Question about Ovens
Error code have a older electric stove ge model #j35gkw-7 giving error code se-0 unable to locate owners manual for code
Found sensor inside oven no continuity am ordering new sensor should fix problem
Posted on Jan 10, 2009
How to set clock on GE DOUBLE OVEN STOVE MODEL #JB860SJ1SS
To set the clock on the JB860SJ1SS, press and hold the 9 and 0 keypads simultaneously for 3 seconds (or a bit longer). Then type the current time using the keypad. Press Start to save the current time. This is shown on page 13 of the manual; see item 7 Clock.
Sears Parts Direct has the manual available here: https://www.searspartsdirect.com/partsdirect/user-manuals/JB860SJ1SS-GE-ELECTRIC%20RANGE-manual . The direct link to download the manual is currently https://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/1508037L.pdf .
I hope this helps.
Nov 05, 2017 | GE Ovens
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Kitchenaid superba built in oven thermometer probe symbol appeared after cleaning
The last digit is a 0 not an O go to Whirlpool,com scan over service and support click manuals and literature enter your model Number for owners manual as a tech have never seen the symptom you describe do me a favor hold the 0 button for 5-7 seconds to get into diagnostics we are looking for any F error codes hopes this helps
Feb 14, 2015 | KitchenAid Ovens
Owners manual for 1950 o'keefe & merritt stove
Sorry, I only have information on the STOVES 720ef and thus unable to help.
Nov 14, 2011 | Stoves Ovens
My electric GE oven self clean lever will not open.It is an older stove that was present when I purchased the house. The lever is stuck in the locked position. How do I open it? thanks dave
You have to manually open it by hand. Since you did not provide a model number I cannot tell you the correct way to do this. need the mod. number
Mar 25, 2010 | GE Ovens
Giving an F7 error code
There was a tag on stove that told on the error codes. Reset pad, it was somehow stuck. Thank you for your help!!
Cheryl
May 27, 2009 | GE JRP15 Electric Single Oven
Older Ge F4 error Code
Your oven temperature sensor is bad and must be replaced.
Feb 28, 2009 | GE JTP85 Electric Double Oven
I HAVE AN OLDER MODEL KENMORE LIMITED EDITION STOVE/OVEN. I DON'T HAVE THE MODEL NUMBER OR OWNERS MANUAL. ANYWAY, I HAVE A PROBLEM, I TRIED TO USE THE OVEN BUT AFTER I SET IT " F5" COMES UP AND IT BEEPS...
you can get the model number and serial number from the oven, just open the oven drawal and get the number and call the customer service from where you got this oven from.
Dec 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
F 10 Error code
I was unable to find an F10 fault code for the model you provided.
Have you checked your users manual?
Below is a link to most manufacturers fault codes. It also provides links for parts and exploded view diagrams.
It appears that your model was made by Westinghouse but their F codes only went to F8.
http://www.repairclinic.com/0078.asp#Westinghouse
Let know if the information I provided helped solve your problem by rating my answer.
Thank you,
Dave E. (Illeagle)
Jun 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
GE Profile 2002 Wall oven JCKP18BA2BB Code faults
Try my solution for the F7 problem at the following link:
http://www.applianceblog.com/manuals/Dreaded_F7_Problem.pdf
I have shared this with over 1500 folks and most report success.
Please let me know. Also, what is your model number, how old is your oven and where are you located? I am making a study of this problem. You can email me at: hutchipop@yahoo.com
Jan 08, 2008 | Ovens
Ovens Logo
198 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
