Question about Tappan TGF657 Gas Kitchen Range
Oven door tappan gas oven model no 30-4979-23/01201-ser. no 89303418.i would like to remove the oven door but do not see how to lock the hinges not like any that i have seen.stove is late 80's
Replaced oven igniter without removing oven door
Posted on Jan 10, 2009
How do I get my kelvinator stove's P 12 front door back
Without more information I can't be sure of your problem but I will make a guess that you removed the door without engaging the hinge locks. I am attaching a video that may help. All oven door hinges are not the same. Some require you to insert a screwdriver or pin in a hole to stop the hinge from retracting. My own oven door has retainers that snap onto the slot just above the hinge. When you remove the door these pieces are used to hold the hinge in the open position.
If the hinges are in the closed position you will have to figure out how to open them and hold them in the open position. Be Careful. The springs are very strong and can hurt you. I am including a link to a youtube video that may be the same as your oven door.
This free troubleshooting video shows step-by-step instructions on replacing the oven door hinge on Frigidaire, Electrolux, Gibson, Kelvinator, Tappan, and Kenmore gas ranges.
Door Hinge Replacement part 316456302 Frigidaire Gas Range Repair
Aug 15, 2014 | Kitchen Ranges
Oven door spring model av 669 26a
MFG Part Number:WB9K4 if spring is red -MFG Number WB9K5 if spring is black with a spot of blue paint. To access the spring remove the storage drawer. One end attaches to the hinge the other to a slotted hook. Check the opp. side spring to see how it is hooked up.
Feb 05, 2013 | Tappan TGF364AS Gas Kitchen Range
Tappan gas range oven door hinge is binding
What is the model number of the unit?
Nov 29, 2012 | Kitchen Ranges
How to remove a Maytag gas stove oven door (Maytag Model # MGR5755Qwd)
Hi.
Before removing the door you need to release the lock on the oven door hinges. Door hinge locks are slide mechanisms or pins located on top of the hinges Once lock is released you will be able to pull out the door by opening it a bit, then lifting it up and pulling out.
Here parts and diagrams for your oven: MGR5755QDW.
Regards.
Ginko
Sep 09, 2011 | Maytag MGR5755QD CleanDesign Gas Kitchen...
Oven door will not close all the way. 6" gap at the top. No problems until last use and now won't close. Any hints on how to proceed would be appreciated. Thank you!
Most oven doors are held in place by two hinges at the bottom. Usually these hinges are not attached but hook into the oven.
Sounds like you need to readjust one or both of the hinges.
Usually can be done by pulling up on the door and pushing the bottom of the door in.
Write back if you have more problems.
Dec 02, 2009 | Tappan TGF320 Gas Kitchen Range
I have a Frigidaire Gallery Oven Professional Series, I don't have the model number. In trying to self clean my oven, I accidentally pressed something that engaged the oven door lock. Now I can't close...
If your oven door has gotten bent or warped (maybe you rested something heavy on it…), you need to remove the door, disassemble it, and straighten it. You can lift most oven doors off of their hinges by opening the door several inches to its first "stop," and lifting the entire door straight up.
If the hinges have become worn, damaged, or bent, you probably need to replace them. I recommend replacing both hinges at the same time, to prevent uneven wear of the undamaged hinge.
Sep 04, 2009 | Ovens
Model number mgr5775qdb. someone removed the oven
If there is a hole in the metal hinge near the base; put a nail in the hole to keep the hinge from closing until you get the door in place and then remove the nail.
Sep 03, 2009 | Maytag MGR5775QD Gas Kitchen Range
Tappan wall ovens doors nneds replaceing. This is a gas wall oven. I notice the spring one one side came ouy. Any solution.s
Hi, With the model #, I could get you the info on the part# and how to change them springs and maybe=y hinges.
Please let me know
Thanks
Vic
May 11, 2009 | Ovens
Stove window cleaning
refer to your use and care manual as to howe to remove your door assy, generall its open door fully and "lock " the hinges\( pull tabs on bothhingestha alloy you to "lock" thehing and upn lockking you lift the door rigth off then its a matter of removing the frame holding the glass, do it slowly and carefully the galls will coe of, clean it and revers the procedure to reinstall the door
Sep 27, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan TGF657 Gas Kitchen Range Logo
551 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
