Question about Dell Inspiron 630M Notebook
Loss of wireless use. Cable connection works fine.
I have a Dell D510 that has lost wireless connection, became very intermittant then not at all. I've tried another wireless card in it from my Dell D810 I think it is and it came up but then failed again. If I search for available wireless networks it fails to find two that are active. I then search again and it finds the strongest network but won't connect. If I click on 'repair' it again cannot connect to the wireless network.
Any ideas?
Thank you!
My dell latitude d510 cpu fan won't start when i turn it on
sound like a faulty fan or the fan's power lead check all connections soldering and plugs for secure dust free connections or replace the fan
hope this helps
Oct 09, 2012 | Dell Latitude D510 Notebook
Can i run windows 7 on dell latitude d510 no drivers on dell website
It worked for me, for the wireless drivers, I installed those for d520 as the ones for d510 didnt work.
Apr 26, 2010 | Dell Latitude D510 Notebook
I cannot get wireless network to work on my dell
Download this driver. if your hardware is ok this will make it function.
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R257684&SystemID=LATITUDE%20D510&servicetag=&os=WW1&osl=en&deviceid=8274&devlib=0&typecnt=0&vercnt=8&catid=-1&impid=-1&formatcnt=0&libid=5&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=378629.
Good luck
Apr 17, 2010 | Dell Latitude D510 Notebook
I have vertical coloured lines on screen, these will go away if screen is pushed back and forth. Any Ideas? It is a Dell Latitude D510
There is a thin ribbon cable that runs from the motherboard to the screen, it is this that has worn.
If you can imagine every time the laptop is opened and closed it bends the ribbon cable back and forth and eventually get fatigues giving the lines on the screen where it is wearing away the connection.
They can be replaced but require quite a lot of work to replace as you have to strip down the screen and base unit to get to both ends.
Search for Dell D510 Display cable and you should find what I am talking about. A second one appears to be about £10 - £15.
Mar 03, 2010 | Dell Latitude D510 Notebook
Dell Latitude D510 Wireless Connectivity Fades/Dies
There are wrong settings of your wireless network with your Dell latitude d510,you need to recorrect it .
Jan 27, 2010 | Dell Latitude D510 Notebook
Wireless connection has disappeared since re-installation of windows on dell d510
You will need the drivers from the Dell website, or install the Dell drivers and utilities disk if you still have it.
Jan 05, 2010 | Dell Latitude D510 Notebook
My dell latitude d510 drops wireless connection, lately as many as 5-6 times an hour. The routers seems to be working, and the wireless connection Icon says I am connect by I get the screen telling me I am...
The problem may not be the WI-FI but in the router itself. You didn't mention the strength of the connection when you are able to connect. It's also possible that the channel the router is on has interference and changing the channel will provide a more reliable signal.
Nov 09, 2009 | Dell Latitude D510 Notebook
Dell Latitude D510 - Turn on Radio for WiFi
This can be found in a couple of areas. Under Computer Management, make sure Wireless Zero Configuration is set to enabled. Also under Network Connections, make sure that the network adapter is showing as enabled, and is not disabled. This can be done by right clicking on the network connection and clicking enable.
This issue sounds like you may need to explain to her that the network cabling needs to be changed around so that the router recognizes the cable modem, and than she should be set.
Sincerely,
Ryan Deschaine
Systems Administrator
Boxen Solutions LLC
http://www.boxensolutions.com
Email address: ryan@boxensolutions.com
Office number: 262.254.0064
Mobile number: 262.834-5844
Fax: 414.918.8432
AOL: BoxenRyan
Twitter: BoxenRyan
W172 N9175 Shady Lane
Suite 418
Menomonee Falls, WI 53051
Sep 22, 2009 | Dell Latitude D510 Notebook
Don't know how to get my hp deskjet 6840 to print wirelessly
Should have a USB connector and needs to be plugged into the USB port.
Hope this helps. Bud
Dec 31, 2008 | HP DeskJet 6840 InkJet Printer
Dell Inspiron 630M Notebook Logo
129 people viewed this question
Alun Cox
