Question about U.S. Robotics MAXg USR5421 802.11g/b Wireless Adapter
Unable to open internet page
HI i use wireless adapter US robotics MAXg,and seems that i connected to modem.The ikon shows status connected,signal strenth exelent,before it was showing aquiring ip adress(if you use automatic update ip adress in internet protocol)i set in manually .Still can not get access to internet.My modem works perfect,we use wpa/tkip security.Adaptor was set with the same security standarts and passphrase.If you use the command prompt i can see that media state disconnected.I tryed to to check for ping google.com result was "ping request cant find host". Should i use manually set ip adress in internet protokol if automatic can not get ip adress?Should i use windows to configure wireless connection or let the tool manage it?What is available solution to solve my problem?Thank you..
    President:
  • 2,961 Answers
Let you router allocate the ip addresses manually by enabling DHCP and restart the router,and remove the usb adapter from the usb port and reconnect it, but when you right click on the taskbar on the little pc icons for your connection click enable WZC windows wireless Zero configuration as this will dissable the software you got with the usb adapter and hopefully make the connection more stable, but ensure you have a strong signal.
Posted on Jun 01, 2007
I can connect to my modem, but cannot connect to the internet. Showing I have an excellent signal, but pages on internet will not load.
I have the same problem all of a sudden as well. No problem connected to the router: Connection Manager showed IP address and Connected status but could not load any web pages.
Dec 13, 2010 | D-Link DWA-125 Wireless 150 USB Adapter...
Can't find wireless router in windows xp
Please do the below steps.
1. Check the status of the wireless router . is it power ON and working ?
2. Check the wireless adapter status on the PC
3. Check for the proper drivers for the wireless adapter. If possible reinstall the drivers
Oct 31, 2010 | U.S. Robotics Wireless MAXg USB Adapter...
I bought this US Robotics wireless (model 5461 (Maxg)) maybe 3 years ago. I haven't used it in maybe 2 years and now it wouldn't work anymore. I recently switched apartments and computer, it used to work...
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
9. cell phones, cordless phones, digital TV's, can affect the data signal from a router. Also distance from the router can be a factor. If your router is in a basement place the router to a upper floor and center it in the room.
Oct 04, 2010 | U.S. Robotics MAXg USR5461 (738168036790)...
My US Robotics USR5461 Wireless MaxG router needs to be rebooted quite often (sometimes once or twice a day) to get internet access back. The status page says it's connected to the internet but I can't...
Considering the frequency you have to reboot the router to get it to work may indicate a glitch with the WAN gateway.
I recommend fully resetting the router and setting the wireless network up again.
You should be able to reset the router using a pin and sticking it in the pin hole on the back of the router near the power source.
Thanks,
Pat
Jan 03, 2010 | U.S. Robotics USRobotics USR5461 Wireless...
Us robotics
u must check if the coverage is rhight or not when face this problem
Jun 20, 2009 | U.S. Robotics MAXg USR5421 802.11g/b...
Low signal(wireless MAXg ADSL Gateway USR9108)
1.TRY siting in a place wth less people ... actually wth my USR9108 i get disconnected even if some one is standing infrront of the modem so stay in a open place wth less people.
2.RESET your modem 3 tymes and configure ur modem by the settings given from the Telecom company.
3.Check ur modem antennae ... bcoz its modem is very FRAGILE... it sometimes have an internal wire break ,,,,
TRY installing ur BRothers antannae on ur modem nd den use it....
ALI KAZMI
May 01, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
I have a WCG200 linksys but can not go onto internet.
from what i have read, your router is broadcasting a signal, and your modem has an open and active internet gateway.
pls make sure that the connection from the modem to the router are correct. the modem should be connected in the port with the label internet. you may have to reset your modem AFTER you have connected the wireless router to allow the router to be assigned an ip. now with the wireless router and broadband modem connected, you can connect to the network and access the internet. pls repost if you hit any snags
GOOD LUCK and PLS rate this post.
Mar 18, 2009 | Linksys WCG200 Router
How do I connect a MaxG wireless router into a SmartAX MT880 DSL modem
  • Connect cable from router to computer ...
  • Connect cable from router (internet port) to the modem ....
  • U will be able to go online ....
  • And after it is done ...u can do the wireless settings ....
  • then connect to network and u will be perfectly able to go online ....
Oct 24, 2008 | U.S. Robotics (USR8054) Router
Can't Connect to Internet
there is a need to reconfigure your router to work with your modem. If configured already before, then there is great chance that this has been set back to factory default.
Oct 06, 2007 | U.S. Robotics USRobotics USR5461 Wireless...
U.S. Robotics MAXg USR5421 802.11g/b Wireless Adapter Logo
224 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Michael Galve
Michael Galve
Aris C.
Aris C.
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
