Question about General Electric GE SmartWater Household Water Filtration System - GNWH38F
The hot water smells like rotten eggs., only the hot water
The hot water smells like rotten eggs, the cold water has no smell.
Its the mag rod in water heater-if your not using alot of hot water,and water is sitting in heater it will smell like rotten eggs-u can remove mag rod from water heater.it is in top of heater-
Posted on Jan 08, 2009
What could be the problem causing the rotten egg smell in the water? We have changed the anode rod.shocked the well.no sulfur. We have kinetico softener. Use iron out salt. Water heater 2 yrs old.
Some water softeners you can increase the back wash time on the unit to clear out a smell or bad taste , rotten egg smell can be sulfur. You may need a well flush but seek a well company on that for there advice as its not cheap .
May 16, 2017 | Water Water Heaters
Rotten eggs smell
first replace your anode rod if that doesn't work the problem is in your water look at water treatment systems
Dec 01, 2013 | Bradford White M1TW50S6FSX 50 GALLON...
I replaced the anode rod in my electric hot water heater but still get the rotten egg smell. Any suggestions? The heater is over 22 years old, 80 gallon.
Clean the tank with hydrogen peroxide as outlined in following link.
You may also need well company to shock-treat the well with clorox, or whatever procedure they recommend for local area.
http://waterheatertimer.org/Replace-anode-rod.html#H2O2
Aug 08, 2012 | Water Heaters
Water smells like rotten eggs.
When the water heater smells bad, it is time for a new anode rod.
And then you flush the water heater with 2 bottles of hydrogen peroxide.
With water heaters that experience the problem frequently, you change your incoming cold water pipes so hydrogen peroxide can be added easily.
http://www.thisoldhouse.com/toh/video/0,,20047047,00.html
http://www.waterheaterrescue.com/pages/WHRpages/English/Longevity/water-heater-anodes.html
http://www.prweb.com/releases/2010/02/prweb3592714.htm
Oct 23, 2010 | RELIANCE ELECTRIC WATER HEATER
How do you check the condition of the annode tube in a hot water heater?
You'll have to disconnect the water lines from the top to pull the rod up out from within the tank. If you don't have enough clearance above the tank, you'll have to drain the tank, remove the venting and tilt it or lay it down to remove it. The sacrificial rods usually go bad prematurely on well water systems with hard water and causes a sulfur stench in your water. Here's a quick test to try before you do this: Go to the nearest faucet to the water heater and fill a glass full of cold water and another glass full of hot water and smell them. If the hot water is the only glass that smells like rotten eggs, it's most likely coming from your water heater due to your anode rod. Douglas
Oct 04, 2010 | American Standard 40 G Natural Gas Water...
2 month old Lochinvar Electric 30 gal heater hot water has rotten egg smell. Do not have water softener system. Well water with a lot of iron.
is it a new well.......it may go away after a while...its sulfer....sometimes when you drill well too deep you get sulpher water......
Nov 16, 2009 | Emerson InSinkErator W-152 Point-Of-Use...
Hot water is flowing from the water heater into
boiler type? Combi,standard,if your boiler is a combi the non return valve onto your heating line may be defective thus hot water slippng back through cold line best of luck
Oct 27, 2009 | Water Heaters
General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
1,352 people viewed this question
Top General Electric Water Heaters Experts
Paul Carew
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
