Question about Desa International Kerosene Portable Forced-Air Heater
I HAVE 6 DESA HEATERS, NCANT KEEP ANY RUNNING MORE THAN A DAY.NO FUEL PRESSURE, NO SPARK, TOO MUCH FUEL PRESSURE,ETC. IVE SPENT ALOT TO REPLACE PARTS ON THESE UNITS, EVEN THE ONE THAT IS ONLY 5-600 HRS OLD HAS PROBLEMS. IS THERE NOT A HEATER WITH LESS MAINTENANCE? JOE
4 Suggested Answers
tbugger
  • 232 Answers
SOURCE: my DESA C100D kerosene heater quits after running a while. It may
Emery- there are 2 types of filters used in the spark plug heaters.. Most likely yours is a long cylindrical type which is hidden inside the pickup tube that drops into the tank. These filters tend to get gummed up with a black, tar type goo that restricts fuel flow & starves the flame. The other is a lawnmower type filter. Go to this page for pictures of both types of filter.
The filter is probably the problem. The flame goes out due to lack of fuel, then the photocell shuts the heater down due to lack of flame.
Don't rule out water in the fuel. Water will cause a flameout condition, also.
Posted on Dec 20, 2008
  • 7 Answers
SOURCE: Grade of fuel required for DESA heater
Dave you can use all three types that you have listed.
The pump is typically set for Number 2/ Diesel Fuel and if you run Kerosene the unit will run a little bit hotter but with a 3E359B you will typically run diesel due to the amount it will use and the increased cost of kerosene over diesel fuel.
Number 1 is similar to kerosene and is the fraction that boils off right after gasoline.
Number 2 is the diesel fuel that trucks and some cars run on, leading to the name "road diesel". It is the same thing as heating oil.
Posted on Feb 10, 2010
  • 3239 Answers
SOURCE: I have a Glo-Warm "DESA GWRP16" LP wall heater.
sound like the reg is locking up turn off gas then turn on very slow see if you get gas flow , if not then you could try new reg
Posted on Nov 30, 2010
Brand new ignitor will not light , pump and fan run, fuel sprays new fuse installed could there be a board problem if so how do you check reddy heater rm200at
Difficult to comment without knowing what function the circuit board has.
Heaters of this type usually need a high voltage supply to produce a spark at the ignitor. The high voltage is typically produced by a transformer which historically is highly stressed and unreliable in some types.
Your heater might be differently designed but it is fairly clear the ignition spark is absent...
Feb 01, 2018 | Reddy Heating & Cooling
I have a master heater b150b 150,000 btu kerosene heater motor and fan blowing and i can see tho igniter lighting but it seems like no fuel been sitting awhile it will not light
jason2713,
Provided that you know the unit has sufficient fuel and there is no dirt or water in the fuel you have a classic All Pro, Reddy Heat, Master Heater, etc problem. They are all made by DESA International and similar in operation. They control fuel pressure by bleed air. As the air filter plugs up the pressure changes and that is why your unit runs with the top off. You allow more air to flow. You need to replace the air filter and set the pump pressure. I have a tip at
http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters
which is written for Reddy Heaters but as I said before they are all the same. It tells you how to complete the repair and where to get the parts.
Thanks for using FixYa and for the great rating.
hardrocko
Mar 03, 2011 | Reddy Heating & Cooling
As soon as i plug it in. the fan starts to blow **** the flame does not turn on. and the unit shuts its self off automaticaly. I took the cover off of the unit.and then it would fire up. But i do not...
toddbrewer1,
This is a classic All Pro, Reddy Heat, Master Heater, etc problem. They are all made by DESA International and similar in operation. They control fuel pressure by bleed air. As the air filter plugs up the pressure changes and that is why your unit runs with the top off. You allow more air to flow. You need to replace the air filter and set the pump pressure. I have a tip at
hardrocko
Mar 01, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
I have a 165000 reddy heater.I have fuel going in,igniter is glowing ,fan is running but it will not ignite.
Now you may want to try to reposition your igniter closer to the fuel source. I have also widened the spark gap on the spark type igniters and had success. Then are you sure that the igniter is getting hot enough to ignite the fuel?
Dec 14, 2010 | Desa International (R165DT) Utility Heater
M where is the fuse located at? my heare will turn on, then it turns right back off. i took it apart and could not find it.
mikeleviner,
The problem you describe is a common problem with all these kinds of heaters. It involves the pump pressure and interaction with the air supply which changes as the filter gets restricted. The solution involves getting a new filter and setting the pump pressure. You could also have water in the fuel but all this is explained in my tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which also tells you where to get the parts.
Thanks for using FixYa and for the great rating and testimonial. Great ratings keep experts helping to solve problems. Thank you.
hardrocko
Nov 19, 2010 | Desa International RH125AT Utility Heater
I have a 2E511C heater that wont fire up but the spark plug is firing
You probably already know this . The 2E511C was manufactured by DESA for Grainger, so you must follow these Reddy Heater troubleshooting tips.
It sounds like the heater is not getting fuel or the fuel is not hitting the spark and you must troubleshoot and find out why.
Contact me for a Dayton to DESA parts cross reference chart.
Oct 27, 2010 | Dayton E51 Oil Filled Utility Heater
Can not get the pilot light lit again
It could be the electrode or the ODS pilot assy. that you need to replace. It really depends on the type of you unit you have. If its made by Desa( Comfort Glow, Vangaurd, etc) or ProCom check out Master Parts, they carry these parts. 800.446.1446 or www.masterparts.net. I hope this helps you!
Feb 26, 2010 | Desa International GWRN18T Infra-Red...
DESA space heater 30000 BTR nospark or fuel motor runs o.k.
You may need to replace ignitor oor spark plug. It also could be a defective transformer or circuit board. The manufacturer has technical support sevice manuals listed on there site that are very helpful. Go to www.desatech.com. I hope this helps you!
Jan 10, 2010 | Desa International R40 Utility Heater
My DESA C100D kerosene heater quits after running a while. It may
Dec 20, 2008 | Desa International Kerosene Portable...
Heating & Cooling Logo
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
