Question about GE Dryers
Automatic dry feature of electric dryerr does not work
I have a GE DS4500EA1WW electric dryer and the Automatic dry selection causes the dryer to run forever. What is the controlling sensor and do you have the part number?
Thank You
    Sergeant:
    Champion:
  • 262 Answers
Chances are you have lint on the sensor look inside the dryer in the front just in side the door you will see three or four silver wires about flush with the front housing wipe the off and try it if this fails contact a local appliance parts store with your model number and they can get the part num for it
good luck
bill
Posted on Jan 08, 2009
How many cubic feet are in GE electric dryer model DHDSR46EE1WW?
Features
  • 7.0 cu. ft. super capacity
    Handles large-size items and family-size loads
  • Auto Dry
    Uses thermostats to monitor air temperature and reduce fabric wear
  • Dura Drum interior
    Provides long-lasting dependability
  • Four heat selections
    Provide the right temperature for the right drying results
  • Interior dryer light
    Lets you see everything inside for easy loading and unloading
Sep 13, 2015 | GE Dryers
Electric GE harmony dryer runs but will not dry. Do these newer models not have heating elements? if not what has gone wrong with it?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 19, 2010 | GE Profile Harmony DPGT750EC Electric...
My GE dryer has no heat but runs. Also when you put the setting on more dry or less dry the dryer will run for hours, but will run the correct time on the timed dry setting. Either way the dryer will not...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Oct 07, 2010 | GE DBXR463EDWW Electric Dryer
I have GE dbl33eb4ww dyer that wont get clothes dry till you run them through about trhee or four times
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 19, 2010 | GE DBL333EA Electric Dryer
Problem with Dryer Timer or heating element
The heat cycle must be working for the timer to advance in the Auto Dry setting.
Your heating element and or high limit thermostat is bad.
We need a complete model number to be more specific.
May 31, 2010 | Kenmore 600 6965 Electric Dryer
No heat during either drying cycle automatic
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
heatman101
Feb 15, 2010 | GE DVLR223 Dryers
GE Profile dryer - automatic dry never stops
ok go back to that page and
look in the
backsplash, blower section
you are looking for part
230
Oct 15, 2009 | Dryers
GE Profile Dryer - sensor problem
When I pull up the exploded view of your model, it does not show an individual moisture sensor, but is does show disconnect plug(s) for it. I can only assume that the sensor bars are an intrical part of one of the front bulkhead components. That all being said, the most common reason for your symptoms is when people use fabric softener sheets in the dryer, the sheets leave a waxy type coating on the silver sensor bars inside the drum, near the air inlet to the lint filter. If you clean those two (usually about 4 inch long x about 1/4 inch wide) metal bars off, they will be able to detect the moisture level of the clothing again, and your dryer will work on auto dry again.
Jan 24, 2009 | GE Profile DPSB620ECWW Electric Dryer
GE Electric Dryers Automatic Cycle won't advance/turn off
check the vent probly cloged or vent hose kinked, or heater is broken.
Dec 21, 2008 | GE DPSR610GGWT Dryer
Timer only works on Timed Dry Setting
Check your heating element. If one coil of the heating element is burnt out the dryer will heat on the remaining coil, but the timer will not advance in automatic dry.
Nov 13, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
152 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
