Question about Nikon Coolpix S210 Digital Camera
Dropped camera jammed zoom lens on nikon 28-85 lens
How can I get my zoom lens to zoom after it was dropped and subsequently jammed?
  • rraskin Jan 09, 2009
    Excellent.. Thanks alot for your help
  • 88 Answers
You have impact damage, the gears in the lens are out of alignment.
www.cameradr.com
he is a friend of mine who can fix this for you.
Posted on Jan 09, 2009
Jammed lens
Send it to Nikon for repair. If you try to fix it yourself, you will only cause more damage and add to the cost of repair.
Apr 04, 2013 | Nikon 17-55mm f/2.8G ED-IF AF-S DX Zoom...
When I'm taking a picture, and i try to zoom, it zooms a little then stops, says lens error and goes black. If i turn it back on, it goes on, I just can't zoom.
Most digital cameras jams are the cost of lens problems while zooming, with Nikon Coolpix S4000, simply use your fingers carefully pulling on the lens while turning the camera on. this can be done by getting your fingernail under the lens opening and gently pull.muunlyte5608.jpg
May 10, 2011 | Nikon Coolpix S4000 Digital Camera
I dropped my 14-24mm F2.8 and now the zoom ring is jammed. Help !!
I've done the same thing before and the only advice I have to offer is to LIGHTLY, LIGHTLY tap around the lens (360 degrees) at the zoom ring with something like a Sharpie marker. If that doesn't work send it to Nikon. You spent a lot of money on this fine lens so if a "Quick Fix" doesn't do it don't mess around.
Good Luck, I feel your pain.
Feb 22, 2011 | Nikon 14mm F2.8 D-AF ED Lens
I have a Nikon D40, which I recently dropped. :( Camera seemed okay, but then I noticed later that the 18-55 lens was being less than cooperative. It now is stuck on 55 adn will not zoom out. It still...
It sound like the lens zoom has broken.
If other lens is ok and this lens still focuses automatically the conection is working.
Sorry to bring the bad news but it may cost less to get a new lens than to get it fixed.
Someone else might have an idea how to fix the zoom, good luck.
Jul 05, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
My 18-70mm DX has a shaky front portion that the shade fits on
My lens did the same for most of the past year or so. Finally it started catching as I zoomed in and out and would not go wider than ~24mm. The problem is one or more of the screws holding the zoom mechanism comes loose and jams. Follow this link for the fix; took me ~20 min to repair (I went very slowly)!
http://photo.net/nikon-camera-forum/00Pegi
Good luck...
-David
Mar 20, 2009 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
Coolpix L1 Lens error.
Seem like the AF system doesn't reach the home position, therefore the zoom is not closing. Or may be has been smashed and the zoom block is jammed.
Anyway you need professional help. Problem will be solved after a major srip down.
R. Calla C.
Oct 22, 2007 | Nikon Coolpix L1 Digital Camera
I dropped my camera and the lens got stuck
I banged mine around several times and tried to force the retractable lens in and out. Neither of these things worked. I finally thought "what the heck it's broken anyway" and used a bobby pin to try to force the outer lens cover off. After applying just slight pressure it unjambed the lens cover and it works fine now.
Dec 29, 2006 | Nikon COOLPIX L3 Digital Camera
Nikon Coolpix S210 Digital Camera Logo
332 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
