Nokia 6300 Cellular Phone Logo
Posted on Apr 29, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nokia 6300 wont turn on
I dropped my nokia 6300 phone this afternoon, when i checked it right away, it was still perfectly functioning...
but when i lost battery charge and tried to charge it, it refuses to turn on already...
ps. around the time that it was out of charge, i tried to turn it on to check on my messages quickly i got to read a couple of messages, but it turned off again after about 10 seconds... but after that, as mentioned, it wont turn on anymore,,, even if it was connected to the charger,
what can i do? can you help me? thanks
Computer Repairing
Level 3:
  • Nokia Master 14,641 Answers
  • Posted on Jul 07, 2017
Computer Repairing
Nokia Master
Level 3:
Answers
14641
Questions
0
Helped
718136
Points
53082
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
5 Related Answers
Anonymous
  • 8 Answers
  • Posted on Feb 18, 2008
SOURCE: Nokia 6300 wont power on
check on that battery connector isnt damaged it looks like you middle pad BSI line its not connected properly
Anonymous
  • 283 Answers
  • Posted on Apr 17, 2008
SOURCE: nokia 2610 wont switch on
u've gotta go to your nearest center to fix your firmware... your program was corrupted and to fix that need the software for flashing your fone
Anonymous
  • 218 Answers
  • Posted on May 18, 2008
SOURCE: I can't turn on my phone ><
remove its memory card and then try switching it on
Anonymous
  • 39 Answers
  • Posted on Aug 28, 2008
SOURCE: NOKIA 6600 wont charge and turn on
hey,
how about check your charger .. maybe there is a problem with your charger... try another nokia charger
Cheers
Anonymous
  • 5 Answers
  • Posted on Mar 21, 2009
SOURCE: my nokia 6280 is not keeping gharge and is refusing to charge
1-Try another trusted genuine battery.
2- Try another trusted genuine charger.
3- If RETU IC is not under-filled try yo reflow it, if not works then replace it.
4- No way but to try replacing TAHVO IC even if it's under-filled (if you really want to solve the problem) ;) .
maybe ur bsi line short to ground!!
try to remove the resistor in bsi line....
1helpful
there is bettewry problem and also check ur charger problem..if there is no image on turn on then u have to change the LCD of mobile..but this model always has less timing of bettry
Nokia 6300 on off switch problem
the switch button is or maybe broken
the best way is to send it right away to the nearest service center
Nokia 6300 turning its self off and shutting its self down
the switch off button of your phone has stuck in pressed position try to release it or go to any nokia repair shop they will repair it for free
pls rate me
thankyou
2answers
6300
Try removing the sim and memory cards then try to switch it on, whilst the charger is plugged in. If it still fails then it does need to go away for repair.
1helpful
2answers
Phone dropped accidentally
please give me nokia 6300 mic diagram...
Nokia 6300
when i turned the tone set up for the profile of my china nokia phone (6300) it turned off and my tone set up is not functioning. but other programs are all doing fine. what will i do?
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
