Question about Refrigerators
Rotten gasket seal on ConServ bottom freezer refrigerator
I am looking for the gasket seal for both the freezer & fridge both. The model number is SKF375. It's an older model. The fridge seal is 38 x 23 size gasket and the freezer seal is 32X23. Any idea where I can purchase them? Will I be able to install it myself?
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
had same exact problem - followed advice for fixing same problem in similar refrig. took of the back panel off the freezer section - 8 hex head screws - and found the cooling fins all frosted over.
Posted on May 31, 2008
SOURCE: Fisher & Paykel Model number 402B S.Steel. Bottom frezer top Fridge.
My Fisher & Paykel Model E402B Stainless Steel Fridge/Freezer has a problem. Bottom Freezer is OK but Refrigerator will not work properly, somtimes it will freeze everything now it just warm inside i have checked the the fan and the rubber holding it up has broken also the ice is frozen in the vents can you help i got someone in to fix it but he said it will cost around $600 as there might be more wrong with it, what do you suggest thanks Clare
Posted on Sep 29, 2008
SOURCE: Condensation on refrigerator front btwn top freezer and refrigerator doors
I have the same problem with my frig in the basement. I get condensation and resulting mold on the top outer surface and related areas. This is from the surface being cold, with resulting outside moist air condensing on the cold surface. Best solution - spray/wipe the surface with a bleach and water solution, let it soak a few minutes, then wipe off with a rag. Add a drop of dishwasher soap to a mixture of roughly 4 parts water to one part bleach. Repeat if necessary. Do this as often as the problem seems to creep up again. Good luck!
Handyman in NJ
Posted on Oct 11, 2008
Techsim
  • 59 Answers
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
  • 31 Answers
SOURCE: KENMORE MODEL 596 BOTTOM FREEZER, FRIDGE NOT COOLING
The freezer will stay cold because a small amount of cold air will be forced through the frost but that will not be enough to make it up to the refrigerator portion. You can defrost the unit by removing the metal panel and allowing the frost to melt. Careful use of a hairdryer can speed up this process. This will likely be a temporary fix. The root cause of excessive frost can be caused by a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar bill at several points around the door, both on the freezer and refidgerator door. If you can pull the bill out with no resistance, the door is not making a good seal. Inspect the seal and make sure there isn't anything stopping the door from closing such as food, or a shelf not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The defrost system has three main parts, the defrost heater, thermostat, and timer. None of these parts are particularly expensive, or difficult to replace you feel comfortable with repairing it yourself. If you can troubleshoot this by manually starting the defrost cycle. Let me know if you would like this procedure.
Posted on Jan 07, 2009
Why the freezer door opens when the refrigerator is closed?
I have a refrigerator with a top freezer that was constantly popping open, just enough to let the heat in and melt anything inside. This can also cause heavy frost build up from condensing humidity in the air. The frost can build up on the front face of the fridge where it meets the magnetic gasket on the door making it even harder to keep the freezer closed.
The cause in my case was that slamming the refrigerator door sent a puff of air through the ductwork to the freezer above. The sudden pressure increase popped the freezer door open and the door wasn't heavy enough to close on its own. Since this is a beer fridge in my garage I fixed it by putting a stick on childproof latch from H-D on the freezer door. :-)
If this was our main fridge indoors, I would first check to see how much force it takes to open the freezer vs. the refrigerator section. It should be about the same. If not, check the freezer door gasket to be sure no food or ice is built up on it and that the mating surface is clean. Check that the door is closing parallel to the mating surface. A misalignment would make it hard for the gasket to seal or stay sealed. Adjust hinges if necessary. If all seems ok, check to see if the fridge is level or possibly needs to be adjusted so it tilts back just a bit to make the doors self closing and not fighting gravity to stay closed. If all else fails, inspect the door gasket to be sure it isn't broken or stiffened with age. Inspect the bottom of the door gasket with a mirror. I once had a side by side with what looked like a good gasket until I felt around the bottom of the door. Replace if necessary.
Dec 15, 2016 | Refrigerators
PARTS NUMBER
Hello Jerry;
My name is Peter. I am a retired field service refrigeration technician.
You need to provide a model number for me to give you the gasket part number and price. The model number is on a label in your fresh food section on the upper side wall.
You have a bottom freezer, Right? These bottom freezer drawers are had to seal all of the time. They can get off track and not seal properly. It is not uncommon for them to ice up around the door gasket.
Lets try this first:
1.) Clean the gasket.
2.) With a hair dryer and a kitchen spatula, Heat the gasket while pulling gentle out on the gasket, to expand the gasket.
3.) Run a piece of paper between the gasket and the freezer front. If you can do this, then you still do not have a solid seal.
Feb 25, 2015 | Freezers
Hi, I think the seal is damaged on my fridge freezer. It is a CB18m/1c/fan whirlpool fridge freezer. Where do i look for a replacement seal? Thank you
Is a package/or a shelf blocking the door? If a gasket is required & damaged it would be noticeably different than the look of the rest of the gasket. The door originally was held straight by the screws behind the gasket & a undamaged door liner(cracked with weight of packages will cause it to twist), if it is twisted than it can be realigned by twisting it straight & may have to loosen the screws a little first & then snug them back up after it has been twisted straight. Gaskets generally have a flat magnet in them to pull the door up to the body of the fridge & with a model number(or take the gasket to them is the worse scenario) can be obtained from a Major appliance store or they can order it.
Dec 12, 2013 | Refrigerators
Model #79575543401 KENMORE ELITE Refrigerator The left side double door leaks at the bottom into the interior of the fridge. There is a panel on the inside of the bottom of the door, but not sure how...
. Using a good light , flashlight , etc. check your refrigerator and freezer door seals . This is the gasket that seals the door shut when closed . Look for cracks, tears, and possibly bumps in the gasket material. If you notice any of these , replace the door seal gasket . Furthermore , it is always best to replace both door gaskets at same time .
Feb 19, 2011 | Refrigerators
Can't find the model number - our fridge is old; about 20 yrs. Freezer door won't seal so cold air leaks, ice forms, water drips at the door handle. My husband tried beefing up the magnets, but that...
model on that vintage very well might be behind the bottom lover vents. remove vent screws and kick plate vent. look for a piece of paper in a taped on envelope. also sometimes on a sticker on the back of the unit.
hope this helps you.
Jan 24, 2018 | KitchenAid KTRS19KKSS Top Freezer...
Freezer won't stay shut
If you want a part number for the replacement door gasket please provide a complete model number here so I can give that to you or you can look it up yourself at www.searsdirect.com You must have your model number. (sample 110.XXXXX etc)
The magnet is inside the door seal itself. If the seal is damaged replacement is your only option.
Thanks for using FixYa!
Kelly
Feb 18, 2010 | Refrigerators
Model gss20iepcbb freezer side works fine ...fridge
on most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hopr this helps good luck ron
Dec 10, 2009 | Refrigerators
Replacing a freezer gasket
Yes and here is a link to the service manuals ( there are two available) that provide parts and some details on how to remove and replace. hope this helps you..
http://136.166.4.200/contents/Fridge/LRDN20720xx.htm
regards
Jul 09, 2008 | LG LRDN20720 Bottom Freezer Refrigerator
Refrigerators Logo
162 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
