Question about Dell Inspiron 6000 Notebook
Windows will not boot up. It gives me an error message at the sta
After the initial dell logo displays the comp is redirected to an error message stating that there is a problem with windows and that it will not start. It gives options for starting in safe mode, saf mode w/ networking, safe mode w/ command prompt, and start at the last configuration the computer worked properly. None of these will work and then a blue screen with another error message displays. The top says unmountable_boot_volume. It offers advice about restarting and hitting F8 to get into the advanced setup to disable BIOS memory and then enter safe mode, but I can't get it to do anything. The bottom of the error message reads 0X000000ED (0X82F9B030, 0xC000009C,0X00000000, 0X00000000) I ran the diagnostic for symptoms associated withe OS not booting. It gets to one part in the test where it stops and gives error messages. The first said 0F000:0228 MSG:Block 1201280. Then after that each test says IDE device failed. Can you help. I hope so, because if not I'm up **** creek.
  • jaridmatheni Jan 08, 2009
    Will I be able to recover the data currently stored on my computer?
    Sergeant:
  • 367 Answers
First off you must be from the U.P. :)
It sounds like you have a hard drive issue. You can try reinstalling the operating system by booting off the windows cd. I would recommend running a full check disk before installing windows though. If the harddrive has bad sectors your going to run into the same problem later on.
Posted on Jan 08, 2009
  • Dell Master
  • 4,806 Answers
Hi there
On start-up hit F2 and go into the bios, if your hard drive is there, exit the bios and you will need to recover the the system. The blue screen that you get is known as the "blue screen of death" in the PC repair trade. "unmountable boot volume" means that Vital boot string is corrupt and windows will not start.
If you have a recovery disk then you will have to use that to recover the operating system. If its a hard drive failure you will need to purchase another one and use the recovery disk again
Good luck
  • Lee Hodgson
    Lee Hodgson Jan 08, 2009
    Hi there
    Yes you can recover the data from the hard drive but it has to be connected to another computer as a "slave device". Once you have connected it just brows the contents of the drive and copy your data to the other PC.
    When you are satisfied that you have all of your data you can proceed with the system recovery when you put the hard drive back into the machine
    Good luck
    President:
  • 2,110 Answers
I think u have to re install operating system again...as u can't boot into safe mode ...
    Genius:
  • 3,422 Answers
HI,
The only solution to this problem is to reinstall your operting system from the recovery discs given to you.
  • Priya darshan Jan 08, 2009
    Yes you cna recover the data you have.Please use your recovery discs and follow the appropriate steps you get on the screen to recover your data.
Currently, this hardware device is not connected to the computer. (Code 45)
  1. Turn the computer off.
  2. Turn the computer back on.
  3. Immediately at the Dell logo screen, starting tapping the F12 key once a second until the One Time Boot menu appears (if the computer boots to Windows turn the computer off and try again).
  4. At the One Time Boot menu, press the arrow key to highlight Diagnostics and press enter
  5. Write down any Error Codes and Validation codes listed.
Jun 22, 2014 | Dell Inspiron Computers & Internet
Comp frozen.will not connect to windows 7..error while initializing the NIC
PXE ROM boot is a network boot that kicks in when all else fails. If you have or can borrow a Win7 boot disk, watch the screen closely when powering on the computer and it will tell you which key or keys to press to force a boot from the the cd/dvd rom. If you can boot from the optical drive , it may give you the option to repair Windows. READ THE SCREENS CAREFULLY AND CHOOSE WISELY - if you do not you can overwrite windows and ALL of your personal data. IF you have a hard disk failure, windows should tell you so...
Feb 06, 2014 | Computers & Internet
DELL OPTIPLEX WONT BOOT PAST WINDOWS LOGO
If the loading fails with an error message, try hitting F8 before the windows logo appears and from there Select "Safe Mode". If it works like that, one you're logged in Windows, perform a System Restore to an earlier point in time (when the computer worked).
Sep 24, 2013 | Dell Optiplex 755 Ultra Small Form Factor...
Keep getting checkpoint errors, and have changed Sys Battery , reset Bios and when i boot it ,it goes to Dell logo and keeps trying to reboot. Windows will not load.
Try going to the BIOS and see if it reboots from there. If it does, then it is most probably a hardware problem. You can try re-seating the memory modules and If you have multiple modules, try them one at a time.
If it does not reboot while you are in the BIOS, then the problem lies on Windows. Get your DELL Restore CD or your Operating System CD and insert it to the CD-ROM drive. Reboot the computer and press F12 while seeing the Dell logo, that should give you the options to boot to CD-ROM. It will give you a quick prompt of "press any key to boot to cd..". Make sure you press the space bar during this time to initiate the boot from CD-ROM.
Once the Windows Setup loads, Choose "Recovery Console" to repair your computer. Just choose the installation you would like to repair (normally it's number 1) then it will ask you for the administrator password. By default, the password is blank, but if you set a password for admin then use that password.
Once you get to the prompt, Type this command. "CHKDSK /R" (without the quotes). It will initiate the repair for your OS. This might take an hour or so. Just wait for it to finish and it will automatically reboot your computer. Let the computer computer reboot normally. You should be able to get to your normal windows screen back.
Good Luck.
Nov 10, 2010 | Dell Dimension 4600 PC Desktop
Starting problem
Immediately after seeing the Dell logo, keep tapping the 'F8' key,
until you see a "menu" (white text over a black background)
giving "startup" options for Windows XP.
Select "Safe Mode" and see if you can start in that mode.
Then, use "System Restore" to go "back" in time, to the most-recent checkpoint (date/time) where your computer _DID_ work.
Restore to that point, and restart.
Jul 17, 2010 | Dell Inspiron 1525 Notebook
Cannot read disk
"A disk read error occured press Ctrl+Alt+del to restart " FOLLOW THE BELOW INSTRUCTIONS TO RUN DELL DIAGNOSTIC ON INTERNAL HDD Open the Dell Diagnostics on either your hard drive (F12) or from the Resource (Drivers and Utilities) CD. Running from the hard drive is the preferred method of using the diagnostics. If problems occur when running from the hard drive or there is no Utility Partition, the diagnostics can be run from Resource (Drivers and Utility) CD. From your hard drive: Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. When the boot device list appears, highlight ?Boot to Utility Partition? on desktop systems or ?Diagnostics? on portable systems and press . Note: On portable systems, PSA will be executed first. When PSA completes, press any key to load the Dell Diagnostics.? Go to step 2. NOTE: If you receive a message stating that no Diagnostics utility partition has been found, follow the instructions on the screen to run the Dell Diagnostics from your Resource (Drivers and Utilities) CD. From the Drivers and Utilities CD ResourceCD: Insert the Drivers and Utilities CD into the CD drive. Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. NOTE: This feature changes the boot sequence for one time only. On the next start-up, the computer boots according to the devices specified in the system setup program. When the boot device list appears, highlight IDE CD-ROM and press . Select Boot from CD-ROM option from the CD boot menu. Select Run the 32 Bit Dell Diagnostics numbered list. If multiple versions are listed, select the version appropriate for your platform. Go to Step 2. After the Dell Diagnostics loads, the Main Menu appears. Click the button of the option you want. If a problem is encountered during a test, a message will display the error code and a description of the problem. Write down the error code and problem description and follow the instructions on the screen. If you can not resolve the error condition, contact Dell. If you run a test from the Custom Test or Symptom Tree option, click the tabs above the right window for more information: When the tests are completed, if you are running the Dell Diagnostics from the Drivers and Utilities CD, remove the Drivers and Utilities CD. Close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and restart the computer, close the Main Menu screen. Regards Sunil Dsouza
Dec 04, 2009 | Dell Dimension 2400 PC Desktop
Unmountable boot volume
hi,
-this can be a hardware problem or a software problem
-run diagnostics first on the computer
-turn off computer; while the computer is off, press and hold the "Fn" key then press power at the same time to initialize the test
-if you find error message like 0142 - this is a hard drive failure; contact your manufacturer for replacing your hard drive
-if no error is found, it is a corrupted Windows; you need to reinstall Windows, ensure you consult local technician to back-up files before installation.
cheers!
Oct 05, 2009 | Dell Inspiron 1525 Notebook
Problem with windows. It won't boot up
this only problem with windows or virus....
you can use recovery to solve this problem..nothing else...check and it will work fine
Jan 08, 2009 | Dell Inspiron 6000 Notebook
Booting problem
Try putting the computer into safe mode by holding down on the F8 button and selecting safe mode during the boot process. Once you get to the safe mode screen and windows appears, restart the computer.
If that doesn't fix the problem you will have to restore Windows.
Jun 12, 2008 | Dell Latitude C640 Notebook
Dell Inspiron 6000 Notebook Logo
Alun Cox
