Question about Gateway PLSM50TV 50 in. Plasma Television
55 INCH TOSHIBA, CONVERGENCE WON'T STAY SET, WON'T ALIGN
The edges of the "boxes" around "info" are not straight. I can adjust each individual convergence location(0-9) but they seem to change again later. Also, the text on the screen, especially near the edges, shows the misaligned convergence. Have electronics experience, was hoping I could just swap our convergence ICs. 55H70 model.
  • Gateway Master
  • 3,459 Answers
Projection TV55 INCH TOSHIBA, CONVERGENCE WON'T STAY SET, WON'T - 2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
    55 INCH TOSHIBA, CONVERGENCE WON'T STAY SET, WON'T - 2_bing.gif"h_mi">Screen looks 3D2_bing.gif
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
  • photos of convergence problems.
    Here is a quick test....
    Using your original remote go-to the settings menu then goto the convergence section.
    Try to adjust the red and then the blue convergence.
    You should be able to move RED and BLUE in all directions - up, down, left, and right.
    55 INCH TOSHIBA, CONVERGENCE WON'T STAY SET, WON'T - 2_bing.gif't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
    Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
    93a1209.pngCONVERGENCE SOLUTION
    You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
    This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Posted on May 30, 2010
How to fix red & blue lines to align, box 3,7.8 on 50H81?
Have to do convergence adjustments; provided the circuit part to convergence section works properly. Check it out first.
If it works properly, do a convergence adjustment. Do it carefully. Before start to do it, read and understand all the steps have to do.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Details about this adjustments have given by one of the posts.
Aug 23, 2014 | Toshiba 50H81 50" Rear Projection...
Need to get to cross-hairs screen to align colors. I did it once b4 using a sequence of buttons but lost that info.
Unplug TV ,then while holding CH+ and VOL+, Plug Set Back in to Outlet ,When Tv comes on you should then be in the Service Menu.
Press CH+ and CH- to Select an adjustment you need to adjust
Press VOL+ and VOL- to Adjust .
Jul 20, 2011 | Sharp 55R-WP4H 55" Rear Projection...
How do i adjust convergence on a 55 inch toshiba
You need an original working Toshiba remote: two choices here--in the customer menu there will be an option for this and there is a hidden tech menu for finer adjustment all over the screen.
Usually the customer mode works ok--if you find red or blue will not adjust somewhere you have a problem-that aside tell me what you are trying to acheive?
SD TECH
Dec 12, 2009 | Toshiba 55HX70 55" Rear Projection...
The picture is bowed and has a rainbow affect around the edges
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 01, 2009 | Mitsubishi WS-55809 55" Rear Projection...
55 inch mitsubishi rear projection tv red lamp out of adjustment
Have convergence IC's replaced. I believe this unit uses STK-392-570 convergence IC's Only one has gone bad but replace them both, because if one has failed then the other is not far behind, for Blue and Green. One handles Red, One handles BLUE and Grn. There are only two of them in the set, They are the two largest IC's in the entire set.
Oct 01, 2009 | RCA HD52W59 HDTV Projection Television
Toshiba tn55n81
in the menu go to convergence adjustment and align the colors
Oct 20, 2008 | Toshiba 55H70 55" Rear Projection...
Toshiba theaterview 50in rear projection tv
Look at it on the QVC channel where you have boxes with straight lines. If any of the 3 colors are bowed and 1 inch off, then it needs parts inside. If the colors are straight and only 1/4 inch off, you can adjust it. Using the remote, in the menus find convergence to adjust. Your user manual will explain it. At WWW.Toshiba.com you can download the manual if you do not have it.
Mar 24, 2008 | Toshiba 57H81 57" Rear Projection...
Can not align color dirvertions on test screen
I think you need a remote to use the convergence features of this set. Does it have an auto convergence feature? And does it work?
Dec 31, 2007 | Toshiba 55H70 55" Rear Projection...
Adjusting the color convergence
You are going to have to have the convergence IC's replaced, the only way to correct this I'm afraid. Good Luck
Jun 24, 2007 | Toshiba 55H70 55" Rear Projection...
Center screen convergence problem
The convergence adjustment on the TV set are for the center adjustments ONLY. if you cannot get them in or they are way out, then you have a convergence IC problem. Dont feel bad though as it happens to every rear projection set ever made. Good Luck
Dec 30, 2006 | Toshiba 53AX62 53 in. Rear Projection...
Gateway PLSM50TV 50 in. Plasma Television Logo
169 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
