Question about Acer Aspire™ T180 PC Desktop
Acer e lock activated
This happened after 2 years of use. E lock has not been activated nor any software installed. Affects floppy drive, CD and strangely a serial connected printer. When I try to print anything the job is queued then deleted and the error message 'Optical Drive Device Locked' appears. Fix Ya says that you had a workaround for the problem..
Thanks in advance
John
  • john365 Jan 13, 2009
    Where do I go online to and where do I type 'acer e-lock deactivation'. Its not been activated except maybe by itself..
    Genius:
  • Acer Master
  • 1,102 Answers
You can on line and type acer e-lock deactivation
should tell you what keys to use to deavtivate and activate
Posted on Jan 13, 2009
Where is the floppy disc on my acer SA80 - Z970
I doubt you have one. Computer manufacturers have not been installing floppy disks for some years now.
Jul 07, 2011 | Computers & Internet
Tip
Solutions for exception Processing Message c0000a3 parameters 75b6bf7c 4...
Many of you might have faced issue called windows – drive not ready and a message ” exception Processing Message c0000a3 parameters 75b6bf7c 4 75b6bf7c 75b6bf7c” right below of that. It will keep disturb you every now and then even if you close this number of times This normally happens when you remove a drive like Floppy drive, CD Drive or Pen drives from its working conditions without proper instructions. You will get this error message when you remove a CD/DVD from CD/DVD drive during a process happening form CD/DVD like installing software or accessing files etc.
In that situations the programs seeking the files from the drives but its not finding there.So we are getting this error.
You can see the error below.
Here is the steps to solve the issue:
a) Simply put a CD/DVD in to the CD/DVD drive and click on Continue.
b) Open the CPU box and make sure all the data cables connected properly.Like data cable for Floppy drive and CD/DVD Drives.
c) Go to BIOS and disable the Drives which you are not using. Nowadays mostly nobody uses Floppy drive. So you can disable Floppy drive. You can disable unused IDE or SATA ports in bios.Save the settings and restart your PC, Now you will not get the annoying pop ups now.
on Jul 03, 2010 | Computers & Internet
Where is the wireless on TOSHIBA SATELLITE 2805-S301
Hi just go this link below:
http://www.user-guides.co.uk/cddownload/Toshiba-Satellite-2805-S301-Windows-7-Driver-CD-Recovery-Restore-Disk-326243.html
Jun 19, 2011 | Toshiba Satellite 2805-S301 Notebook
Nec versa want to downgrade from vista to xp but booting from xp cd it does not detect harddrive, why? what can I do about it?
Sometimes booting from XP disk wont detect your hard disk,the problem is because the IDE driver which is needed for the identification of the hard disks are not at all avaible with the XP CD. So u have to download the corresponding IDE driver for your hard disk and then u can install that from the floppy drive during the installation . I think on installation XP set up will ask for a driver installation (third party installation). U can do this by using a floppy disk . If the floppy drive is not all available in your laptop then u can use softwares which can mix the IDE driver along with the XP set up U have. A lot of softwares are available for download for this purpose
Thank u and please rate my solution
Oct 22, 2009 | NEC Versa FX Notebook
I installed a new WD Cavier 500 Gb hasr drive ot
Your problem could be that the hard disk is not ACTIVE.
Boot up with a DOS disk (floppy or CD or USB) and run FDISK, select 4 to Display Partition Info. If the C drive does not have A under Status then press ESC and select 2 to Set active partition and then set Partition C to active.
Sep 06, 2009 | Western Digital Computers & Internet
Optical Drive Device Locked Acer e lock activated. I cannot use my Cd drive.
Acer eLock Management
Acer eLock Management is a security utility that allows you to lock your removable data, optical and floppy
drives to ensure that data cannot be stolen while your notebook is unattended.
Removable data devices - includes USB disk drives, USB pen drives, USB flash drives, USB MP3 drives,
USB memory card readers, IEEE 1394 disk drives and any other removable disk drives that can be
mounted as a file system when plugged into the system.
Optical drive devices - includes any kind of CD-ROM or DVD-ROM drives.
�� Floppy disk drives - 3.5-inch disks only.
�� Interfaces - includes serial ports, parallel port, infrared (IR), and Bluetooth.
To activate Acer eLock Management, a password must be set first. Once set, you can apply locks to any of the
devices. Lock(s) will immediately be set without any reboot necessary, and will remain locked after rebooting,
until unlocked.
You can try this:
You can reset the system to its default settings (all devices unlocked) by removing the password (leave the password fields blank when changing the password).
You also may be able to simply uninstall the e-lock software in add remove programs.
Is there an icon in your system tray that may allow you to disable e-lock?
Dec 30, 2008 | Computers & Internet
Motherboard
Hi Henryk14,
There are a few issues that can halt Windows from installing.
1. If your Microsoft Windows CD is a copy & not a valid CD this can happen. (Possible bad copy).
2. You CD-ROM drive is either dirty, (Inside) or it's not reading the disk. (Check the data cable on the cd-rom drive. Make sure it is fully connected). (Swap out the data cable is needed).
3. E-Machine's can & most do have more than one partition on the primary hard disk drive.
Most likely there are two hidden partitions on the drive. If the manufacture placed one of the partitions at the top of the drive, (As many do to stop owners from upgrading their operating system with their own CD). The installation of XP can be halted. You will not see an error message from windows during installation in this case.
(The hidden partition is too small to allow windows to install, 4MB in size is about norm).
One option is to contact the manufacture & buy their upgraded OS CD for your model.
Another would be to erase the drive with a floppy disk. A standard Win98 boot disk will do the job but that is ill advised.
The best way to clean & format the entire drive would be to find the manufacture of the hard disk drive & go to their web site. Download their Dos software to create a bootable floppy disk for Dos. Boot the system with the floppy disk & format the drive. This will remove all the hidden partitions & make the drive whole again.
Most hard disk drive manufactures also provide software to create a bootable CD. This will also clean the drive & set it up for window. (You should back up all your data to CD or a second drive).
Other software can be used to totally clean a hard disk drive. "Darik's Boot And Nuke".
Found here: http://www.dban.org/ (Ideal for tough systems & dreaded blue screens).
Good luck Henryk14!
Mike
Oct 24, 2008 | E-Machines eMachines Desktop PC
Cd rom message "no emulation" when booting the windows xp installer
when i install my windows xp professional i get a message prompting BOOT TO ATAPI CD-ROM: "NO EMULATION".... how can i fix this?Pls help me on this
Jun 07, 2008 | ASUS P4SP-MX Motherboard
Hey anyone can help me with some info
Well it will not hurt you're board if that's what you want to know. Depends what devices you have plugged into the board. If you're running 4 serial ATA SATA's. Two CD/DVD drives. A floppy drive & an AGP 8x graphics card. The 400w should do just fine. (You can never run too high a PSU source).
I'm running 4 serial ATA 7200rpm SATA's, 2 DVD-ROM's, a floppy drive. 1 PCI-E graphics card. Four, 4" case fans. Skt 939 Dual core 4200+ CPU & my 550w has been stable for over 2 years.
Have a great weekend!
Mike
May 30, 2008 | Abit A17 Guru Motherboard
Acer Aspire™ T180 PC Desktop Logo
115 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
