Heat stays on no matter what the therm temp is set on any ideas
I INSTALLED A NEW THERMASTAT AND THE PROBLEM IS THE SAME . AS SOON AS I TURN THE HEAT SWITCH ON AND GO DOWN TO THE UNITTHF FAN COMES ON AND THE GAS STARTS AND THT UNIT RUN TILL I TURN OFF THE SWITCH ON THE THERM I NEED THE DRAWING 09-24212-01 REV 06
  • carl carpenter
    carl carpenter May 11, 2010
    is this a digital programable or non-programable t-stat.when you say fan, some units have an iduced draft motor that comed on first.
    Problem Solver:
  • 13 Answers
If the stat has an installer set up did you configure it for your specific system type? (heat pump,fossle fule,and fan control
Posted on Jan 11, 2009
I have a 2005 grand prix gt temp guage reads normal and heat is on and warm when start driving heat gets colder or if i change to defrost its cold air doeasnt stay hot car doesnt over heat though changed...
The heating coil is probably getting plugged up. You may have heat at idle or slow speeds, but once you get going, there is not enough coolant going through it to stay warm. Get the system flushed or replace the heating coil.
Jan 23, 2014 | 2005 Pontiac Grand Am
Carrier gas furnace does not cycle right.
Check out the flame sensor see if it is clean and check the connections .
May 21, 2017 | Carrier Heating & Cooling
2000 altima 4 cyl. put new therm in { only a 170 degree offered for car} engine does not come up to temp and that means no heat? any ideas
thermostat in correctly? is it stuck? air lock?
try letting the engine warm up a bit then tap the thermostat housing with the handle of a wooden screwdiver or something (NOT A HAMMER)
Jan 29, 2012 | 2002 Nissan Altima
I have a GMP100 furnace and I replaced the control board because the blower fan wouldn't kick off now and then. It all works great but the main blower only stays on about 45 seconds after the burner turns...
Check the board for a set of dip switches. Check against the old board for switch positioning. These control fan on/off times. Ensure you turn power off before changing switch positions. If no dip switches,??
Dec 04, 2009 | Refrigerators
Central heat/air unit for home blows cold air
could just be heat trapped in ductwork for attic temp or from not running for more than a few hours.
Jan 13, 2009 | Haier HC48C1VAR Central Air Conditioner
Ruud air to air heatpump intertherm propane furnace honeywell th5220d non programable thermostate.fan on furnace will not turn off in aux.mode even though the furnace heat kicks on and off. thank you for...
Make sure fan relay is wired correctly (G) wire. Ensure the fan on therm is not on, it should be on Auto or off.
If your furnace is short cycling because it has to keep heating your home, the delay in the control board may be staying on to compensate for the exchangers getting hot. If it heats normally, then put your attention to your thermostat.
Set the heating system on aux heat only. Fan should not be on, if it does stay on after a heating cycle, see if the furnace is heating normally, and reaching temp as desired before the heat comes off. Then check the therm wiring, pull the face of the therm, disconnect green wire (fan) and try the heating again.
Dec 06, 2008 | Intertherm Heating & Cooling
Problem with RSKP 0006 control board
If the unit has an outdoor thermostat, this turns the aux. heat on very cold days. It may need to be replaced, or removed completely, if its kicking over to soon before it gets that cold. If its set to turn on the electric at 30 degrees, then its working the right way. Also, look for different temp. setting on the board you lust installed, there should be some sort of adjustment options on it. Especially if there is no thermostat outside.
Feb 28, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
