Question about Microsoft Windows XP Professional
D:/windows/system32/shdoclc.dll/dnserror.htm can not opened the any webside in internet explorer
  • Andrew Podner May 11, 2010
    can you provide the operating system (vista, XP, etc.) and method you use to connect to the internet (Dial Up, DSL with Network cable, DSL with USB cable, Wireless router, etc.)
    President:
  • 623 Answers
Hi hemgri,
the answer to this problem is unfortunately not that easy, because multiple reasons can cause this error.
It could be a simple DNS or DHCP service error, that can hopefully be fixed by restarting the services
  1. Go to Start>Run and type "services.msc" and click ok
  2. In the list look for "DHCP Client". Right-click and choose Stop
  3. Then right-click "DHCP Client" again and choose Start.
  4. Then look for "DNS Client". Right-click and choose Stop.
  5. Once again right click "DNS Client" and choose Start.
  6. Double-click your Internet Explorer button and all should be working now.
It is also possible that your DNS server is not working properly. What ISP do you have and what are your DNS servers? Try assigning a static DNS server.
  1. Go to Control Panel>Network Connections.
  2. Right-click on Local Area Connections and go to properties
  3. Double-click on Internet Protocol (TCP/IP)
  4. Chose "Use the Following DNS server"
  5. Type in 4.2.2.2 on the first line and 4.2.2.3 on the second line.(These are Verizon's DNS server.) Click OK.
We are just going to use theseDNS to see if there is something wrong with your ISP's DNS. Try browsing and see if it works. If it does, you can also use one of the open DNS servers instead of the one's from your ISP, i.e. OpenDNS's free DNS servers: 208.67.222.222 and 208.67.220.220.
If this still doesn't work, then there is a possibility that your computer is infected with a virus. To do something about that would be too much for this forum, because it involves posting of 'HijackThis" logs. Have a look here, someone had the same problem. Try to find help there - the guys are really good and know what they're doing.
Please leave a comment, so I (and maybe others) can learn more about this.
Posted on Jan 11, 2009
Disconnectivity within 1 minute I install a fresh
ftp://ftp.hp.com/pub/softpaq/sp47501-48000/sp47845.exe
A lot of Windows Update Issues are linked to this Intel Storage Technology Driver being out of date. Hope this helps!
Aug 16, 2013 | Computers & Internet
Tip
Add Remove Programs list is blank -- Windows 2000
Usually It happens due to some virus activity or any corruption in system files. So when you go to Add Remove Programmes, It shows nothing but a blank space.
· To resolve this issue with Internet Explorer 6.0 installed, repair Internet Explorer 6.0:
Click Start, and then click Run.
Paste the following command in the Open box, and then click OK:
rundll32 setupwbv.dll,IE6Maintenance "C:\Program Files\Internet Explorer\Setup\SETUP.EXE" /g "C:\WINDOWS\IE Uninstall Log.Txt"
Because this command is case sensitive, you should copy the command, and then paste the command in the Open box.
· To resolve this issue with Internet Explorer 5.0 or 5.5 installed, repair Internet Explorer 5.0 or 5.5:
rundll32 setupwbv.dll,IE5Maintenance "C:\Program Files\Internet Explorer\Setup\SETUP.EXE" /g "C:\WINDOWS\IE Uninstall Log.Txt"
If the Add/Remove Programs tool still does not function properly, shows no content, or if you want to try to fix this issue without upgrading to later versions of Internet Explorer, check the following registry keys to make sure that they contain entries:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\App Management\ARPCache
Note If the previous registry keys are blank, the Add/Remove Programs tool may also be blank.
Use the command line REGSVR32 [path\filename] to register each of the following files:
%systemroot%\System32\Appwiz.cpl
%systemroot%\System32\Mshtml.dll
%systemroot%\System32\Jscript.dll
%systemroot%\System32\Msi.dll
Program Files\Common Files\System\Ole DB\Oledb32.dll
Program Files\Common Files\System\Ado\Msado15.dll
%systemroot%\System32\Msdart32.dll [not registerable]
%systemroot%\System32\Mshtmled.dll
%systemroot%\System32\Mswstr10.dll [not registerable]
If the Add/Remove Programs tool displays incomplete information or is blank, verify the file dates. Where possible, register the following files:
%systemroot%\System32\Gdi32.dll [not registerable]
%systemroot%\System32\User32.dll [not registerable]
%systemroot%\System32\Msvcrt.dll [not registerable]
%systemroot%\System32\Ole32.dll
%systemroot%\System32\Shlwapi.dll [not registerable]
%systemroot%\System32\Imm32.dll [not registerable]
%systemroot%\System32\Indicdll.dll [not registerable]
%systemroot%\System32\Urlmon.dll
%systemroot%\System32\Version.dll [not registerable]
%systemroot%\System32\Lz32.dll [not registerable]
%systemroot%\System32\Comctl32.dll [not registerable]
%systemroot%\System32\Clbcatq.dll
%systemroot%\System32\Oleaut32.dll
%systemroot%\System32\Mlang.dll
%systemroot%\System32\Shell32.dll
%systemroot%\System32\Shdoclc.dll [not registerable]
%systemroot%\System32\NetapI32.dll [not registerable]
%systemroot%\System32\Secur32.dll [not registerable]
%systemroot%\System32\Netrap.dll [not registerable]
%systemroot%\System32\Samlib.dll [not registerable]
%systemroot%\System32\Ws2_32.dll [not registerable]
%systemroot%\System32\Ws2help.dll [not registerable]
%systemroot%\System32\Wldap32.dll [not registerable]
%systemroot%\System32\Dnsapi.dll [not registerable]
%systemroot%\System32\Wsock32.dll [not registerable]
%systemroot%\System32\Plugin.ocx
%systemroot%\System32\Wininet.dll [not registerable]
%systemroot%\System32\Crypt32.dll [not registerable]
%systemroot%\System32\Msasn1.dll [not registerable]
%systemroot%\System32\Msls31.dll [not registerable]
%systemroot%\System32\Imgutil.dll
%systemroot%\System32\Cscui.dll
%systemroot%\System32\Cscdll.dll [not registerable]
Now Restart your system.. and Voila !!
Your problem is gone..
on Jan 24, 2010 | Computers & Internet
Missing shortcut to internet explore8
1: Go to your windows drive ( where you installed your OS)
2: Go to program files(folder)>internet explorer( folder)> Right click on the IEXPLORE.EXE > select Send to> select Desktop( create a shortcut)
Jan 12, 2011 | Computers & Internet
Intrnet explorer not working
u should have told the problem more broadly.
because i don't know the type of error
Click the Refresh button, or try again later.
If you typed the page address in the Address bar, make sure that it is spelled correctly.
To check your connection settings, click the Tools menu, and then click Internet Options. On the Connections tab, click Settings. The settings should match those provided by your local area network (LAN) administrator or Internet service provider (ISP).
See if your Internet connection settings are being detected. You can set Microsoft Windows to examine your network and automatically discover network connection settings (if your network administrator has enabled this setting).
Click the Tools menu, and then click Internet Options.
On the Connections tab, click LAN Settings.
Select Automatically detect settings, and then click OK.
Some sites require 128-bit connection security. Click the Help menu and then click About Internet Explorer to determine what strength security you have installed.
If you are trying to reach a secure site, make sure your Security settings can support it. Click the Tools menu, and then click Internet Options. On the Advanced tab, scroll to the Security section and check settings for SSL 2.0, SSL 3.0, TLS 1.0, PCT 1.0.
Click the Back button to try another link.
Cannot find server or DNS Error.
C:\WINDOWS\system\shdoclc.dll/dnserror.htm
Whenever u get this it's almost always an IP address problem. Try renewing your ip address.
1. Click the Start menu button on the Windows taskbar.
2. Click Run... on this menu.
3. If the computer is holding a current IP address, type 'cmd' (without the quotes) in the text box that appears. A command prompt window appears on the screen.
4. Type 'ipconfig' (without the quotes) to view the status of the computer's IP address(es).
5. If the computer is holding a current IP address, type 'ipconfig /release' to let go of the address.
6. Type 'ipconfig /renew' to obtain a new IP address (whether or not the computer is holding a current address).
http://compnetworking.about.com/cs/w...in1/ht/ht_.htm
See it this doesn't fix your problem.
Oct 01, 2010 | Lenovo IdeaPad S10-1211U Netbook
//ieframe.dll/dnserror.htm
There are many possible causes for the error you are getting. try these steps.
  1. Restart your computer unless you've already done so. The ieframe.dll error might be a fluke and a simple restart could clear it up completely.
  2. Install the latest version of Internet Explorer. No matter if you're missing ieframe.dll or if you're receiving a browser error message about it, reinstalling or updating to the latest version of Internet Explorer has resolved many user's issues with ieframe.dll.
  3. Using Visual Basic 6? If so, change the reference for Microsoft Internet Controls from the existing ieframe.dll to shdocvw.ocx. Save your project and then reopen it.
  4. Restart your router, switch, cable/DSL modem and anything else that's used to communicate to the Internet or other computers on your network. There may be an issue in one of these pieces of hardware that a simple restart could solve.
  5. Scan your entire computer for viruses. Sometimes, the ieframe.dll error will show up when your computer is infected with certain kinds of viruses. Use your antivirus software to do a complete system scan for virus infections.
  6. Disable Windows Firewall in Windows XP if you have another firewall installed. Running two firewall applications at the same time can cause problems so if you have a firewall program installed like ZoneAlarm, Norton Personal Firewall, Comodo Firewall, etc., then you should not be running Windows's built-in firewall simultaneously.
    Note: Even if you're positive that the Windows firewall is disabled, check again. Some Microsoft security updates have been known to re-enable the firewall automatically even if you have an existing firewall enabled in another security software program.
  7. Update all non-Microsoft firewall and other security software on your computer. Certain security updates from Microsoft have been known to cause issues with security software from other vendors that those vendors are responsible for resolving. Check their websites for updates or service packs and install any that are available.
    Note: If you're already running a fully updated version of your security software, try uninstalling and then reinstalling the software instead. A clean installation may stop that nagging ieframe.dll error message.
  8. Install any available Windows updates. It is true that some previous updates from Microsoft may actually cause some ieframe.dll errors, but installing more recent updates, especially those to the Windows Update software itself, may help resolve the problem.
  9. Clear the temporary Internet files in Internet Explorer 7. Some ieframe.dll issues may have to do with problems accessing existing temporary Internet files.
  10. Increase the frequency that Internet Explorer 7 checks for new versions of web pages. If the default setting is too infrequent and there are issues with certain pages, you may see ieframe.dll and related errors.
  11. Disable Internet Explorer 7 add-ons one by one. One of your installed add-ons might be causing the ieframe.dll issue. Selectively disabling them will show you which one, if any, is causing problems.
  12. Set Internet Explorer 7 security options back to their default levels. Some programs, even some updates from Microsoft, will sometimes make automatic changes to your Internet Explorer 7 security settings.
    Incorrect or overprotective security settings can sometimes cause ieframe.dll issues. Returning these settings to their default levels may correct your issue.
  13. Move the IE7 Temporary Internet Files Folder to its Default Location in Windows XP. If the Temporary Internet Files folder in Internet Explorer 7 has been moved from its original location, plus both Protected Mode and the Phishing Filter are enabled, the ieframe.dll error will occur.
  14. Disable the Phishing Filter in Internet Explorer 7. This isn't a great long term solution if you don't have another phishing filter installed, but disabling IE7's phishing filter has been known to correct ieframe.dll issues in some situations.
  15. Disable Protected Mode in Internet Explorer 7. The Protected Mode feature in Internet Explorer 7 can, in some very specific situations, be involved in generating an ieframe.dll error message.
Still having the issue try the fix at this link HERE
Apr 16, 2010 | Dell Inspiron E1505 Notebook
C:\Windows\System32\DRVSTORE what is this?
Hiii
This actly stores the drivers on ur windows vista. Assuming it may hav bn corrupted, If u hav a Vista OS CD, DO follow the steps below, it wud chk for any corrupt files of the OS and wud repair it wid out losing or harming ur data.
Make Sure U login wid a ADMIN rights on vista. and RUN the following command
sfc /scannow
or u can verify the files before repairing it. Chk the image below. a522ba0.png
This wud solve ur problem.
Regards
Sep 06, 2009 | Microsoft Windows XP Home Edition
Res://c:\windows\system32\xpsp3res.dll/dnserror.htm#http://www.ya
go to the usb model web site and download a latest ed driver and download it
Jun 11, 2009 | Computers & Internet
CAN PRINT OFF SOME THINGS FROM COMPUTER BUT NOT ALL
To resolve this problem, register the Ole32.dll file.
To do this, follow these steps:
1. Click Start, click Run, type or copy and paste the following command in the Open box, and then click OK:
Regsvr32.exe %Windir%\System32\Ole32.dll
2. In the RegSvr32 dialog box, click OK.
Jan 09, 2009 | Canon PIXMA MP470 All-in-One Printer
'Create new website' link on synthasite.com fails to open
It could be a DNS problem.
Goto Start > Run. . . > Type in "cmd" (without the quotes), hit enter or ok.
Type in "ipconfig /all", and look in there besides DNS Servers, if there is not one listed that would be your problem.
If that is not it try Control Panel>internet options>Programs> hit Reset Web Settings
Please tell the results and I will continue to help you the best I can if this is not it.
Dec 20, 2008 | Microsoft Windows XP Professional
Ieframe
use this link to download ieframe.dll fill. extract the winrar and copy the file in your system32 folder.
c/windows/system32. the problem will be solved.
http://www.dll-files.com/dllindex/dll-files.shtml?ieframe
Oct 02, 2008 | Microsoft Internet Explorer 7
Microsoft Windows XP Professional Logo
1,303 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
