Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer ghw9250 tub bearing
I need instructions on how to r&r this part. I have the part and wish to make this repair myself.
  • onthethejob1
    onthethejob1 May 11, 2010
    whats the part ????
  • 213 Answers
SOURCE: whirlpool duet sport front load washer
the panel below the door has 3 screws under the bottom lip of the panel. remove the screws to get the panel off youll see the pump right in front of you. you can unscrew the cap on the pump and remove it to clean out the punp. thats where 99% of clogges are on that washer
Posted on Nov 26, 2007
  • 7 Answers
SOURCE: Maytag MAV7200 Washer......needs seal and bearing kit
it was making a loud noise during sin cycle, like a bad bearing would
make, jet engine kind of noise, i did replace the bearing and made a web
site with pictures on how to do it, since it almost takes all the parts
out, it will show you how to get to most of the parts in the machine, and
i also included links for downloading the repair manual, and parts at
appliance parts pros web site
Posted on Apr 11, 2008
  • 291 Answers
SOURCE: a marble or a bearing is rolling behind the drum
The lowes salesperson is wrong ,,, it wont destroy anything it will just be bad noise till it falls into the lower tub and then into the pump filter where you can unscrew the cap on the pump and take it out ,,, to get it out b4 then you have to pull the top, outer panel then get to the tub and on that style you have to take the complete tub out and take it apart to remove it and then replace the spit seal and reinstall ,,, it would cost anywhere from 300-400.00 to remove the marble so best best is to let it go thru its course till it drops out / i have done the repairs on those machines so i know what it would take to do it ,,,,, sorry but thats the best and cheapest / larryyb
Posted on Dec 09, 2008
  • 3 Answers
SOURCE: Whirlpool Duet Washer (GWH9100LW1) Bangs Loudly during spin
I have a Kenmore which is the same as the Whirlpool. I dismantled the unit, it was only 3 years as Sears stated its was not under warranty. Upon review the stainless steel tub tripod assembly which is connected to the flywheel was cracked in three places which caused the knocking and vibration. Even though the warranty states lifetime on the Stainless steel drum, there is a ploy on words as the failure was not the stainless steel, so these machines are good for the scrap heap as the cost to replace the parts is more expensive than a new washer.
Posted on Apr 14, 2009
  • 15935 Answers
SOURCE: how can I repair code F24 on whirlpool duet sport ...
This advice is for Whirlpool Duet and Kenmore Elite model FRONT LOADERS displaying the "F24" Error Code. Some of the error codes on these model washers can be erroneous, however. The first step in troubleshooting any error code is to simply unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of the washing machine. If the error code reappears following a CCU reset, then you have a genuine problem.
"F24" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor.
To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a 2 x 4 under the front feet of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Make sure this plug is secure and not loose or unplugged. It is common for the connector plug to come loose due to vibration. If the plug is intact, check the contacts for corrosion. If everything appears as it should, then unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&&
Posted on Sep 28, 2010
Whirlpool duet ghw9250 smells like burning rubber and very loud
Does the drum turn, if not then the drum bearings may have siezed.
Dec 30, 2012 | Whirlpool Washing Machines
We have a Whirlpool Duet WFW9400SW02 that is making loud noise during the high speed spin cycles. It is only 13 mos old. Whirlpool will not even stand behind the parts. The repair person estimates over...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
Feb 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer making loud noise when spinning
It sounds like you need a bearing job. The bearings in the back half of the wash tub go bad. and the washer gets loud .It's an expensive repair. I hope this helps
Jul 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool duet sport front-loading washer that is about 4 years old that is now making a squeaking/ticking or slight scraping sound when the tub turns. Even when I turn the tub when empty I can...
before calling any repair man,
take a flashlight and carefully inspect tthe inner tub
on a few service calls with this particular complaint
ive found small nails, taks, penny nails, screws, what have you that fell into one of the holes and got stuck
barring that , i would get your bearrings checked yes
at four years you should still be inside your part warrenty if it needs to be replaced
Oct 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet washer makes a horrible noise during the spin cycle. It looks like the drum is out of balance and wobbling. I have checked all 3 of the counter balances and they are intact. I have also...
One of the arm supports on your inner spin basket has broken in the back of the wash tub. You can easily determine this by reaching inside the tub and placing your hand at the 12 o'clock position. Push up and release. If there is any play in the basket, the rear support is broken. Depending on how long this problem has been occuring, will also determine whether or not you need to replace the tub shells as well. The only way to know is to disassemble and inspect.
This has been a noted problem with some Kenmore and Whirlpool model washers. Unfortunately, its not an easy problem to fix, and its not cheap in most cases. I have instructions on how to perform this repair if you wish to attempt this yourself. If you have a service contract, maintenance agreement or warranty, you may want to pursue those options first.
Let me know what you decide.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150W0 Washer - Stainless Steel Washer Bin Arms Broken
Jun 07, 2009 | Whirlpool GHW9150 Duet Washer
Whirlpool ghw9100lw2 bearing repair
It is not a hard job to replace the tub. Just time consuming. I replaced the back portion of the tub where the bearing is. If the inner tub shaft has any wear on it , replace that as well. Otherwise youll have the same problem in a month. Its an easy fix if your patient. I paid about $130.00 for the rear portion of the tub. I'm not sure about the inner tub.
Mar 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
how old iss your washer? do you have an owners manual. because usually there is an extended factory warrenty on the tub and basket. the only thing you would have to pay for would be the labor. Call whirlpool if you do not have a owners manual to find out. the bearing is compressed in the tub. does it sound like an airplain taking off in your house that's usually it.
Jan 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Nylon or plastic bushing around tub breaking down
sounds like you have abadrear bearing, not cost effective to repair by you, parts have a 5-10 yrs warr, you would need to check your manual, usuallt wind up replacing, the rear drum, inner basket, without warr theese parts are probalby 650 dollars. so i would call an authorized servicer(whirlpool wont send you parts even though they're warr)
Apr 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
483 people viewed this question
Dan Webster
Dan Webster
Sal De
