I have gigabyte motherboard and having a problem in front 2 usb ports. when i opened the cpu then i saw that usb peripherals was not attached. There were 4 cables in each usb port. data 1 etc were written on it. Can u please tell me how to insert or attach the peripherals. i also know where to attach but i dont know is that which cable to attach in which slot as there are 4 cables each (as told earlier). Plz Help Me Out
when i connect the usb1 connector the wire is heating so that i remove it again
-   Guest
Aug 16, 2008
-   need pin layout and color
-   Guest
Jun 03, 2008
-   I have gigabyte motherboard and having a problem in front 2 usb ports. when i opened the cpu then i saw that usb peripherals was not attached. There were 4 cables in each usb port. data 1 etc were written on it. Can u please tell me how to insert or attach the peripherals. i also know where to attach but i dont know is that which cable to attach in which slot as there are 4 cables each (as told earlier). Plz Help Me Out-   Guest
Feb 07, 2008
-   i do not have the diagram i need to hook up my wires
Normally front USB ports have a pair of 4 wire cable with connectors marked red wire is vcc; white wire is -D; green wire is +D; and black wire is gnd. The motherboard would normally have two pairs of dual pin connectors that would be sitting side by side or in-line with uneven pins - 4 and 5 pins; then another 4 and 5 pins. Please refer to the attached simple diagram for your connection. For some reason I couldn't get hold of a manual from the Gigabyte site of your particular model GA-81KHXT. Nonetheless hopes this works for you. Pls post again how things turn up. Good luck and kind regards.
have an rs482-m socket 939 motherboard. i can't get the front computers pink and green plugs to work with a headphone. i did notice inside 4 wires that were not plugged in anywhere. i found a place on the motherboard marked audio where these could go, but i can't figure out which plugs go where on the board. anyone have the users manual. thanks
