Question about Digital Audio 2400 WATTS HIGH CURRENT AMPLIFIER DHC1604 Car Audio Amplifier
I need to know if the amp is good and also i cant find the specs for the amp.
3 Suggested Answers
  • 173 Answers
SOURCE: digital audio dhc 2754
no thay need 1000 rms each i would go with a hifonics bxi2010d amp from vminnovations.com for around $300
Posted on Apr 03, 2010
  • 3 Answers
SOURCE: BP1200.1 Car Audio Amplifier: is that amp good for 2 12 inches subs kickers 600...
that will most definitely be the best amp you will own and the only amp you will ever need to purchase.
Posted on Jun 11, 2010
Hi, i need to know the exact power plug so i dont have to run the pedal on battery power.i know i need a 9v power supply but i dont know the size of the jack that goes into pedal..many thanxs..
Unfortunately, battery jacks and plugs similar to the type you're describing do not have any real standardization - unlike the outlets and plugs in homes and businesses have.
You best bet is to either bring the plug / jack to a shop to match it or contact the instrument's manufacturer to obtain the connector specs for physical dimensions
Be sure to obtain the power requirements in either watts or amps so that you can obtain a power source capable of delivering what you need without overheating during longer periods of use. Adding 25% to 50% more amps or watts to the minimum required should provide years of trouble free service. Example: 9VDC at 50 watts should be supplied by a 9VDC 62 watts or even 75 watts; or in the case of a rating of 9VDC at 6 amps should be supplied by a 9VDC at 7.5 amps or even 9 amps. With DC powered devices, make sure you observe proper polarity! Good luck!
Mar 16, 2016 | Music
How many Watts is the A1300HCQ AUDIOBAHN amplifier
  • 2400W Max, High-Current Monoblock Car Amplifier
  • RMS Power Rating:
    • 300 watts x 1 chan. @ 4 ohms
    • 600 watts x 1 chan. @ 2 ohms
    • 1200 watts x 1 chan. @ 1 ohm
  • Max Power Output: 2400 watts @ 1 ohm
Dec 18, 2014 | Car Audio & Video
How many Watts is the a1300hcq Autobahn amplifier
A1300HCT Max Watts:
  • RMS Power Rating:
Dhc1204 car amplifer
it puts out 600 clean watts per channel, rms @ 4 ohm, and up to 2000 dirty watts bridged mono.. lt listed for over $800, but is realistiocally worth around $300, currently.
DIGITAL AUDIO Amplifiers
Jul 15, 2014 | Digital Audio 2000 WATTS SINGLE CHANNEL...
Mtx mxa 6001 amp cant get it to produce good bass using mtx 5500 subs running a 2ohm load
You seem to have everything in spec. check your crossover points and your speaker wiring. subs may be playing out of phase.
A huge factor is subwoofer enclosure ...if the enclosure is not in spec with sub requirements the subs will not peform great.
Sep 23, 2013 | Car Audio & Video
Im looking at this rockford fosgate p700-1bd amp brand new for $300 it comes with a birth sheet it says 750 rms on a 1ohm load. i cant find any reviews about it 225 rms x 1 @ 4-Ohms 450 rms x 1 @ 2-Ohms...
You can't go wrong with Rockford, in my opinion. Everything they make is well built and high quality. I personally have two Rockford p500-1bd amps hooked up to four 12 inch subs in my car and those amps make those subs slam. I have them wired down to 1 ohm and the specs say that they should be pushing 500 rms a piece at 1 ohm so that p700-1bd amp really packs a punch. Depending on what you're hooking up to that amp I would defenitely recommend it to you. - Ryan in Alaska
Feb 15, 2011 | Rockford Fosgate P7001BD Car Amp
What is current
http://en.wikipedia.org/wiki/Electric_current
Explains what electrical current is.
But as for your amp, it means that your amp can handle high power going through the amp without shutting down or being blown up. As your impedance(resistance) drops on the amp, more power the amp will put out....
Sep 19, 2010 | Digital Audio 2000 WATTS HIGH CURRENT...
I need to know that amps that this device needs
If in the USA, this will be plugged into a 120v AC mains supply, the power into the device is 10.5v DC.
It uses less than 6 watts.
I cant see any info for amps, but i would imagine it would be less than 1 amp.
Your manual is here http://www.westell.com/images/pdf/e90_6000_6100_6110_ug.pdf
And your detailed specs here
http://www.dsl-warehouse.com/pdf/westell6100_liteline.pdf
I hope this is of some help to you, please leave feedback
Thank you
Aug 20, 2010 | Westell Wirespeed LiteLine 6100...
Just need to know the specs for the orignal battery in a 2002 LeSabre is it 12v 6 amps or 2 amps
the only thing you need to decide is how high of CCA
you want,it is for Cold Cranking Amps,
the higher the number the more you can crank your car over before it goes dead,a good number is 450cca
Jan 20, 2010 | 2002 Buick LeSabre
Car Audio & Video Logo
242 people viewed this question
Top Digital Audio Car Audio & Video Experts
Joe Ankney
Level 1 Expert
Tom Chichester
Are you a Digital Audio Car Audio and Video Expert? Answer questions, earn points and help others
