Question about Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft. Conquest Side-By-Side Refrigerator w/ In-Door-Ice Ice Dispensi...
Inside LED and light on fridge do not work.
The light works fine on the freezer side but nothing on the refrigerator side. Not sure what happened. Help?
    Scholar:
  • 58 Answers
First check your light bulb to see if it's good, if it is replace the door sw( it's the switch the door hits when closing ), It can be a pain to remove but that's the only parts that make up the light circut hope this helps
Posted on Jan 09, 2009
Back of freezer has frost and freezer wont cool to proper temp. icemaker etc also not working
Did you leave the freezer door open for a period of time while the refrigerator was running? Unplug and defrost the freezer manually with a hair dryer until all frost is removed inside and in back of the freezer. Reapply power and see if it will then cool/freeze properly. Let me know the results
APPLIANCE 911
Jan 10, 2016 | Samsung RH29H9000SR RH29H9000SR 36"...
How to stop the flashing (strobing) lights inside both the fridge and freezer?
I had the same problem but instead of throwing a couple hundred dollars away I decided to let my lights stay on all the time inside the fridge. All I did was pop the filter switch out so it wouldn't trigger when the door was closed. No more flickering and the hole doesn't irritate me like the rave party inside my fridge did????
Apr 01, 2015 | Whirlpool WRS325FDAM 25.4 cu. ft. Side by...
Refrigerator lights both not working. Freezer / Fridge LED Control numbers not lighting up. Still works fine. Freezer lights work fine. Whirlpool Gold Model GS5SHAXNL00.
Sorry to read about your problem, I hope this helps you out.
you lost a control board
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Our refrigerator is not cooling at all. The freezer is working fine, but no cool air is getting to the refrigerator section. A couple of weeks ago, this problem happened after the freezer had started...
Some fridges only cool the freezer and an evaporator fan motor moves cool air from the freezer to the fridge side. If this fan doesn't spin very freely then it may need to be replaced. You should also pull out the fridge and see where the drain hose is connected to the inside of the fridge, try pouring hot water down the hose to see if it is open. It may be clogged with a pea or some food or frozen. If your fridge is really full, make sure there is nothing in front of where the evaporator fan blows air into the fridge. Make sure that the adjuster flap is open in the fridge section.
Oct 31, 2009 | Refrigerators
I have a samsung RS21DCNS fridge but i have jus had apower cut for 10mins and now the fridge is not working. the lights are coming on inside but there is nothing on the contol panel and none of the buttons...
unitl you either cleanr the code or repair the fault that is what you see.the fault is the ice maker sensor is not reading correctly. check the plug connections for the sensor. if you would like you can contact me and i will help you with this problem.
Jan 17, 2009 | Samsung RS2630SH Side by Side Refrigerator
Freezer not freezing, fridge section not cooling
the problem you have sounds like the defrost heater is not being activated causing the evaporator to choke up with ice which will therfore restrict the airflow through the cabinet,
to resolve this problem you are best to defrost the unit and replace the thermal fuse for the heater' and the defrost sensor, both these parts are located behind the evaporator cover inside the freezer.
hope this is of help murdozzz2
Dec 08, 2007 | GE GSS25SGSSS Stainless Steel Side by Side...
Samsung RCS21DCNS Side by Side
probly the evaporator coil in fridge all frozen up you need to pull all the back out inside the fridge section and defrost with air drier
Sep 21, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
172 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
