Question about Packard Bell Easy One Silver 2120 Notebook
Need to remove keyboard on easynot c3256 - Packard Bell Easy One Silver 2120 Notebook
How i unlock my keyboard. lts packard bell easynote TE11 BZ
Hello
Does the whole keyboard not work or only some keys?
Try the following shut down the computer , disconnect the power cable and remove the battery from underneath then press power button for about 20 seconds then reconnect the battery and the mains power and switch on the laptop again.
Did you spill any liquid on the keyboard?
Jan 23, 2015 | Packard Bell Computers & Internet
Easynote tm01 Hi, My daughter spilt about half
When one of my kids forgot his phone out inth the snow i dismantled the whole thing and put the mothercard in the kitchen oven on the lowest temperature for about 1hour to extract all of the water i could'nt see. booted the thing up and it was good to go.(tip)
As for the other? it's cheaper to buy a new one than to install a new motherboard.
Oct 24, 2013 | Computers & Internet
Remove keyboard from e-system laptop
I have a Packard Bell ALP-ISIS GB easynote which I bought in 2007 but now I need a new battery old battery not help plis
Sep 18, 2013 | Computers & Internet
Remove keyboard packard bell easynote LM
Nope, u need to remove whole panel AND keyboard to get acces to motherboard, take one screw of and then u can pull out your motherboard and then u can acces to the fan.
The kboard comes of quite easyli, just press lil buttons(you can see em above f1-f12->) I used this as advice http://www.youtube.com/watch?v=Ayng3v482Hg
Not the same laptop but u will figure it out how to dissamble your laptop with this.
Mar 31, 2012 | Compaq Keyboard
How do I fit a new keyboard to an easynote C3 laptop
Are you asking how to connect an external keyboard?The easynote C3 has a parallel port on it. Hence you will have to get a keyboard(parallel port) and plug it into the slot. Thats all.
Regards,
Sai.
Nov 30, 2009 | Computers & Internet
I need to replace a keyboard on a PACKARD BELL EASYNOTE F7305 but I cannot locate the screws that are holding it in place could someone please point me in the right direction?? Thanks
I would expect, as with most laptops, you will need to remove the bezel theat contains the power key, etc. In most cases when replacing a keyboard you are required to remove most of the top plastics, bezels and in some cases the screen. I would advise on seeking professional assistance on this.
Nov 20, 2009 | HP Computers & Internet
How do I remove a CMOS battery from a Easynote R1935?
Hello! the CMOS is a stack whose is under de keyboard! Many computers give to remove the keyboard.
For this, there is usually some caps underneath the computer where are the memories and graphics card and also indicates the screws you should take to loosen the keyboard.
Otherwise the result attempts to disassemble the top of the computer where you have the buttons and turn off the sound
Dec 22, 2008 | Computers & Internet
How do I remove the keyboard on a easynote mv35
Push the top cover plate to the right (towards the power botton) and remove.
The keyboard should now lift away from the laptop and you can disconnect it from the motherboard by easing up the plastic clips on either side of the motherboard connection.
Nov 19, 2008 | Computers & Internet
Packardbell easynote
First makes sure to dry the keyboard well somehow and try it after that. Turn the laptop upside down and try to let it dry.
If that does not work after it has dried well I think you need to replace your keyboard.
Meanwhile you can connect an external keyboard.
I hope that helps. I do not think you can do more.
Jan 16, 2008 | Packard Bell Easy One Silver 2101 Notebook
Packard Bell Easy One Silver 2120 Notebook Logo
56 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
