FixYa.com
Tags:
Jenn-Air JGS8750 Gas Kitchen Range
F1-1 error on Jenn-Air Range (by 4 users)
posted by J Waters on Jun 01, 2007
When using my Jenn-Air range I get the error code F1-1, I have unpluged the range, however I am still getting the error code when I use the range.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by Guest, posted on May 11, 2008
We are having the same problem. Our repair man has suggested we kill the power to the stove for 48 hours to erase the memory to see if that works, so that is what we are trying now. It is certainly the cheapest option.
Comment by Guest, posted on Jan 05, 2008
we have also been getting this error code with beeping that happens randomly, but usually after the over has been used. It happens up to several hours when finished using the oven, many times in the middle of the night
Comment by Helena66, posted on Dec 23, 2007
I am getting the F3-1 and F1-1 error codes. I had a repairman come to my home, and he installed a new "sensor"; however, the same day he installed the sensor, I am still getting these error codes.
Best Solution
posted on Aug 02, 2007
Helpful (85)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
VANMAN69,
I have looked in the door under the oven door and can not find the codes. Any more suggestions? I have had a repair man come and replace my control board but I am still getting the F1-1 fault code and when using the oven I get the F3-1 fault code.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jun 02, 2007
Not Rated (0)
VANMAN69
Rank:Master Master
Rating: 80%, 19 votes
if it is the stove that is in the picture the fault codes are in the door under the oven door.
Can you Help with these Kitchen Ranges problems?
Contro Panel
The control panelon my range... Answer This...
jenn air natural gas range
other burners make a clicking... Answer This...
jenn-air glass cooktop 36"
one burner is not working -... Answer This...
Jenn Air convect all gas stove
When the oven is on, it keeps... Answer This...
Jenn-Air gas range F9 indicator
What is it and how do I get it... Answer This...
Repair Service
Find Kitchen Range Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
