Question about Sharp FO 5700 Plain Paper Laser Fax
Sharp F0-5700 Fax No Paper (Tray)
No Paper (Tray).
I checked under the machine but I'm not sure where I'm looking.
Go underneath the machine and make sure that a black piece of plastic is secured in there. Sometimes they get pulled out when the tray gets removed.
Directly above the paper tray is a little "arm" type black wheelie thing...One the left rear corner is a lightweight black plastic rectangle cover....what black piece of plastic am I looking for exactly where?
  • 1 more comment
  • dragonmouse Jan 08, 2009
    Well I just went and did that and it appears to be in place. I just sent a fax to it and somehow it found paper to print the fax but the light and error is still there.
    Thank you for your help. I guess I'll learn to live with the error as long as it keeps working. Unless you can think of anything else.
  • dragonmouse Jan 09, 2009
    Re: Do we receive faxes on Legal sized paper...
    Not that I know of. When I left yesterday I started wondering if the silly thing thinks there's supposed to be a second paper tray attached..
    That has to be it. The tray that is in there does not do legal so there's no way to switch it and I don't know of the machine ever having a legal tray. But I had something like this happen to a printer sometime ago.
    The weird thing is that it sends, receives and prints faxes fine.
  • Sharp Master
  • 2,794 Answers
Remove the tray out of the copier and look for one next to the feed tires.
Posted on Jan 08, 2009
  • 1 more comment
  • Tim Babcock
    Tim Babcock Jan 09, 2009
    Do you get faxes from time to time that could be received on legal size paper?
  • Tim Babcock
    If there was another tray with legal paper it will switch. If someone sends you a fax on legal and you have letter in the tray, then it will cause that error to happen. You could switch the paper and see if it still happens.
  • Tim Babcock
    You should be able to install legal paper into it by changing the rear paper guide.
I have a SHARP UX178 fax machine that displays all the time the message out of paper but the roll paper is corectly installed. Ther is a sensor or a contact that has to be checked? Thank you
yes there is a sensor or a switch
when you slide the paper under the roll in the middle you should see the switch ot sensor some models have the sensor maybe on the right or left kyou need to look for the sensor or switch
hope it will help
Oct 11, 2010 | Sharp UX 108 Roll paper Thermal Fax
Screen says film at end- it's half full
Issue with Sensor...Take Off Thermic Paper and check for swich..and take off paper jam on the tray put back paper, turn off then turn on unit Check for menu setup for utility Check Date & Time set unit first also check if you battery memory is on good condition if so check on the front cover for inside battery or under
Sep 30, 2010 | Sharp UX 510 Plain Paper Thermal transfer...
I have the same problem; every 2nd page is blank
sounds like the seperation roller in the paper tray is worn .. this roller is there to stop multiple feeds or it may have a pad in your tray open the paper tray up and look at the roller in the tray or the pad ; and give it a clean with a damp cloth.. also check the paper if it has been in the tray over the weekend when not used sometimes they pick up cold or dampness and so the paper sticks to the top sheet.. Im thinking more on the lines of the sepertion roller/pad area.. Goood luck A
Jul 20, 2009 | Sharp UX P200 Plain Paper Thermal transfer...
A friend gave me this fax machiene. On the screen it sais "out of paper" when there is clearly a lot of paper in the bottom tray. However it is missing the top paper tray but has the lower tray. Could
Make sure you have a receiving tray. You can live without your sending tray. If you have the receiving tray and it says TRAY OFF thats because its not seated properly onto the frame. Make sure the tray engages the black sensor next to the speaker, also make sure you have paper in both trays to get rid of the OUT OF PAPER error. If the OUT OF PAPER error continues then you have a broken sensor in the upper tray.
May 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Sharp FO 6700 Plain Paper Laser Fax
No there is no configuration page. The red blinking light means you have no paper under your blue tray or the paper empty sensor is broke. To identify the noise open the lid then close it, if you hear the noise while the fax is warming up then most likely you have a bad gear that meshes with the fuser drive gear, although it could also be the toner or drum. If it's not the toner or drum I stongly recommend a service technician , he should be able to provide an exit tray.
Oct 05, 2008 | Sharp FO 6700 Plain Paper Laser Fax
I cant recive any fax
Sometimes the plain paper in the tray underneath upsets the whole machine.
Open up the top of the machine, as if you were going to change the toner cartridge. Pull out the cartridge carefully to mae sure that there is not a piece of paper jameed underneath. Replace the catridge and close the top of the machine. when you close the top 'door' the machine will make a noise as if it is resetting itself - the 'jam' display may or may not clear at this point. Next, pull out the paper tray. You will need to stoop down to look into the gap where the tray normally sits. If there is a piece of paper jammed at the back this will need to be carefully removed. If you pull it out make sure there a re no fragments left int he machine - you can check this by oepning out the piece of paper removed and see if there are any pieces missing.
Finally, if all is clear, replace the paper tray (it would be worth topping up your supply of paper as the 'jam' message sometimes comes up when the machine has a low paper supply.
Hope this helps.
Sep 08, 2008 | Canon FAX-L350 Plain Paper Laser
Error message
when you look at the front of the fax. above the paper cassette there is a gray,blue cover where the paper comes out when receiving or coping , that cover needs to be seated properly there is a mag switch that will shout down machine till it is in place.
Never have I seen this sensore go oit just the cover is out of position,
hope all will be OK
Jul 23, 2008 | Sharp FO 5700 Plain Paper Laser Fax
Message that tray is out of paper, and tray is not in machine.(SHARP FO-5700 Fax)
Jul 01, 2008 | Sharp FO 5700 Plain Paper Laser Fax
I get a "document jammed" message.
1-there is probably a piece of paper on a sensor
2- a sensor is bad
try to locate the sensors and look carefully
there should be no more than three on this model
1-in the paper tray so it knows there is paper in the tray
2-under the drum/toner cartridge and on in the fuser
Jan 24, 2008 | Sharp UX 300 Plain Paper Thermal transfer...
Fax Machine Jams Everytime I Try to Load Paper...
Is it jamming at the document feeder, or in the blank paper tray? You may need to clean the feed rollers. Use a lint-free cloth (not paper) and some alcohol.
Dec 27, 2006 | Sharp UX-B20 Plain Paper Inkjet Fax
Sharp FO 5700 Plain Paper Laser Fax Logo
391 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
