Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso top load washer getting FL error message
I was washing pillows and one of the pillows ruptured allowing the pillow filling to get into the washer drum, now getting FL error message. Any idea what this means? i suspect the pump may have gotten plugged with the pillow filling.
  • 640 Answers
Fl,,flood condiction,,the pump is trying to get out the water,,replace or try and un block pump..onthejob
Posted on Jan 09, 2009
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Old washing machine will wash will not spin stops after wash cycle
I worked on one that would not spin. I removed the agitator and found a king sized pillow case.
It is quite possible you have the same problem. I took some photos and posted em HERE and HERE
Aug 19, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso top load washer stuck on FL
Fl means flood
you either have a bad flood switch or something is in the pump.
the pump is located under the washer
if you where to tip back and remove the 3 5/16 inch screws and look to the very right you will see the pump.
it could be these 2 things and or it could be something in your sump balls. which you would need special tools to gain access to.
let me know if this helps
May 12, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
FL code washer not draining
“FL” (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the overfill switch is reset or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. Shut off the water
faucets to the inlet hoses if water continues to flow.
Here is the complete manual.
Jan 08, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I was washing pillows and water just overflowed - I'm not sure from where. I think the bottom of the machine. Just a little bit of water. Did I ruin the motor?
If you let the tub fill, then put the pillows in, you may have caused the water level to overflow the outer tub somewhat. If you didn't smell smoke or hear any frying sounds, the motor is probably ok. Does the washer seem to operating normally?
Jul 30, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water pump out??
The washer filled with too much water, causing a switch to trip. Then everything stops. It tries to drain during FL but if it can't drain, the washer powers down.Choose Drain & Spin to let the washer drain. Then you have to take the washer apart. Fix the problem. I personally can't tell you what to do because I don't own a Calypso.
POSSIBLE CAUSES:
Bad Pump
High Water Flow
Other Causes
Jul 30, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Ge frontloder leaks as it fills
Are You Sure Because A Load Of Pillows Can Easily Cause An Over Flow Have You Ran Anything Else Through Besides The Pillows?
Also If You Didn't Know Tennis Balls Or Alike In Socks When Pillows Are In The Dryer Really Helps Them Fluff ; )
Otherwise I Will Seek The Service Manual.
Jan 14, 2009 | GE WSXH208A Front Load Washer
I have a calypso with an error code of FL. where do I find the switch to reset the washer
"FL" (Over Fill) flashes
The washer will beep every 10 seconds with no time-out, The
faucets to the inlet hoses if water continues to flow,
If it still happens you need to get a service guy out.
Dec 17, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Prevent items getting sucked through the pump
hi suggest you try this? use a spare small pillow case and put all smaller items in it then tie up open end witha a cord then put in washer they will wash and not get eaten by washer////// there are string bags with tie cord on the market at tesco etc that are designed for this purpose ?and are not expensive
Nov 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
140 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
