Casio WK 3200 keyboard makes funny noise
Casio wk3200 keyboard makes a sound like a space alien ray gun whenever a key is played and none of the functions change when attempted. I don't know how to "reset" the keyboard to possibly correct the problem.
Removed batteries, reinstalled them, resetting keyboard, problem solved
Posted on Jan 09, 2009
How to reset factory defaults for a Casio WK-8000 keyboard
1. Press the Transpose/Function button
2. Cursor down 3 times to "Init Mix"
3. Cursor right to "Init Sys"
4. Press Yes twice
5. When it says "Please Wait", don't press any keys
6. After that, press Exit once and it's ready to go
http://www.sweetwater.com/sweetcare/articles/reset-casio-wk3000-factory-defaults-hard-reset
Please rate my answer, Thank you.
Aug 05, 2014 | Casio KEYBOARD WK-8000
Hi, i have a problem with my casio wk 210 keyboard. when i push a key then the note keeps playing and doesn't stop. i have tried turning off the power and turning off reverb and none of them fix the...
It sounds like the sustain is stuck on as if a sustain pedal is active. You don't mention if you have one, however if you MIGHT have one and you have used a Roland pedal, that brand is reverse sensed and would cause note to remain on.
Jun 14, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
One of my keyboard black keys is playing louder than usual what can i do?
One of the two contacts of that key is dirty. This cause the key velocity to be read as maximum making it loud. The keyboard contacts are conductive rubber pills that press across circuit traces on a board under the keys. CLean the pills and the traces GENTLY with ONLY 99% isoprophyl alcohol and Q tips. Getting at the contacts requires a lot of careful disassembly of the keyboard to get at the contacts.
Apr 06, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
Re: Casio WK-210. Audacity, Jet Audio and Ctrl Pnl allow me to choose a USB PnP "record from" option, however, no sound is being recorded from the Casio to the PC. What am I doing wrong. Many...
Pat, the USB output on the Casio WK-210 is only capable of sending and receiving MIDI information. It's not sending any digital or analog audio. Audacity is primarily for sound file editing.
In order to use the keyboard to record onto your computer you can connect an audio cable from the 1/8" stereo mini-jack to an input on your computer. Then you can record into Audacity.
Or you can acquire MIDI recording software (ie. Logic, Cubase) and then using the USB output on the keyboard, you can control and record multiple MIDI instruments in those programs.
Feb 23, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
Faulty key on digital piano
If it is brand-new, then take it back, and exercise the "warranty" to get it fixed at NO CHARGE to you.
May 29, 2010 | Casio KEYBOARD WK-8000
My WK- 3700 Casio keyboard is malfunctioning.
One portion of the key scanning matrix has gone bad. First thing is to clean the contacts with 99% isoprophyl alcohol. These USUALLY consist of traces on a circuit board that conductive rubber "pills" under silicone rubber domes are pressed down. Each note usually has two contacts, one closes before the other. This creates "velocity" measurement for the key. IF ONE of the contacts for a key doesn't work, the velocity can detect that the note has actuated, but no release occurs.
This would be on the "STROBE" line for either the first or second contact for THE OCTAVE you have problem with. There are disconnect diodes that prevent sneak paths.
You could have one bad diode, a crack in the circuit board, or a bad connection to the keyswitch board.
Nov 21, 2009 | Casio Music
I fixed the dead keys on my Casio WK-200 keyboard. Now some...
Most of these have VELOCITY sensing and that involves two contacts per note. If the velocity sense on those notes is somehow not working, broken wire or trace on the board or short that MIGHT cause your problem.
Aug 12, 2009 | Casio Music
Need a manual for casio wk 110
Why not download it?
http://www.generalmanual.com/Musical-Instruments/Casio-WK-110-Portable-Keyboard.htm
There;s a link on that page.
All you need to do is google the words
casio wk 110 manual
And you find your answer,
Hope that helps you.
Apr 25, 2009 | Casio WK110 Portable Keyboard
SMF converter for wk-500, Does it exist?
No.
I have a Wk-8000 & a CDP-200R, the later is the same as wk-500 but with 88 weighted hammer keys.
Since wk-500 can play SMF (Midi 0 & 1) format directly from a SD card and there is enough polyphony to play anything, I don't find any real reason to convert SMF to any "Casio Format". Just get a 2GB SD card and put your SMF files in the MUSDAT folder for the SD CARD using your PC/MAC.
Dec 31, 2008 | Casio Lighted Keyboard LK90STADMC
455 people viewed this question
 Grubhead
Grubhead
