Question about Sony KP-51WS500 51" Rear Projection Television
TV quit working and power light flashes.
The TV started (about 3 months ago) having trouble holding color. If it was turned off and on several times it would finally hold color. Over time this took longer and longer to work. Finally this no longer helped and now when it is turned on the picture fades to blue after about 30-45 seconds, it turns off and the power light flashes 8 times.
    President:
  • 846 Answers
On that TV 8 times means, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
Use Sony's website help you find the nearest certified sony repair dealers and you can call and ask how much they will charge tell them model number and flash code. Nothing safe about doing that yourself you can hurt yourself or damage the TV further. Hope this answered your question as to what the problem is and a solution.
Posted on Jan 08, 2009
    President:
  • 1,990 Answers
Welcome to Fixya! had a Similar Problem with the Same Model-Got it Repaired at an Authorized Service Center for $450.00 after Numerous Trial and Error Fixes, Nothing Else did Any good.
    President:
  • 2,110 Answers
Its in your power supply and colorwheel it would cost about 600 maybe more to fix
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
LG RU-60SZ30 when turning the tv on the power lite changes from red to flashing amber, flashes 6 to 7 times then turns back to solid red. The tv never actually starts. Before this the tv would randomly...
I have read another solution which may indicate the light engine has failed and will likely need replacing. The cost is quite expensive. $1500 range and apparently the part is no longer available from LG. Best you might do is get an estimate to repair just to be sure.
Dec 04, 2010 | LG RU-60SZ30 60" Rear Projection...
Hi, About 3-4 weeks ago I replaced the bulb on my
I am having the same problem as mg2low. I changed the lamp, but my Sony KF60WE610 still will not turn on. It flashes green several times then it begins to flash red. Can you recommend some trouble-shooting for me? Thanks, Richard
Sep 05, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
Mitsubishi WD-62525 TV will not turn on
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it for a samsung ,it works like your mitusibishi:http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php The ballast has a sensor that detects when it's not able to power the lamp or if lamp is not responding,it will flash red when that sensor detects that.When you say: "it began to roll like the vertical and horizontal hold did not work then the sound went out" Do you mean you where getting horizontal lines? If you did that could be the Dmd.his is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Usually when there's a green light it could indicate a problem with the power supply,sometimes some capacitors do go bad. Check all of this and comment on this answer to see how it went.
Apr 08, 2010 | Mitsubishi WD-62525 62" Rear Projection...
My TV began with a flash of white light then will turn itself off. It won't turn off every time the screen flashes. It started a month ago then worked trouble free until now and it began again. You can...
I hope you have a service plan for this set. Most likely--the CRT"s are going bad. This was a VERY common problem for Sony sets of this age. the CRT tubes SHOULD last a long time...BUT Sony had a BUNCH of the tubes that had 'contamination" on the cathodes of the guns...and after a few years..this 'flakes off" and shorts out the tubes. There WAS a recall on these a couple of years ago, but I am not sure about it now. You will need ALL 3 tubes to fix this problem. If it was me...I would try and find out if there is any way to get Sony to cover it..., if the set is not more than about 8years old.
Oct 12, 2009 | Sony KP-51HW40 51" Rear Projection...
Tv wont turn on but green power lite flashes 3 times if i use the remote or press power button on front of tv i have unplugged tv replaced the batteries in remote trouble started 2 weeks ago if i hold...
it sounds like youre describing a RCA HDTV which needs the CP150, CP120 and CP114 repair kit. You can get that repair kit at www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Sep 22, 2009 | Televison & Video
I turned on the TV but just got a black screen but could hear audio just fine. Turned the set off and unplugged it. When I plugged it back in the green timer light started flashing and would not stop...
Nonstop blinking is likely a DM or format board - format board most likely. I have rebuilt several of these by simply replacing all the caps, about 70 of them, and takes about two hours start to finish... But this set does need to boot. It takes about 70 seconds of flashing green light before you're able to press the power button - even when everthing is working as it should..
Hope this helps!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Aug 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Samsung HLP 4663W DLP TV 3 lights blinking
Color wheel is the biggest failure part in Samsung DLP...
A little technical to replace...............T.
Jan 22, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
If you have already replaced the lamp and ballast, to no avail, then it is time to take it in to a certified repair center.  Most will charge a nominal diagnostic fee.  My 61" did the same thing and it turned out to be the Light Engine (of which the DMD Board is a part).
If the problem were the color wheel, the lamp would come on for a bit until the color wheel sync couldn't be achieved and then it would turn off.  The all-3-flashing-lights problem is the lamp.  Here is a page from the service manual on the 3 blinking lights problem.
The Light Engine controls the ballast via a separate signal than the 320 Volts.  The voltage reading means that the Power Board is working properly.
Samsung hln4365w - no pic. or sound. it whistles a few times when powered on
We have the same DLP set and had the same problem. The Color Wheel, P/N BP96-00250A, a $200 part needs replacement to eliminate your problem.
May 24, 2008 | Samsung HLN4365W 43" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
19 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
