Question about Karcher 2500 PSI Pressure Washer
Karcher hds 1000 de
Pump does not have continuous pressure and the ignition tranformer has blown
3 Suggested Answers
SOURCE: KARCHER HDS 1000 de
hi jim i have the same unit diesel burner and diesel engine have you tryed a new accelorater cable?
Posted on Jan 08, 2009
LandaNW
  • 45 Answers
SOURCE: whare can i get a
I work for one of the top Karcher dealers in the US and we can get this part for you. Visit our website at www.landanw.com for contact info or call 800.247.8103.
Sincerely,
Aron Kerr
Landa Northwest, Inc.
www.landanw.com
Posted on Mar 09, 2011
Karcher hds 558c after about 15mins looses pressure, then about 30 seconds later pure stream come out
Sounds like water is not getting to the pump for some reason. As the pump needs constant water flowing through it for cooling, you should not operate the unit until you find the problem. The pump could be damaged.
Jul 18, 2016 | Karcher Garden
My karcher isn't giving me hot water why? It's a hds 601c
Morning Chris Taylor,
You have an igniter/burner coil inside your system that has to be
functioning properly to have good combustion going inside the coils of your heater unit (very bottom).
I tried to pull the documents to see if yours was kerosene powered (like mine: not a Karcher)... but could NOT pull your HDS 601C up on the company site (Karcher.com, sorry... It's me & my new PC).
Poor water = de-lime water coil procedure
Cool water = No combustion, check kerosene, oil (burner fuel)... filter... (etc.) and check your spark!
If your air supply is insufficient to support great combustion your ignitor & fuel nozzles can get heavily built up in soot. My manual says to clean it with detergent & water... I have only ever used Berryman choke & throttle body cleaner.
All the precautions... don't hurt yourself!!
Hope this helps...
KARCHER HDS 601c ECO STEAM CLEANER BOILER HEATING COIL ELEMENT HEATER...
Operating manuals
http://www.ultimatewasher.com/download/hot-water-manual.pdf
May 01, 2016 | Karcher Garden
Karcher HDS 7/10-4M has the oil light giving 4 flashes, what does this indicate as the fault.
Ive got a brand new HDS 10/20 and its crapped out on me already, water line filters were blocked, cleaned them out and now it splutters after 2mins of pressure washing, oil light flashing x3, nothing in any of their **** manuals to assist, any ideas before i set it on fire?
Jan 19, 2013 | Karcher Garden
Karcher HDS 601 C Burner not ignited
hi i have a archer has 601 with problems. the boilers not igniting properly and I'm getting a roaring noise and thick white smoke. the fuel sides working fine iv changed the igniter and the coil still the same works when it wants to. any ideas thanks
May 20, 2012 | Karcher Garden
Whare can i get a pump head for a karcher hds 1000 de
Sincerely,
Aron Kerr
www.landanw.com
Feb 26, 2011 | Karcher 2500 PSI Pressure Washer
G'day bloke i am after a wiring diagram for a karcher hds 1000 de please
I have it, but don't know how to up load it for you. It is in pdf form.
Oct 23, 2009 | Plumbing
KARCHER HDS 1000 de
Hi Jim,i have the same unit to,can you tell me are you connecting to mains water via the small black header tank at the back next to the boiler or is it connected straight to the pump head inlet?
Theres more than one reason i'll just start with this one 1st.
chris
Aug 08, 2008 | Karcher 2500 PSI Pressure Washer
Karcher HDS 750 HOT HIGH PRESSURE WASHER
G-day Mate.
Did you check if the igniters? they may be cloged up with ****. Unscrew the Sight glass on top of the boiler and run the machine (in cold or hot mode, doesn't matter, as the igniters are running all the time) and see if there are working, you should take them out anyway and give them a wipe with a rag as general maintenance item, and when you put them back in there should be about 5mm gap between them.
Less common reasons for the boiler to not work
- Faulty fuel solenoid valve, (You should hear a click sound about 5 - 10 seconds after you pull the trigger)
- Dirty fuel filter,
Take a look at those simple things and let me know if its any of these.
I have a Karcher HDS 750 1989 Year model
This machine just keeps going, it's had a fairly tough life but it has stood up to it all,
i hadent spent anything on it until about 6 months ago when i purchased a new fuel pump for it as the old was wasn't pushing 170PSI to the Disiel injector it had slowly droped 70psi, and it doesn't create a hotter burn in the boiler, but still very good for a 19yr old pump,
other than that thats all it's needed, it's still going strong to date
Very robust machine.
my e-mail is cgodfx@internode.on.net
Cheers Matt.
Apr 07, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
292 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
