Question about HP Pavilion a1230n (EG134AA) PC Desktop
Hp a1230n heating
I have a hp a1230n pavilion and it shuts off on me after about an hour using it. i downloaded speed fan to monitor the temp and everything is fine except the remote sensor. it started at 95f and climbed all the way to 135 before i shut it off. is this normal and where is the sensor located at?
thanks Robert
rmooney@consolidated.net
  • rmooney Jan 09, 2009
    thanks
    hp sent me a download to update the bios and also the fan in the back wasn't working 100%.
  • 139 Answers
Switch on your computer and go to bios and check if your system restarts.
Posted on Jan 08, 2009
  • 53 Answers
Robert, I recommend you to open the chassis cover and check if there is any obstruction of any air vent. Meanwhile, if you can hear a loud fan spinning of the CPU heatsink, you might have to replace the thermal paste, the instruction http://www.techpowerup.com/articles/overclocking/134.
If the problem still persist, don forget to come back here. I will try my best to help you.
  • Eugene Tan
    Eugene Tan Jan 12, 2009
    Glad to help, Thanks for the rate (^_^)
How to take cover off HP a1230n computer
Remove side panels, "2 screws on each side at back" top piece should come off, Normally the front panel is clipped into slots and possibily one to two screws, remove with care.
Apr 16, 2012 | HP Pavilion a1230n (EG134AA) PC Desktop
My desktop doesnt have any sound!! i have a hp pavilion a1230n
install your sound driver from your motherboard cd or turn on your windows update
Aug 16, 2011 | HP Pavilion a1230n (EG134AA) PC Desktop
HP Pavilion a1230n had bad power supply I changed it out for a better one of the same make and model. Now when it turns on I can hear the hard drive spinning and the fans running but it beeps every few...
If the beeping is coming from the power supply, that typically means that you are pulling too much wattage. I would recommend trying a higher wattage power supply. The video card is one of the lowest things on the computer's list of things to keep running at all costs, because even if your video card flickers off, you won't lose data. Before getting another new power supply though, I would ensure that your video cables are properly plugged into your video card and your monitor. To be sure that they are snug simply screw them in so that they don't wiggle at all when you pull on them.
Jun 10, 2011 | HP Pavilion a1230n (EG134AA) PC Desktop
I have an HP Pavilion a1730n. For the past 5 times I turned it on, I received an error message Error: The System Fan Has Failed!Service PC to prevent damage to the system.PressF2 to Continue I ran HW...
1. Check if fan is spinning. If not, replace with new one or check cables.
2. Check if there are no swapped fan connectors when reconnecting mb cables.
3. Check BIOS update on HP website. Choose your OS here: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=3339287&
4. Check for a BIOS setting for disabling the fan monitoring.
5. Install a monitoring app which reports fan speeds and temps. See http://www.cpuid.com/softwares/hwmonitor.html
6. Check if CPU fan works.
Mar 14, 2011 | Computers & Internet
I up dated the BIOS in my HP Pavilion a1230n. when I rebooted the pc came on the green light stays solid green and the monitor says no signal detected what do i need to do
Check your video card connection.Be sure you have set the default monitor in the BIOS settings.If it still doesn't work. Try to install a video card because your motherboard maybe faulty.
Apr 08, 2010 | HP Pavilion a1240n (EG136AA) PC Desktop
G60-120US high temp problem
Laptop's temp should NEVER be higher than 60-70 C. Otherwise, windows or the CPU will shut it down (my laptop never goes over 75 C, even when running games for a short time)
A few tips:
1) Laptops are a really bad choice for games. They are not designed for that and they will overheat, some of them a lot, depending on the manufacturer.
2) Check if you BIOS has an option to turn "automatic fan control" OFF. This will keep the fan running at HIGH all the time, helping somewhat with the heat (most laptops do not have this control in the BIOS)
3) Clean up the fan. Turn the laptop off, disconenct the AC charger, remove the bottom cover and blow compressed air from a compressed air can. Be sure to remove all the dust and lint. Check that the fan moves easily. Replace the cover, plug the AC charger on and try again.
4) REMOVE SPEED FAN and install CPUID's Hardware Monitor from here:
http://www.cpuid.com/hwmonitor.php
It's much better and it gives you the temps of CPU, HD and video card and also speed of fan(s)
Mar 27, 2010 | HP G60-120US Laptop
HP pavilion DV6700nr laptop looses power
If it is (and it does sound like) a heat problem, the first thing do to would be to make sure the vents are clean and the fan and heatsink are free of dust buildup.
Here is a page from HP to assist you in doing so:
Reducing heat in notebooks
If you go into the BIOS setup, many have an option to monitor the CPU temp. Watch it and see what temp your computer shuts down.
Hope this helps. Thanks for using Fixya.
Jun 04, 2009 | HP Pavilion dv6000z Notebook
Computer shuts down
Almost certainly an overheating problem. Speed Fan will provide a temperature monitoring solution if you don't have one built-in: http://www.almico.com/sfdownload.php This program will also give you S.M.A.R.T. info. Open the case and look for dust bunnies, especially in the heat sink and fan areas.
May 26, 2007 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
HP Pavilion a1230n (EG134AA) PC Desktop Logo
181 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
