Printer stop printing color, install new ink cartrage still will not print color. hp psc 750 printer
  • overthehi18 Jan 08, 2009
    I did the things you said to do, I reinstalled the soft ware that came with the printer when It was new and it did not help.
  • overthehi18 Jan 09, 2009
    I held down left arrow & cancel key and unpluged the power,still not printing color.
  • 916 Answers
  1. Open the top cover of the printer and remove the cartridges.
  2. Verify that the correct cartridges are installed in the printer. Click here to see if you have the correct cartridges . If the correct cartridges are installed, make sure that the tape has been removed from the cartridge nozzles.
  3. Insert the cartridges firmly back in their cradles and close the latches.
  4. Close the printer door.
Posted on Jan 09, 2009
    Sergeant:
  • 378 Answers
It also happens if both the cartridges are faulty. you told you replaced colour also replace black and check it will start working.
Posted on Jan 08, 2009
    Top Expert:
  • Office Equip... Master
  • 77,499 Answers
Soak the print head of the cartriage in hot water for 5 minutes, then put a rag or paper towel over the end and shake it so the ink moves to the bottom of the cartiridge, this wil in most case fix the problem.
    Scholar:
  • 100 Answers
Goto Start menu then select printers and faxes a window will show all your printers. right click on your printer then select printer preferences. then choose color tab and select print in color. now print a test page to verify it.
please dont forget to rate my solution :) thank you
  • 4,806 Answers
Hi there
Take the colour cartridge back out and check to make sure you have removed the plastic contact protective cover, if you have you may have to use HP software to keep printing a test page until the colour comes through
Good luck and thanks for using Fixya
    President:
  • 1,952 Answers
Compatible cartridges are actually refilled HP cartridges. They are not as reliable as new cartridges. Before assuming that the cartridge has become defective, clean the electrical contacts on the cartridges and carriage with alcohol and a cotton swab. If you still get the error return the cartridge to Office Max.
Both cartridges must be recognized as good by the printer or it will not print.
Download the Users Guide here.
http://h10032.www1.hp.com/ctg/Manual/bpu02250.pdf
  • mohammed marika thambi
    mohammed marika thambi Jan 08, 2009
    first question I have ( I know it sounds dumb, but... )
    did you remove the plastic strip covering the cartridge before you put it in the printer?
    and the next question - when was the last time you actually printed from it?
    the first troubleshooting step I would suggest is, pull the cartridge
    out, use a q-tip and water, and clean the contacts on both the back of
    the cartridge and the carraige holder
    At this point, about the only idea that comes to mind is to try
    replacing the cartridge. when ink cartridges sit around, the ink
    solidifies inside, causing it to stop working long before it should.
    the last suggestion I would make on the existing cartridge is to take a
    paper towel and water, and wipe off the bottom of the cartridge, see if
    that helps to moisten the ink to push it through, then put it back in
    and try printing again.
  • 679 Answers
There are some causes for that;
1. clean printer rod and cartages head.
2. check the new cartages you purchase is of same model as old.
lets me know if solution not works.
    President:
  • 1,990 Answers
Welcome to Fixya! First you need to use the Settings in the Printer Software to Reallign the Print Cartrige and Try to Print a Taest page. if it still does not Work, Remove the Cables from the Back of the Printer for 5 Min. Reinstall Cables and Run Allign and Test again. Should Reset ther Printer to Accept the New Cartridge.
  • 10,594 Answers
Please go to control panel and printer properties and check and disable B/W printing box.
    Sergeant:
    Novelist:
  • 326 Answers
Either the carriage cable is faulty also tell me do u get any error for color cartridge.
    President:
  • 2,110 Answers
try to reset the device: press and hold the left arrow and the cancel button, while unplugging and reinserting the power supply.
  • 13,433 Answers
Check your computer printing preferences, also try reinstalling the printer.
you can download the latest software and drivers for it here
  • Ekse Jan 08, 2009
    Ok,
    things to try, please try them all and if one doesn't work go to the next.
    1. Press and hold the power button for 30seconds, reset the printer
    2. reinsert the cartridges
    3. Double check your printing settings that color is being used
    Important
    4. Print a self test page from the printer not from computer.
    1. From the front panel, press
      Menu
      repeatedly until
      Self-Test Report
      displays.
    2. Press
      Select/Resume or Enter
    If color is missing from the page you probably have a cartridge that is empty, has clogged nozzles, or dirty contacts.
    The cartridge shouldn't be empty, so either clogged nozzles or dirty contacts, you can clean the cartridge contacts on the cartridge and in the cartridge carrier.
    5. Run the cleaning utility that came with the hp software
    6. Calibrate the cartridges, utility comes with hp software
    7. Clean the nozzle
    8. if your problem is not solved you may want to contact HP to service the printer.
Printer always says "Remove and check color cartridge"
It must be your ruined catridge. Some times the wire connections are burned at the side of the catridge and you must thaw away it and buy a new color catridge.
Oct 28, 2009 | HP PSC 750 All-In-One InkJet Printer
Hp psc 750 won't print with new color ink cartridge
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Aug 24, 2009 | HP PSC 750 All-In-One InkJet Printer
Installed black ink but hp psc 750 keeps saying install colour and i only have black ink. Can you operate this printer without colour in.
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Aug 19, 2009 | HP PSC 750 All-In-One InkJet Printer
WONT COME OUT OF THE ALIGN CARTRAGE MODE
if the colour cartridge is empty or any of the three colour is not got printed on the allighnment page it will not comple allignment.replace the colour also or get you colour cartridge refilled.
May 06, 2009 | HP PSC 750 All-In-One InkJet Printer
How can i print in just black with no color cartrage
in your printer you can use single cartridge but there should be both cartridge inserted in the printer.it will not print if only one cartridge inserted.so let the colour cartridge empty but it should be there in the printer.other wise it will not print.at present the problem in your printer is colour cartridge circuit is got faulty so the printer is not detecting the co,lour cartridge in it.so it ask for replacement.in this case you will have to compulsary get the replacement cartridge.you can buy new cartridge or recycles cartridge that will be quite cheaper then new cartridge.
Apr 03, 2009 | HP PSC 750 All-In-One InkJet Printer
Printer stopped working E appears in ''copies box''
There is a great possibility that that the cartridge is bad.
You could take it back to Ink Stop to check and for an exchange.
Most of the time the cartridge may be overfilled.
Check the cartridge printhead, if it is wet, blot it dry with a paper towel.
If is a color cartridge, check for all 3 colors are present
by pressing the printhead on a piece of paper
if 1 color is missing, the printer will sense the cartridge as bad.
Do the following steps in installing the cartridges
Remove both catridges
Unplug printer, wait 3 minutes, plug back printer.
Turn printer back on
Wait until printer stop
Check the contacts of the cartridge to be clean
Install both cartridges.
Apr 03, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 2410xi color printing issues
Try using warn distilled water and Q-tips to gently clean the area where the ink cartridge and the carriage mate up. You may have dried old ink in there which is clogging the print nozzles. Allow to air dry, reinstall cartidges, start machine and let it go through its cleaning cycle. Also check www.hp.com. Hope this helps.
Jan 30, 2009 | HP PSC 2410 All-In-One InkJet Printer
We have long had an HP PSC 750. We don't print in color and a tech person at HP told us just to buy black cartridges and take out the old color cartridge & put it back in and set the printing prefs for...
You must replace the color ink cartidge because the inking system uses both cartridges even on just black prints.
Sad, but true. This is how HP makes their money. Selling ink, not printers.
I'm a good ol' US of A boy.
Jan 22, 2009 | HP PSC 750 All-In-One InkJet Printer
INK CARTRAGE PROBLEM ?
Hi
You must define in printer Properties that you install a new cartridge!!! Just go on Printers and faxes, right click on printer, select properties, advance and click install new cartridge!!!
good luck!!!
Jan 23, 2008 | HP PSC 1210 All-In-One InkJet Printer
Hp psc 1410 all-in-one printer not printing
What is not working? The printer or the cartridge? If it's the cartridge, try this. fold a paper towel in 4ths, dampen it and place on a flat surface. Blot the cartridge several times on the towel. You should get blots of black with the black cart. and three colors with the color or photo cart. If not... replace. If the printer carriage just won't move and you're shure you have power.. time for a new printer.
Aug 27, 2007 | HP PSC 1410 All-In-One InkJet Printer
19 people viewed this question
jasbo
jasbo
