Question about Creative Labs ZEN SLEEK MP3 Player
Same problem ...not able to switch on .. :((
I thought I am alone :). Oh you are here. I am also having the same problem and looking for the soultion. My Creative Zen player was working well for quite sometime. It stopped switching on suddenly, When I was transfering the mp3 songs to player ...suring transfer my Explorer just hanged ..I thought removing USB connection and put it back will solve the problem. But I am not able to swicth on my mp3 player ... and my pc is not detecting my player. I tried to reset ..that also doesn't work. Pls inform me if you got a solution.
  • Edwin james Jun 01, 2007
    Thanks for ur suggestion.
    I beleive battery is ok..as I am able to see the blue lights on when i rub my hands on the buttons while my player is connected to my USB.
    When I disconnect my player from USB , stil my button lights on... but it's dimmed.
    The prblem came only when I disconnect the player from USB when data transfer is in progress.
    Still looking for solution ....
    Problem Solver:
  • 9 Answers
Well have you tried a new battery or it could be a faulty wire ! hope it helps ...
Posted on Jun 01, 2007
I'd like to just see in the manual on how to swap out a battery in a 2006 nytro RS90NL snowmobile
OH PLEASE no battery will last forever . and if you look at it , perhaps you will figure it out alone .
Feb 07, 2017 | Cars & Trucks
Gotta 93 dodge ram 5.2 sb 4x4, it keeps popping coils... and back firing i want to do carb conversion but its 1200 bucks in parts alone. Any thoughts oh yeah and 3 bad injectors. Mice have chewed hell out...
problem vehicles just cost money regardless of how badass they are. Having said that the way to fix the problem will be to go to a dodge wreckers ( plenty of them around) and get all the wiring harnesses connected to the engine . Be smart and disconnect and connect as you go so that you do not need a wiring diagram
Dec 10, 2014 | 1993 Dodge Ram
How do you get a rear main seal off. A friend siad you can use a scew driver to pop it off this is a toyota celica gt 2002 oh and what do you look for on the seal to determine it is bad will it only be...
Changing a rear main seal is a major repair. The transmission must be separated from the motor to get to it. The way you know a rear main seal is bad is that it will be leaking oil between the back of the engine and the front of the transmission. If it is not leaking oil, then leave it alone. If it is leaking then you have two options. Have some replace it by doing what I have just told you (call around, its probably pretty expensive). Or you can do what I would do, Just check your oil ALL the time and add oil when you need to. Put some cardboard under your car where the oil drips and leave it alone until you want to spend the money.
Mar 27, 2011 | 2002 Toyota Celica
No defrost or floor --- just front vents
i had same problem i thought that it was the switch but after i looked under there i saw that the cable had looped around its self i just followed the cable to where it moves the flapper (it was hard to see it and i was upside down with my feet in the back seat and head under the steering wheel ) and just move the flapper by hand to where you want the heat to go i had car running and heater turned on. if the switch is broken you are looking at $300+ part new just move it to the floor and leave it alone
Feb 09, 2011 | 2003 Chevrolet Cavalier
OK.. I could not get a disk to eject from my wii console. I tried unplugging it and slapping it on the side.. I also found this site trying to figure out what i can do.. I took some of yalls advice on...
Oh my God ;-) Isn't it funny sometimes when you don't notice simple things, happens all the time.
I one time spent 30mins trying to turn on a PC, to only notice I was pressing the "reset" button and not the power button!
Glad I'm not alone.
Jan 03, 2010 | Nintendo Wii Console
Variable speed fans suddenly slow single speed only.
check with the temperature of the CPU core!
because of over heating the CPU is shutting down or not.
Sep 24, 2009 | IBM Computers & Internet
Oh where oh where can my starter be
hootnick: The starter shouldn't be too much of a pain.
What you want to do, standing in front of the car, in the center, facing the engine, look straight down. Look for the engine support bracket. Once you find it, look to the left of it and follow it up to the engine, where the engine and transmission meet. Roughly half way up the block, you will see the starter!
It shouldn't be that difficult to get to or replace.
MAKE SURE YOU HAVE A HOT BATTERY, GOOD CONNECTIONS, NOT THOSE ADD-ON AFTER THOUGHT CABLE ENDS WHICH CORRODE! Those are notorious for selling starters and batteries which were perfectly good! Current goes around the outer parameters of the wire, not through the core, consequently, corroded surfaces from bad connections make for poor diagnosis.
Good luck.
Mar 14, 2009 | 1990 Dodge Daytona
My MP4 Player won't turn on
well you might have to just leave it alone for a couple of months like i did or it migh be because you droped it oh and never ever bang it
Jul 06, 2008 | Audio Players & Recorders
Cannot copy files to the Axim
Try disconnecting your Axim from your PC, then open ActiveSync on your PC, and delete the partnership. Next, reconnect your Axim X5, and go through the connection wizard again, and create a new partnership.
Sep 14, 2005 | Dell Axim X5 Pocket PC
Creative Labs ZEN SLEEK MP3 Player Logo
Top Creative Labs Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
