Question about Sony Playstation 3 (PS3) Console
Ps3 wont register through hdmi to tv
PS3 powers up reads disks, or seems to, but when I look for it on my HDMI for the TV it won't show up anymore. I tried the component cables as well and they don't give a picture either. Am I missing something? Can it be reset? I mostly use this for my Bluray movies and not for games.
  • Martin1000 Jan 08, 2009
    When I plug HDMI from PS3 to Samsung Receiver then to Samsung LCD I get no picture and no sound. If I plug PS3 into TV everything works fine.
    Problem Solver:
  • 7 Answers
To reset the playstation, hold down the power button until it beeps twice and turn it off from the back. at that point, wait three to five seconds and then turn it back on from the back and then the front.
then you can can automatically or manually change the audio/ video settings.
i recommend that you do manual with the problems you seem to have. if you are using hdmi, start from the lowest setting on the visual and test each one to see what your resolution your tv has.
then setup your audio.
Posted on Jan 09, 2009
  • jdv011 Jan 09, 2009
    i forgot to mention that after the second beep, make sure that it shuts down and you see the red light before you shut it off from the back.
    oh yeah... i forgot something else...
    make sure your hdtv has hdmi 3.0 (i think that's the correct version number). if it is not 3.0 then your ps3 will not disply at all on your hdtv.
My lg flatron n2294a - PM displays an "out of range" message and won't wirk with my ps3 when using the hdmi or AV option. Whats wrong?
Your resolution on your ps3 may be too high for the tv to display. Hook up your PS3 to you TV with the HDMI cable. Now, when you turn on your PS3, hold the power button on the PS3 for 5 seconds. It will reset the PS3 video options and recognize the HDMI connection. It will then search for the correct resolution settings on the TV. Press (X) to confirm. And that's it. You should be set. If not, then the TV is acting rather strange.
Apr 01, 2013 | Computers & Internet
My ps3 wont show on my tv anymore. what do i do?
not to worry it is very simple
1. if u are using hdmi port and it is connected to hdmi in your tv
setting might have been changed
1. take out ur nomal av output wire which is given by sony , plug it on to a normal tv (rgb) now u can see the display (if not try mannual swithch off the ps3 and on for 3 to 4 times) u will get the display
2. now go to settings (video settings) there is a option called video output u can change it to AUTOMATIC
3.NOW COME OUT of it and switch off
4. now pug into ur hdmi port it will work
Mar 15, 2010 | Sony Playstation 3 (PS3) Console
I connected my sons ps3 to our new hd tv and now it wont connect to his tv as it only seems to be using the hdmi output which his tv does not support
Turn the PS3 off and make sure it is just showing a red light,
Then, with the PS3 connected to the TV with the regular (not HDMI) connections, press and hold the power button.
As soon as you see the screen flicker, release the power button.
That should do it!
Jan 27, 2010 | Sony Playstation 3 (PS3) Console
My ps3 screen is blue and it says no signal also the power switch wont turn on but the eject disk button still works the tv is a hdmi 22" technika
Pull the HDMI out of the PS# while it is on and then back in. Also make sure the HDMI going into the tv is tight.
Jan 13, 2010 | Sony Playstation 3 (PS3) Console
How would i know if my HDMI ports are working or not?? Tried to connect a PS3 to it but nothing. Thought it may have been the cable so checked someones that i know is working and still nothing. Checked...
As you already checked PS3 and HDMI cable,
select HDMI input in TV and connect PS3 via HDMI cable. TV should show PS3 picture.
And if still no joy then HDMI input port in TV is bad and need to replace input board/ main board.
Jul 08, 2009 | LG M227WD-PZ LCD TV
Ps3 plays audio but does not show image on tv
Well you can just use the hdmi cable if you're going both audio and video in to your tv. With your hdmi cable you get the best quality for both.
But in anycase, it seems that your PS3 is set up to output video via HDMI cable. To reset our video output settings, simply power down your PS3 (turned off) and hold down the power button until you hear the second beep. (around 5-10 secs) Power back up and hopefully you'll have video via your av cable. Hope this helps.
Apr 22, 2009 | Sony Playstation 3 (PS3) Console
HDMI Input only reads Digital TV and not PS3 or AV Receiver
Well, I won't take the credit of others. Many people have the same problem as you do.
In the search box on the top of this page, put in " PS3 HDMI ". The one that has the 10 solutions so far has the best answers for you.
Good Luck
Feb 16, 2009 | Philips 52 In. LCD HDTV
Cant get hdmi for ps3 to work on my jvc hd 52g887
Had same problem with Panasonic PT60LC14 tv when connecting by HDMI cord to my PS3 and a blue ray disc was playing. First, read your tv manual to see what video inputs it supports . Then read the PS3 online manual (section on "video output settings").
For me I found out that my tv only supported 1080i (along with 480i/p, 780p) and the ps3 manual says blue ray outputs 1080p, so my blue ray discs will not play on my tv according to the PS3 manual. PS3 manual says to restart the ps3 (power off, then power on and HOLD for 5 seconds) - then the standard video output settings should be reset. Hopefully the ps3 menu will pop up at least. I haven't tried this yet but if it doesn't work, i'll may try to reset PS3 video out settings manually first using another tv that works with it ..
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
127 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
