-   after the software instalation, i connected this web camera some messeage from taskbar is "during the software installation some problem occar..ur hardware might not work properly..."-   Guest
A4tech web camera with a usb port, usually when you insert it to the system unit automatically it has power. Once it did not power on, its the camera has the problem. Have it check with a technician.
We are looking for a basic web cam for outside use that we can record/monitor from a computer. Any...
(More)
We are looking for a basic web cam for outside use that we can record/monitor from a computer. Any suggestions?
My LifeCam VX-1000 has stopped working in MSN messenger Video calls , the mircophone still works and...
(More)
My LifeCam VX-1000 has stopped working in MSN messenger Video calls , the mircophone still works and the camera works using the LifeCam program so please help me figure out why it has stopped working for video calls
lyzmorato
I Apologize For Saying Your Solution Did Not Work.
i.e.
The speaker you got...
(More)
lyzmorato
i.e.
The speaker you got is USB powered. Upon connecting it to your Mac, it should undergo the Auto Detection process. When you connected it, do you see any signs of power on the speaker? If yes, it is getting power. After connecting the USB cable, connect the headphone jack to the audio jack on your Mac.
Please see diagram below. If you have any clarifications, please comment back. Thank you, lyzmorato
To Which I Responded;
When I Connect As Shown In You Diagram (By The Way,Nice Diagram), How'd You Do That ?
The USB Port Is Connected To The USB Input Port Of My Mac.
The Speaker Connection When Connected To The Headphone Jack On My Mac, It Registers As Under Name "Headphones" Under Type It Says "Built-in Output".
When I Switch Jacks On My Mac To The Other Open Jack [Speaker Output], It Says Under Name "Internal Speakers", & Under Type It Says "Built-in Output".
I Did NOT Accept Your Fix, & Again I Apologize For That.
I Can Consider This Matter Closed
Hope This Gets Posted On "FixYa"
