Acer Aspire One  PC Notebook Logo
Darlene K. Kirby Posted on Nov 21, 2012
I can't hardly read my facebook messages print to small, need larger
Nathan
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Nov 28, 2012
Nathan
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
1919
Points
24
Hold down the "Ctrl" button and press the "+" button. Hope this helps.
Picture crop
HI,
One way is to go to your menu bar at the top of your web browser, click on "File" then "Print Preview". At the top of the window there should be a small window with "Shrink To Fit" in it. Click the arrow on that box for a drop down list and choose something, like 90% (there is a custom option at the bottom of the list if you need to set something unique in between what's listed) and see how it changes the print size of what is to be printed out and choose the one that looks and works best for you without cutting off text somewhere. This will make it larger when printed out.
Another way that usually works to make the print larger when printing internet stuff & emails is by changing the view size on the screen to a larger size in your web browser (this is separate from your other setting you've already setup). Go to the menu bar at the top (i.e. Internet Explorer), click on "View," then "Text Size" then select a size like "Larger" or "Largest" (something higher than what you're currently set to.)
Sometimes adjusting the current window's magnification (lower right corner of screen or Ctrl button + scroll wheel on mouse) can have an affect on print size.
The only other method is to copy & paste the text into a text editing software like Word and adjust the text size there. If you're using a text program, then you simply adjust the size of the text to a 12 or 14 point, or larger, font size (adjust depending on the font and size you need) and that should do the trick.
More info see this link.
https://www.inkling.com/read/photoshop-cs6-missing-manual-lesa-snider-1st/chapter-6/resizing-images
Thanks.
Technical Support
Enlarge text size
Create Menu tab right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar
This will add to your screen toolbar File Edit View Favorites Tools and Help select the View from the drop down list will be a Zoom with percentages % and text sizes largest to smallest and Full screen option
Increase the Font Size in Email
Email font size is easily controlled while composing messages, but the messages you receive have been sized by the sender.
Some contacts may be perfectly comfortable writing in size 8, but such text can be a strain on the eyes, even with good reading glasses.
The printed hard copies of email messages with small text are even more difficult to read.
There are a few ways to quickly change font size for ease of reading and better quality print-outs.
Open an email message with particularly small text. Increase the email font size of the text using step 2, 3 or 4.
Click on the "View" selection from the menu bar.
Roll the mouse pointer over the "Zoom" choice.
Click on one of the choices that is greater than 100 percent.
Click "View" and cover "Zoom" to make a larger choice if the first choice does not increase the text size sufficiently.
Click the "View" option on the menu bar. Roll the cursor over the "Text Size" selection.
Choose one of the options that will increase the text size.
For instance, if the current size marked with the dot is "Medium," then click "Larger" or "Largest" to make the print appear bigger.
Use a mouse with a wheel to increase the email font size.
Press and hold the "Ctrl" key while rolling the wheel on the mouse.
The text will shrink as you roll in one direction, and grow bigger as you roll in the other.
Change font size before printing.
Click the "File" option on the menu bar.
Click "Print Preview."
Click the "Size" drop down which may display "100%," or "Shrink to fit."
Select a choice greater than 100 percent to increase text size.
Click the "Print" button to view the results on a hard copy.
6helpful
I have a facebook problem where the webpage doesnt open . It says error on page.
Proposed solution: uninstall Google Chrome Frame
I discovered the pb yesterday, trying to connect to Facebook on my XP SP3 Win32 desktop that runs fine, but on which I rarely connect to Facebook, so that I don't know for how long the problem has been here (days, weeks, but no more)
I struggled in various forums to find hints others than "use Chrome or Firefox" etc...
I finally found the solution hidden in:
http://blog.crosbydrive.com/?p=310
After uninstalling Google Chrome Frame, I just had to quit IE and launch it again.
Many thanks to "Lexington Computer Repair Blog " and Sue W (who hold the solution from a Facebook forum)
Change font size in e mail
The printer prints whatever it's told to by the computer. Your printer really doesn't control the fonts.
When you are printing stuff from the internet (web pages, email, etc.) the reason for the small print is that it is related to the size of the monitor and it's viewing setup (the higher the screen resolution, the smaller the print will be when printing it out even though it looks good on the monitor).
One way you can make the print larger when printing internet stuff & emails is by changing the print view size on the screen to a larger size in your web browser (this is separate from your other setting you've already setup). Go to the menu bar at the top (i.e. Internet Explorer), click on "View," then "Text Size" then select a size like "Larger" or "Largest" (something higher than what you're currently set to.)
Another method is to go to your menu bar at the top of your web browser, click on "File" then "Print Preview". At the top of the window there should be a small window with "Shrink To Fit" in it. Click the arrow for a drop down list and choose something probably above 90% or more (maybe 100 or 125%) and see how it changes the print size of what is to be printed out.
3helpful
How do I change the font size ?? The lettering is far to small.
Which browser are you using? Internet Explorer? Mozilla Firefox? Opera? Google Chrome? Safari?
If you are using internet explorer: Click Tools/View/Text Size and change it.
If you don't see tools at the top of your browser on a line that says File/Edit/View/Favorites/Tools/Help look for tools over on the right then click it and select Toolbars, then select Menu Bar and it will stay at the top of the browser so you can just click Tools/View/Text Size
I hooked my keyboard and went to my facebook page and the writing on the page and the pictures are so small you can't read them or hardly tell who the people are
Unrelated to the keyboard. You have your web browser zoomed out. Go to Facebook and hold the Ctrl key then press + until it is zoomed in to your liking.
2answers
I have a very small font size on my aol mail. How do I increase the font size
You can increase the font size by going to your browser's settings and changing the font size from there. How to get to these settings depends on which browser you use. An alternative is decreasing the resolution of your monitor.
Printing so small hard to read. HP 932c Email prints at normal size. It's just very small when printing from the internet. Thanks,
look at your perfences before u print the letter. change the font to a larger size. the web browser that u are using has perferences that print at a certain size font..
Print is very small when I try to print my emails from my Mac Book
go to the font settings and be sure its set to size 12, standard for all documents
1helpful
Font size problem when printing documents
Hi, my name is adam. I am pretty sure what you are describing is a common problem. Before you print you need to go to print setup or print preview and change the zoom settings so that when it prints it can be zoomed to where you can see it clearer.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
