Question about Palm Tungsten E2 Handheld
Erasing the charging sign
After charging my tungstene2. the charging sign does not go away
  • hunterredfre Jan 08, 2009
    the charging sign is still there.
    President:
  • 2,110 Answers
Press and hold the power button.
While holding the power button, use the tip of the stylus (or a similar object
without a sharp tip) to gently press and release the reset button inside the hole
on the back of your handheld.
Wait for the Palm Powered
logo to appear, and then release the power button.
When you see the message that warns you about erasing all of the info on your
handheld, do one of the following:
• Press Up on the 5-way navigator to finish the reset and show the touchscreen.
Posted on Jan 08, 2009
    President:
  • 1,990 Answers
Welcome to Fixya! Should go away after you Power down then back up. Some have Removable Batteries, If yours does, Remove for 2 Min. after power down then Reinstall and Power On.
  • 3,037 Answers
If you turn if off and then back on or remove the battery and replace it, the sign should go away. Let me know if it doesn't.
You may also need to upgrade the software
bestdarngood
    Genius:
  • 3,422 Answers
HI,
Please reset your tungsten and the issue will be solve.I'll let you know the reset procedure for your model.
  • 1 more comment
  • Priya darshan Jan 08, 2009
    A soft reset tells your handheld to stop what it’s doing and start over again. None of your information will be lost. After a soft reset, a screen appears that lets you reset the date and time, if
    needed.
    To do a soft reset, use the tip of the stylus to gently press the reset button inside the hole on the
    back panel of your handheld.
    If your handheld does not respond after a soft reset, you need to do a hard reset.
    If hard reseting doesn't fix the issue.Try replacing the battery.Remove the battery from the back and reinsert it after 10 min.
    If this doesn't work then do a hard reset but remember you will loose all your data.
    Doing a hard reset
    Only do a hard reset if a soft reset doesn’t solve your problem, or if you want to clear all of your
    information from your handheld.
    A hard reset deletes all records and entries stored on your handheld, including
    the username that identifies the handheld. This is another reason why it's important to
    synchronize often, so you have an up-to-date backup available. Before you do a hard reset, be sure
    to synchronize.
    0
    1 Press and hold the power button.
    2 While holding the power button, use the tip of the stylus (or a similar object
    3 Wait for the Palm Powered™ logo to appear, and then release the power button.
    4 When you see the message that warns you about erasing all of the info on your
    • Press any other button to do a soft reset.
    Done
    Restoring your information after a hard reset
    If you synchronized before doing a hard reset, you can now put that information back on your
    handheld. However, you may need to re-enter some of your personal settings, as well as your
    color-coded categories in Calendar.
    1 Open the Custom menu in the HotSync® application:
    a. Click the HotSync Manager icon in the taskbar in the lower-right corner of
    the screen.
    b. Click Custom.
    2 Select the correct username from the list at the top of the box.
    Continued
    3 Set the transfer options:
    a. Select an application in the
    Conduit list, and then click
    Change.
    b. Select Desktop overwrites
    handheld.
    This change applies
    only to the next synchronization.
    c. Click OK.
    4 Repeat step 3 for the other applications in the list that you want to restore, and
    then click Done.
    5 Synchronize your handheld with your computer.
    Please make sure you try all the steps i have mentioned.This will fix the issue.I have posted then again below:
    A soft reset tells your handheld to stop what it’s doing and start over again. None of your information will be lost. After a soft reset, a screen appears that lets you reset the date and time, if needed.
    To do a soft reset, use the tip of the stylus to gently press the reset button inside the hole on the back panel of your handheld. If your handheld does not respond after a soft reset, you need to do a hard reset.
    Doing a hard reset Only do a hard reset if a soft reset doesn’t solve your problem, or if you want to clear all of your information from your handheld. A hard reset deletes all records and entries stored on your handheld, including the username that identifies the handheld. This is another reason why it's important to synchronize often, so you have an up-to-date backup available. Before you do a hard reset, be sure to synchronize. 0 1 Press and hold the power button. 2 While holding the power button, use the tip of the stylus (or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your handheld. 3 Wait for the Palm Powered™ logo to appear, and then release the power button. 4 When you see the message that warns you about erasing all of the info on your handheld, do one of the following: • Press Up on the 5-way navigator to finish the reset and show the touchscreen. • Press any other button to do a soft reset. Done
    Restoring your information after a hard reset If you synchronized before doing a hard reset, you can now put that information back on your handheld. However, you may need to re-enter some of your personal settings, as well as your color-coded categories in Calendar.
    1 Open the Custom menu in the HotSync® application: a. Click the HotSync Manager icon in the taskbar in the lower-right corner of the screen. b. Click Custom. 2 Select the correct username from the list at the top of the box. Continued
    3 Set the transfer options: a. Select an application in the Conduit list, and then click Change. b. Select Desktop overwrites handheld. This change applies only to the next synchronization. c. Click OK. 4 Repeat step 3 for the other applications in the list that you want to restore, and then click Done. 5 Synchronize your handheld with your computer.
G11 won't start
I would suggest that before you send it in for a repair, check the terminals on the battery and the camera. Take a normal pencil eraser and gently rub the battery terminals to get any dirt or grease off of it. Then blow away any eraser residue. Using the pencil eraser again, reach in and again rub the terminals in the camera. Blow away any residue. That failing, yes, it's needing repair
Jul 10, 2014 | Cameras
My palm pixi wont let me add contacts to my phone. New or add to existing
Bring up your contacts card, change the preferences 'default account' to whatever else you have there (just check it -google, etc) then back to Palm Profile, then throw card away.. should work after that. But know, that it'll probably still happen intermittently. Best thing is to do a backup (BACKUP icon in your Launcher menu - just so you're current) then do a FULL ERASE. DEVICE INFO icon in your Launcher and follow directions for a FULL ERASE. Then when your phone reboots, it'll ask to sign in to your palm profile to get all of your data back. If you have pics, etc, they will be erased so if you need them, hook your phone to your computer and drag anything you might need before you do the Full Erase.
Feb 07, 2011 | Palm Pixi Cell Phone
I just lost my iphone and i have information that can change my life forever is their away that the phone can erase information
Unfortunately, you have to have the iPhone in you possesion to erase it. It cannot be done remotely. I woould post a reward for it's return. Call AT&T to put that account on hold or cancel, so that you don't get hit with outrages charges.
Sep 25, 2009 | Apple iPhone Smartphone
Print quality on Lexmark T640
There are 2 likely possibilities:
1. Very dark print usually indicates your charge roller is not removing the charge from the drum.
The charge roller "erases" the charge laid down by the laser from the previous pass and prepares it for the next portion of the image. If not erased or has a latent charge it will pull toner onto the drum. Try changing the charge roller . 2. Your wiper blade in the cartridge may not be properly wiping excess toner. Swap the toner cartridge with another and see if the problem goes away.
There is a video here you can watch on changing the charge roller:
http://www.fastprinters.com/TechSupport_repair_parts.asp#T640VIDEO
Mar 24, 2009 | Lexmark T640 Laser Printer
Palm tungstene2 hand held
You will need to do a hard reset...this will wipe all the data on your unit, setting it back to factory specs...be sure this is what you want to do...
1...While holding the power button, use the tip of the stylus (or a similar object
2... Wait for the Palm Powered™ logo to appear, and then release the power button.
3... When you see the message that warns you about erasing all of the info on your
Jan 30, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Palm tungstene2 #
You will have to do a hard reset...this will set it back to factory specs...you will loose any data that you have added to it...So be sure you absolutely cannot remember the password before you do this...
Tungstene2 erasing charging sign
i performed a hard reset,and i still have the same problem plus now i have a touch screen problem.i cleared all information,and when i
touch the screen colors run across the screen.i hope you can help me.the screen is very erratic to touch.some times it work,and some times it don,t.
Jan 08, 2009 | Palm Tungsten E2 Handheld
Memopad backup
Make sure memos are checked in transfer data
Jul 18, 2008 | Palm Tungsten E Handheld
Palm Tungsten E2 Handheld Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
