Question about Maytag PYE2300AY Electric Dryer
Motor smells on model lde7314ace
Got machine for free owner said it made noise, i never tried it, tore apart one of the drum wheels broken, but now iam in the dryer and took everything out the moter smells alittle , what do you think is there a way too test it .do you think its burned up? thanks
  • dbartels Mar 22, 2009
    how do it take apart my maytag model #PYE2300AYW to check the belt since the dryer wont spin
  • 333 Answers
If the motor smell burnt it is going to burn up soon. Unfortunatly it is time to replace the motor if it is worth it. You may consider a new one. Once the motor goes you can guarante that something else will follow.
Posted on Jan 08, 2009
Won't Spin Drum
The problem could be a list of things . Let's start checking the belt , it coul be that the belt is broken or something is keeping it from doing its job ( a piece of clothing coul be stuck) due to the burned rubber smell you detected. It coul also be the electrical door switch and After checking the three first steps then comes the motor part lets hope is not . Good luck
Nov 20, 2013 | Maytag Centennial Series MEDC300XW
We have a MMDE9206AYM model dryer that makes a low humming sound but will not start. Last night it also produced a burning smell. I assume either the belt is gone or the motor is overheating although it...
Sounds like drum is locked and motor is running and burned the belt. Try to spin drum by hand, Might check drum ends felt seals, Teflon bearing strips located on the bottom lip of front drum end for wear causing drag. Also check 2 drum support wheels to see if they spin freely, take the belt off motor pulley and spin drum by hand, if easier & motor runs drum is dragging. How is the spring on tensioner, does tensioner pulley spin free? Hope this helps locate the problem.
Feb 13, 2011 | Maytag Dryers
Squeaky sound but still drying, Kenmore stack washer/dryer, 4 years old.
Typically, the dryer drum is driven by a motor and a large belt that wraps around the back of the dryer drum and is quided by 3 or 4 wheels on the front of the drum. I'm betting the sound is cyclical. If you want to go throught the trouble of pulling the dryer apart (and it's not all that bad) check the wheel to see if any are wobbly. You could also try a little shot of sewing machine oil on the wheel axels. (WD40 has a smell to it so I might not be inclined to use that.) If the sound goes away, plan on replacing the wheels.
Feb 19, 2010 | Kenmore Dryers
Drum rotates and then motor locks up. Burning smell comes from machine with continued operation. Drum rotates free by hand. Drive problem or motor?
replace your belt ... the motor does not smell like burning rubber, the belt will exzude that odor.
Pop the top ... remove the front ... use care with the door switch wires.
the drum will come free of the unit.
Put the new belt over the drum, through the tensioner on the bottom, around the motor pulley.
You will need help ... put the drum back on the wheels inthe back and replace the front ... snap the top down
while it is apart, clean the exhaust system completely
Nov 02, 2009 | LG WM0642H Front Load
The Maytag washer doesn't spin and had a burning rubber smell. Motor operates, but the drum does not spin. Belts have slack, motor pulley show evidence of belt turning which caused the burning rubber...
You should have a tensioner pully (a small wheel on a piece of spring steel) that hold the belt tight.
If that spring steel is broken or weak, then you will have to take the broken one to your local appliance repair parts shop and obtain a new one.
That should keep the belt tight and keep the drum spinning.... -Jim
Oct 23, 2009 | Washing Machines
My dryer stopped spinning and its making a terrible noise/smell
Sounds like you have a broken belt.
If you have to replace your drum belt and if you have a front loading machine.
First you will need to unplug your dryer from the electric.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
The smell your smelling is probably from the heating coil not getting air over it to send to the drum to dry your clothes, this should go away after you replace the belt and get the blower to turn again.
Good luck,
I hope this helps
Oct 08, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer stopped in mid cycle, didn't smell anything, it just stopped. opened and closed the door and tried the start button again and it still wouldn't turn on
Sounds like your problem may be a broken belt.
If the problem is not a broken belt then you have to motor exposed to do further testing, if the motor is ok, then check the start switch and the timer switch
Good luck,
I hope this helps
Oct 08, 2009 | Whirlpool Dryers
Motor Pulley Squeeling - Maytag MDG5500AWW
try spraying wd 40 on the motor ends to see if it will stop if not try the rollers normally they go bad and make the belt squeel.
Jun 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Tub cracked on my Fridgidaire front loading washing machine
sorry no recalls on fridgidaire front load,,there pretty good units,,the mildew and slugg comes from not using he or low suddsing detergent..now dont move so fast ,,because a new spin basket may not solve your problems with noise..check that back tub bearing while you have it a part..now that unit is fresh and new ,,clean the unit every other month with bleach..hot wash cold rinse,,that will keep suds slug and smell out unit...onthejob
Feb 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Maytag PYE2300AY Electric Dryer Logo
158 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
