Question about Hitachi 53UDX10B 53" Rear Projection Television
Convergence problem My TV has convergence problem, When the problem showed up at first time, I replace the ICs STK and all related risitors My TV has convergence problem, When the problem showed up at first time, I replace the ICs STK (two) and all related resistors following the service manual. It was working TV back to normal. But after a few months, the convergence problem showed up again, I find out that same resistors burned, I assume that STK went to bed. So I did fix as late time. Again, after a few months, the problem came back. At this time, replacing IC and resistors do not take care of the problem anymore! After replace all the parts, I can use remote control to move those lines but only limited affect on the curve. Question, If replace STKs do not take care of the problem, what should I replace? And where should I looking into the problem. I am computer engineer with very good solder skills. Thanks
  • 3 more comments
  • ping Lee Jun 01, 2007
    Hi, Bill:
    Thanks for the help.
    I did replace STK392-150 and it does not fix the problem. Only thing I find out is, If I put 1w resistors, it will be burned out soon. So I put 1.5w resistors that hold much longer.
    What is the phenomenon that shows the digital convergence unit may be bed? I also read some article about if the electromagnetic deflection coil went to bed, it can also cause the problem of convergence.
    Ping
  • ping Lee Jun 03, 2007
    Hi, Bill:
    Thanks, I order my parts from electronix.com. The STK392-110 cost about $6 and $10 for STK392-150. I will get the part from B&D, it cost $15.
    I will give a try and let you know the result.
    Ping
  • ping Lee Jun 08, 2007
    Hi, Bill:
    I am in bed luck! The problem is getting worse.
    I replace ICs ( STK392-150) and also double check all the resisters as you said. After I make sure there is no error, I turn on the power. I see the problem of convergence still there! I knew that right way because if the problem is solved, all the lines on the screen should all go straight.That happened to me before. What getting worse is that the TV is off (no high voltage) by its self after a few minutes I turn on. The power is still on, but you can hear the relay click sounds. It looks like that the power blocks shut down by detecting something is wrong.
    Where should I look into?
    Thanks
  • Danomak Dec 23, 2007
    My 53' Hitachi rear projection tv had a severe convergence problem. I purchased the convergence repair kit mentioned in solution 1. The kit came with a diagram of the board showing each piece that need to be replaced. I have not worked with a solding iron for some time, so desoldering and soldering was slow and a bit nerve racking. I put the board back in and worked with the magic focus for a while. The picture looks good but could not get the right side blue to line up exactly. Also picture is a bit grainy or foggy looking. Is there anything I should adjust?
    Thanks for your help.
  • Bob May 11, 2010
    Have 53UWX10B from 2002. Had convergence kit installed 16 months ago. Now it will go in and out of color alignment and picture is curved @ top and bottom toward center of screen. Problem is only intermittent at this point.Picture is fine and then sometimes it starts acting up. I suspect the possibility of a loose connection since when prob starts if you tap side of cabinet usually will go back to normal. Service centers say they just want to come and replace convergence kit for $500.00 or so. Don't think this TV is worth that kind of investment, especially if repair will only last a year or so. Any suggestions???
  • 934 Answers
That unit has a convergence repair kit that should fix most problems. Order it directly from Hitachi p/n# X480295. It contains: Rk42 3.3 Ohm 1w Rk46 1.8 Ohm 1w Rk50 3.3 Ohm 1w Rk54 1.8 Ohm 1w Rk58 3.9 Ohm 1w Rk62 2.2 Ohm 1w Ik04 Stk392-150 Ik05 Stk392-150 And I would strongly recommend testing all the resistors in that circuit for change in value. Are you using a good heat sink compound on the STK's when you installed them? That and ordering the japanese knock-offs for STK's are the two most common critical mistakes made. Originally that unit had two STK392-110's for conv. amps. Even Hitachi recommends subbing to a STK392-150 or 180 for greater reliability. You do realize that for the cost you have after two failed attempts you probably could have taken this to a reputable shop and watching the ball games now. :) (no disrespect intended) Good Luck! Bill
Posted on Jun 01, 2007
  • William Rayburn
    William Rayburn Jun 03, 2007
    When the STK's short they will usually take-out their corresponding resistors. Don't know where you purchased your amps from but one of the most critical problems in our industry today is knock-offs being sold as genuine parts. The STK is made by Sanyo - try B&D Electronics BDENT.COM on the net..
    Make really sure you have checked all the resistors in the convergence circuit for a change in value. Set your DMM for ohms read and replace any resistor not within 85% of its rated value.
    Good Luck
    Bill
Posted on Mar 05, 2009
  • Hitachi Master
  • 3,459 Answers
19a7683.gif Ecollier2012
Rank:guru_s.gif Guru
Rating: 91%, 106 votes
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
    Here is a quick test....
    Using your original remote go-to the tv settings then goto the convergence section.
    Try to adjust the red and then the blue convergence.
    You should be able to move them up, down, left, and right.
    If you can't move them in all directions your convergence chips convergence problem - 2c07611.png should be replaced. This is a common problem.
    2c07611.pngSolution #1
    You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
    Problem #2 CRT Fluid is Cloudy
    Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even seeconvergence problem - 578ba6c.jpgnd images.
    Picture of a set that needs the fluid changed.
    TV sconvergence problem - 2c07611.pnguid change
    2c07611.pngSolution #2
    What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Mar 09, 2009
My Magic Focus Does not work on my hatachi tv and my colors r not lined up does any body know how to line up the colors on the tv.
Posted on Jan 27, 2008
  • 3 Answers
My Hitachi 43 UWX10B had severe convergence problem making it unwatchable. repaired by technician for $285 made this 5 yr old set work like new!
I lack equipment, tools and skills to diagnose and repair these rear proj HD monitor TVs..so I bit the bullet. hope it will last some 5 yrs or so.
Posted on Nov 24, 2007
Focus Error I am getting double picture and the colors are off. When trying to auto focus the blue lines are wavy.
Replace Convergence ICs ,Big black ICs will have PN# on them example STK 392-110
Mats has ICs 1-800-628-1118
Jun 05, 2011 | Toshiba 42H82 42" Rear Projection...
I changed my two IC chips and three resistances on my Hitachi TV to fix color alignments. Now the problems is that yellow and blue double image are seen at the bottom of my screen with no much effect on...
Ur tv still have dead resistors parts,test all 12 resistors parts around the 2 STK convergence ICS and changes some more dead resistors parts or changes all 12 resistors parts for sure.If tv still have the same problems after tested and replaces more resistors parts or all 12 resistors parts.Than some how when u handling and replacing the 2 STK convergence ICS and resoldering the 2 STK covergence ICS u short it out the 2 STK convergence ICS by resoldering without proper grounding ur self not to allow for static electricity to kill the 2 STK convergence ICS or u using a soldering iron to high of a wattage for doing soldering ICS work.
Apr 23, 2011 | Hitachi 43FDX01B TV
Shows 3 screens all Different colors overlapping
This tv have a problems known as a convergence problems,it dead.The tv convergence board,require 2 STK convergence ICS and some or all it resistors to replaced to solved the tv convergence picture problems.The shop will,cost u $300-350 for parts and labors.
Oct 07, 2010 | RCA HD56W58 56" HDTV
Projecting double images
When convergence output ICs got failed, tv shows double image or 3D like picture. Replace convergence output ICs in tv to fix the issue. Local tv repair shop will replace it for you.
Jul 07, 2010 | JVC AV-56WP74 56" Rear Projection...
Have a WD-52725 Mitsubishi TV. Notices lines
Ur tv have convergence problems before,that why tv getting colors lines somtimes alot,sometimes not.The 2 STK convergence ICS was defective.Now the 2 STK convergence ICS are now totally dead.The shop will cost u $300-350 for parts and labors for the 2 STK convergence ICS,and it supporting resistors.
May 12, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Had convergence problem; replaced 2 stk392;
100% Ur 2 STK convergence ICS are still dead.Ur ICS soldering some how,u got the ICS shorted.Or ur ICS not right kind of STK ICS,u replacing in ur convergence board.
Apr 07, 2010 | Panasonic PT-56WXF95 56" Rear Projection...
Tv makes an interval chirp sound when turned on / TV is dead
Ur convergence is dead.The 2 STK convegence ICS are dead.Must know how to solders?Replaced the 2 STK convergence ICS will solved this problems.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost U $300 for parts and labors.
Mar 17, 2010 | GE 46GW947 46" Rear Projection Television
Rear projection out
See below exploded view of your Sony KP-51WS510 TV showing boards...
D board is Deflection Board and has convergence ICs qty 02. If tv has problem of convergence, either you need to replace complete board or replace defective parts ( STK ICs) check IC8001 & IC8002 in D board.
If you have electronics knowledge and experience of tv repair, you can make it.
Related service manual of product made things easy because of information, parts location, applied voltages, part numbers and descriptions etc.
Need further help, let me know to provide you more info.
Thank you.
Oct 07, 2008 | Sony KP-51WS510 51" Rear Projection...
Yet another convergence issue - but need your help!
most times the ICs will be sufficient, but on certain models one or two of the convergence resistors will be burned and often dont show any outward appearance. They are located right next to the ICs about 10 of them all identical and you need to unsolder one side of the resistor and lift the one side out of circuit then check it for resisitance with an ohms meter if it doesnt register it will need to be replaced.
May 20, 2008 | Samsung HCN436W 43" Rear Projection...
Panasonic pt-53tw53 convergence
It looks more like an open solder because you were able to align it properly after replacing the STK ICs, if there was an open resistor(s) you would not be able to get it align.
I would suggest to go back and double check the solder joints on the STK ICs as well add some fresh solder to the resistors nearby the stk392-180.
Good Luck.
Apr 28, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
2,807 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
