The remote works fine, but I can't use it cause it doesn't charge properly. I don't know if it is a charger problem or a problem with the remote. I just bought it a few months ago.
Attempt a hard reboot of the device by holding the home button and the power button at the same time. Contact AppleCare if the problem persists. Also, don't use the iPad's charger on the iPod or an iPhone. It doesn't play well with it.
There are three possible parts of the computer which cause the problem.
1. ac adapter or charger 2. battery 3. motherboard
The charger is working fine which leaves the battery and the motherboard to be the possible reasons for that certain problem. What you need to do is to check which one is really the part that's causing the problem.
Here's what you need to do:
1. Remove the battery from the laptop. 2. Turn the computer by using the charger alone. If it turns on then, the battery needs to be replaced. If it doesn't then it's a motherboard problem which is a very complicated situation. You need to see a computer technician for a motherboard problem.
hi i had the problem before , you have to buy dell charger in order to charge your battery, universal charger doesnot work with this, the only way not to lose your power is to keep the charger connected, in this way the battery will not be charged but u will not lose the power. again you need dell charger the universal only gives power but doesnot charge.
Best Regards
There are 4 reasons why your unit is behaving this way: 1. Charger is the problem. 2. The docking station is the broken. 3. The battery is broken or not accepting charge. 4. The actual unit is the problem. It is very hard to tell which one is causing this to happen. Let us do some troubleshooting first: 1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken. 2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken. 3. If the red power light is lit and the status light (right) is lit too, your docking station is broken. 4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged. 5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
