Question about ServGate Technologies ServGate SG200 Firewall
How to restore factory defaults? Where to find User Manual
I found some pdf's on my.edgeforce.com but most links are not functioning. Can someone instruct how to reset this SG200? I tried power on with switch at back in reset position until bottom led goes out without success. Same result when leaving reset switch in that position for the whole startup. After a few minutes the unit given three beeps. I have the login prompt but admin admin is not the right combination, neither reset with blank password. I salved the unit from scrap. It had a bad power supply, which I repaired. Now I want to use it if possible.
  • Guy Lacroix Jun 06, 2007
    Using the reset switch at the back, waiting for the three beeps and switching back to normal after 10 seconds restored factory defaults. I guess previous attempts failed due to impatience and bad timing. This problem is solved. But now that I start using the device I may encounter a lot more problems. So I still invite Servgate or Edgeforce users to contribute to this SG200 thread.
2 Suggested Answers
SOURCE:
SOURCE: how to reset admin password servgate edgeforce m30/40
I am not sure of the models but on the rack mount Edgeforce product your suppose to hold the reset pin while powering up until the Alarm light turns on, take 2-3 mins. Default user/password is admin/admin.
Fair warning I have one that is locked right now as well and a reset is not resetting and I can no longer log into it either. Anyone with ideas?
Posted on Jul 12, 2008
Forgot unlock pattern but would like to wipe the memory so I can sell it, what next. The phone is the ITRAVL. Terrible customer support!
Page 6 on the manual
Reset by Using the Reset Button
• Unfix the rubber strip on the
right-hand side of the device.
• Unscrew the removable cap of the stylus - it will serve you as a
reset pin.
Note:
The
Reset
button can also be accessed with any thin
object such as a paper clip. Never use a needle or a sharp pin for
this purpose since it can damage the device.
• Press the
Reset
button. If you see a message offering you to
format the user disk, press the
Down
button to cancel formatting
and keep the user data. If you press the
Up
button, the user data
will be erased and the default se
ttings will be restored. On
completion of the reboot, you will see the calibration screen with
five targets, appearing one after
another as you tap them with the
stylus.
• To complete
Calibration
, please follow the instructions on the
screen. To skip
Calibration
, just press the
Recognize
button. You
will see the
Main Menu
Reset via the Setup Section
• Go to the
Setup
section by pressing the
Setup
button.
• Tap
Defaults
. You will receive a pop-up asking you to confirm
restoring.
• Tap
OK
to restore the default settings or
Cancel
to cancel the
restore process
F]ECTACO iTRAVL User Manual
www.ectaco.ca/products/materials/1/TL-2_UM_Eng_web.pdf
Note: The Reset button can also be accessed with any thin object such as a paper ..... To restore factory defined settings for your ECTACO iTRAVL. TL-2, tap the ...
[PDF]ECTACO® iTRAVL® - User Manual
www.ectaco.com/products/materials/1/iTRAVL_UM_ENG_web_new.pdf User Manual. 2. iTRAVL®, Language Teacher®, jetBook®, Audio PhraseBook™, MorphoFinder™, ... the style, format, coverage, and content are designed to meet their specific requirements. The names of actual ...... It is an extremely powerful linguistic tool for those who want to master a ..... phrases or a telephone number.
[PDF]ECTACO iTRAVL-2 LANGUAGE LEARNING SYSTEM & DURABLE ...
www.ectaco.com/products/materials/1/iTRAVL-2_UM_5.1_ENG.pdf Place the SIM card in the phone with golden contact toward ... To restore full functionality of the device, recharge the battery as ..... powerful linguistic tool for those who want to master a foreign language and learn to communicate fluently.
itravl phone hard reset Google Search
Jun 06, 2018 | Cell Phones
How do i master reset a dell insprion 11 series 3000?anybody know?
Mate this first link is a youtube video that goes for five and a half minutes showing how to factory restore,,, The second link is a short manual on the same thing, I hope YOU read this.....
1st link https://www.youtube.com/watch?v=7A8vmqIrO_g
2nd link file:///C:/Users/Steve/Desktop/dell-inspiron-restore-to-factory-default-settings-7319-ncscea.pdf
Mar 16, 2016 | Dell Computers & Internet
How do I restore my router to the factory setting? I have no Wi-Fi service.
Restoring the Default Configuration and Password
  • Use the restore factory settings button on the rear panel of the router. Use this method for cases when the administration password or IP address is not known.
  • This is how to restore the factory default configuration settings that reset the router's user name to admin, the password to password, and the IP address to 192.168.1.1.
  • To use the restore settings button:
    1. Locate the restore factory settings button on the rear panel of the router.
    2. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings button for about 5 seconds, until the Power light begins to blink.
    3. Release the restore factory settings button, and wait for the router to restart, and for the Power light to stop blinking and become solid green.
    4. The factory default settings will be restored so that you can access the router from your Web browser using the factory defaults.
      Then you can go through the setup procedures to setup your wireless
      Here is the link to the documentation so you can set it up again
    WNR2000 Manual Table of Contents
    hope it works for you
    Sep 10, 2014 | NetGear WNR2000 Wireless Router
    Need password to my netgear router n 300
    what is the model #?
    Most netgear routers default to a username of "admin" and password is either " admin ", "password" or it is just blank. Those are the defaults unless someone changed it.
    If you cant get in you can hold down the reset button on the back for 30 seconds (while it is plugged into power) and that will set it back to factory default settings then one of the above should work.
    If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
    Mar 02, 2011 | Computers & Internet
    I have Micromax X235 mobile phone. I want to reset this to factory settings. I lost my user guide. Kindly tell me input password.
    Dear Sir,
    You can restore the factory settings of the mobile phone. The default factory setting password is 0000 If you want user guide get it from the below link http://www.micromaxinfo.com/products/product_downloads/guide/X235_UM.pdf
    right click and click on save as to save this pdf file.
    Thanks
    Mar 02, 2011 | Dual Electronics CECT P168 Cellular Phone
    How to restore defaults?
    sir you didn't mention that you need you camera to restore or your camera driver to restore well i will tell you 2 things number one you can restore by using recovery disk if you don't have download it from this link
    http://www.user-guides.co.uk/download/powershot/powershota80/powershot-a80-reset-factory-settings.html
    number to if you have your camera manual see it if there are any option and try to restore. if you don't have it download it from this link
    http://www.marietta.edu/~mcshaffd/macro/revman/PSA80CUG-EN.pdf
    Oct 11, 2010 | Canon PowerShot A80 Digital Camera
    My acer aspire 4315 stuck at boot with white screen, when using external monitor it show acer boot screen and stuck there. I can press F2 for setup but nothing happen.
    http://tim.id.au/laptops/acer/aspire%204715z%204315.pdf
    Above is a link for your Service manual, inside is everything you need to know to troubleshoot and repair your machine, this is the manual that us engineers use to repair these units.
    This could be your HDD, failed. Work through, the troubleshooting procedures.
    Anyway try this below first. Run Acer eRecovery Management Copy the Acer factory default backup disk Image Create backup of the system Create a complete backup Creating an incremental backup Erase a backup point Using the option ‘‘Burn Disk’’ Burn a backup disc with the factory default settings Burn a backup disc with the parameters of user Copy the current system configuration to disc Burn a disc backup software Restore the system Restore system to factory default settings Restore system from backup user Recover the system from CD / DVD Re-install applications / drivers Other means of System Restore No Restore CD / eRecovery / password / ALT + F10 or F10
    May 14, 2010 | Acer Aspire 4315 Notebook
    I would like to know how to reset the Lexmark E260dn to factory defaults. The printer was set with a static IP address and no longer exists on THAT network. I need to set it up as a DHCP client again to...
    Restoring the factory default settings
    Do one of the following:
    • If your printer is on a network, access the Embedded Web Server:
    1 Type the printer IP address into the address field of your Web browser.
    Note: If you do not know the IP address of the printer, print a network setup page and locate the IP address in the TCP/IP section.
    2 From the Settings screen, click General Settings.
    3 Under Factory Defaults, select Restore Now, and then click Submit.
    • If your printer is connected to a computer by a USB or parallel cable, use the Local Printer Settings Utility for Windows or Printer Settings for Macintosh.
    1 Open the utility.
    2 Do one of the following:
    – From the Local Printer Settings Utility menu bar, click Actions Restore Factory Defaults.
    – From Printer Settings, click Factory Defaults.
    Warning—Potential Damage: Restore Factory Defaults returns all printer settings to the factory default settings except Network/Port menu settings. All downloads stored in RAM are deleted. Downloads stored in flash memory or on a printer hard disk are not affected.
    Or please download the user guide from this link and follow the instructions
    http://static.tigerdirect.ca/pdf/Lexmark-E260D-Series-Mono-Laser-Printer-Manual.pdf
    Hope this will help you
    thanks
    Oct 01, 2009 | Lexmark E260dn Laser Printer
    Cannot get dial tone to send a fax
    try to reset your printer to factory setting
    purchased your HP PSC. Choosing to restore your factory defaults restores
    all settings, except date information.
    You can perform this process from the front panel only.
    1 Press Setup.
    2 Press 5, then press 3.
    This selects Maintenance, and then selects Restore Factory Defaults.
    The factory default settings are restored.
    and you can find the manual at this link
    http://h10032.www1.hp.com/ctg/Manual/bpu05064.pdf
    Jul 01, 2008 | HP PSC 2210 All-In-One InkJet Printer
    How to reset admin password servgate edgeforce m30/40
    Dec 14, 2007 | ServGate Technologies ServGate SG200...
    ServGate Technologies ServGate SG200 Firewall Logo
    332 people viewed this question
    Top ServGate Technologies Computers & Internet Experts
    Alun Cox
    k24674
    Are you a ServGate Technologies Computer and Internet Expert? Answer questions, earn points and help others
