Question about Hyundai ImageQuest L70S 17" LCD Monitor
I have a Hyundai Image Quest L70S, the screen goes blank
I have a Hyundai Image Quest L70S, when I press the on button the screen will display for about 1 second and then goes blank. I have rebooted the computer and the screen will flash on and then go blank. I have unplugged the monitor (for 2 hours) and still get the same results.
  • Waynet2 Jan 22, 2009
    The backlight inverter is bad. I received two Hyundai L70s monitors in the same condition from my employer and I've disassembled one of them. Unfortunately, the inverter is built into the power supply board and I haven't been able to find a source for the board online. I'm wondering if I might be able to figure out what component(s) is/are bad. The board has a large 68uf 400V capacitor that seems to show open on my multimeter no matter how I read it. On a Sceptre 15" I have (which has a different power supply issue), the same 68uf capacitor reads an incrementing value in OHMs and a decrementing value in VOLTs (which I understand is supposed to be normal).
Hello, mine lcd it is extinguished continually. I have tried to open it and seems us or a problem on a condenser dell' inverter. Someone you would know dirmi where to find the outline in order to understand like repairing it?
Posted on Jan 31, 2009
No image when power is on
Find this button...... '[]' . Each time you press this (Display/LCD
on/off). Your LCD display in in off mode. Press the button until the screen is on.
Hope this helps
Sep 24, 2014 | Sony Cyber-Shot DSC-S40 Digital Camera
I am using the Hyundai Image Question L70s and I
Push F8 while it boots up. With safe mode change resolution of the screen. Reboot to hopefully see the screen. Next time you change the resolution of the screen if you cannot see the screen do not touch it. The computer puts up a question, can you see this. With a blank screen, you just wait and the screen returns back. If you can see it then accept the question.
Sep 08, 2017 | Computers & Internet
Power button flickers green and no display
It can be that it is not getting the signal from the PC, or it detects short circuits so it goes into shutdown and try to restart, or failed power supply due to bad caps. Try it on another PC and also check the VGA cable first. If it still does not work and you want to DIY repair, then please read below and look at alot of pictures so you will know what to look for inside.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 12, 2010 | Hyundai ImageQuest L70S 17" LCD Monitor
Have 10 Broken monitors with simalar problems. 1. Dell e153FPB- Video for 2 seconds than screen goes blank. 2. Dell e153FPB- After 20 mins, Display stops working. 3.Dell e1724FPB-Video for 2 Seconds than...
Pleasec look through my albums so you will know what to look for.
Dell bd: http://www.lcdrepair.us
Apr 24, 2010 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Power on Green Light Blinks but no picture. Will not turn on. Hyundai Image Quest L705
bwpvemail, The units "switch-mode-power-supply" may be in shutdown mode. A tech will need to evaluate. Check to see if Hyundai has a refurbished swapout+cash program?? It's that or trade in for new wide screen, so the tech in the store "back-room" can possibly put $8 in new filter capacitors in your unit and with a little luck will have a 17" L70s for 1-2 more years use. 12fixlouie
Dec 08, 2009 | Hyundai ImageQuest L70S 17" LCD Monitor
Screen flashes every 3 seconds
I have a plug that sits between the two coil packs and I do not know where it goes, please help
Nov 02, 2009 | Hyundai ImageQuest L70S 17" LCD Monitor
L70S Issue
Not sure if this helps but run my computer in safe mode and do a virus scan. This worked well for me, hope it helps.
Oct 12, 2008 | Hyundai ImageQuest L70S 17" LCD Monitor
Words are not clear
if its a crt monitor dump it,if its a lcd monitor try changing your screen resolution from display properties,or on the monitor check the brightness and contrast controls.
Dec 26, 2007 | Hyundai ImageQuest L70S 17" LCD Monitor
Hyundai ImageQuest L70S 17" LCD Monitor Logo
1,020 people viewed this question
Top Hyundai Computers & Internet Experts
rhodesworks
 Zackery G
Zackery G
Level 1 Expert
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
