASUS Eee 4G Notebook
Wireless connection
Some ideas...
I found that sometimes I have to "disable" the wireless service, and then "re-enable" wireless before it will show available wireless connections.
After that, just use your normal connection settings - passwords, security type, etc.
As well, at times, if I use the "Wireless Connections" Icon in the "Internet" page to log in, I have to re-type the password in. If I use the "Network Connections" icon in the toolbar at bottom, it seems to remember my password and logs in faster.
Linux quirks? I dunno. Hope this helps.
Edwin
Nov 20, 2008 | ASUS Eee 4G Notebook
ASUS Eee 4G Notebook Logo
230 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
