Question about Frigidaire Affinity ATF7000E Front Load Washer
Mold issue on front gasket
Good Morning -
Could you please advise how to clean the black mold that has formed on my machine's gray rubber gasket just inside the door? I understand this is a common problem.
Thanks for your help!
Scrub with with spray bleach cleaner and a scorse spoonge. It will start to go away...Then wash a load with heavy bleach and soap and it should go away...Even my deep mold stains went away....The gasket is thick you can scrub it pretty hard....However, if it is still there use a copper pan scrubbing pad with bleach and the mold will diff go away....
My Maytag Neptune looked bad and after I did that it looked new again...
Posted on Feb 15, 2009
  • 333 Answers
A solution of bleach and water will do. Just wet the rag and rub it down well. When this is done you may still have the marks but the mold is dead. If you want it to be completely clean you may need to replace.it.
Posted on Jan 08, 2009
We have mold along the inner rim of the rubber gasket between the opening and the door. How can we get rid of/prevent?
Robert, You can buy or make up your own mold Rid/ cleaner, which you will spray on bad areas and wipe off. Tip if possible leave washer door open so trapped moisture can air dry.
Check the attached links, for mold Rid/cleaners.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Concrobium Mold Control 946 mL The Home Depot Canada
http://blackmold.awardspace.com/kill-remove-mold.html
Amazon com CLR PB CMM 6 Mold and Mildew Stain Remover 32 oz Spray Bottle...
Mar 10, 2016 | Bosch Vision 500 Series Front-Load Washing...
We have mold all around the rubber gasket in the opening. How can we get rid of & prevent?
Use a 50/50 mixture of bleach and water. Use gloves and goggles to protect your skin and eyes. This will kill the mold. Try wiping down the rubber gasket after every wash to prevent mold from forming again.
How to clean the mold of the rubber
If you have mold on the rubber gasket of your Duet front loader, I can almost assure you that you have lots of mold in other places in the machine. Front loading washing machine are almost hermetically sealed and if the door is left closed, the inside just never dries out. This is just a perfect environment for the growth of mold and other fungi. Once mold gets established in materials such as rubber gaskets, it can be very difficult if not impossible to eradicate because mold grows "roots" deep into the pores of the material, making it very difficult to remove. Eradicating the mold may result in damage to the gasket since my "cure" is to paint on full strength bleach on the moldy surfaces with a brush or sponge (wear gloves). Repeat if necessary. You may wind up having to replace the front door gasket to get all of it. It will probably take more than one application to fully eradicate the mold from the VISIBLE surfaces of the rubber gasket. If you remove the detergent dispenser and peer inside the opening, you may see a lot more mold inside the cavity. If you see mold inside the detergent dispenser cavity, imagine what the rest of the inside of your machine must look like. Do you run a periodic cleaning cycle as advised in the operating manual? Have you read the operating manual? Do you use the absolute minimum amount of HE (non foaming) detergent? Factory instructions for cleaning the door gasket call for mixing 3/4 cup of bleach into 1 gallon of warm water and applying this mixture to the affected gasket area, let stand 5 minutes and wipe the area down with a dry cloth. My experience has shown that this is a grossly inadequate concentration to deal with a deeply seated mold problem in the door gasket. To run the cleaning cycle, the factory calls for 2/3 cup of bleach to be added to the bleach dispenser. "Use of more than 2/3 cup of bleach will cause product damage OVER TIME". Initially, I would definitely consider using a whole lot more bleach than recommended and run two or more consecutive cleaning cycles. Then EVERY USE OF THE MACHINE: wipe the door gasket and all the creases and folds dry with a sponge, remove the detergent dispenser and wipe the cavity dry, leave the drawer out to dry on a clean towel, leave the door open, buy a cheapy plastic box fan and place it inside the machine and let it blow air around the inside of the machine for an hour or so to dry it off quickly, run a cleaning cycle at least once a month. If this sounds too involved or difficult, I would suggest switching to a top loading washer that is much less prone to develop mold growth as air can circulate in these types of machines to a much greater extent than the front loaders.
Sep 12, 2014 | Whirlpool duet Washing Machines
Black scum forming forming on rubber seal on inside of washing machine door
  • 1 Put on rubber gloves and safety glasses before commencing the cleaning process.
  • 2 Lay an old towel or drop cloth on the floor under the front of the washer to prevent floor damage as you clean.
  • 3 Fill a plastic cup with bleach and dip a tooth brush into the bleach.
  • 4 Remove the toothbrush and scrub the washing machine gasket with it to remove the black mold from it. Hold the gasket open with the fingers of your other hand so that you can clean the center grooves of the gasket where the most mold is likely to grow.
  • 5 Rinse the toothbrush in the cup of bleach and continue cleaning until you have removed the mold from the entire gasket.
  • 6 Wipe the gasket with a paper towel to remove excess bleach residue and any remaining mold.
  • Jul 02, 2011 | Zanussi Washing Machines
    I have front loader washing machine and the rubber has got mould and having difficulty in removing the black mould
  • Saturate an old cloth with white vinegar. Alternatively, you might use petroleum jelly on the cloth to remove the mold.Pull the gasket out gently with your hands to reveal the mold and mildew buildup inside the folds of the gasket.Wipe the mold away from the gasket with the cloth. Continue working to wipe away all mold from the folds of the rubber gasket.Dry the folds of the gasket with a dry cloth when you finish removing the mold.Repeat this procedure at least once per month to prevent mold and mildew from forming. If you notice mold occurring more frequently, clean it off when you see it.
  • Tips for Preventing Mold & Smelly Problems:
    • Always leave the door and dispenser unit slightly ajar after the laundry is done. Front-load washers and the detergent/softener dispenser drawer must dry out.
    • Never leave a wet washload in the washer overnight; remove it when the washing cycle is complete and leave the door open.
    • After a load is done, always rotate the drum with your hand to see and remove all items. Some could be sticking to top or sides of the washer drum.
    • Use softener sheets in the dryer instead of liquid softeners in the washer.
    • Liquid detergents may leave less residue than powdered formulas which may not dissolve properly.
    • Use less than the recommended detergent level for your load. Too much detergent can cause a residue build up. Experiment until you find a minimum measurement that delivers a clean wash. This is also a money saver.
    • Occasionally wash some loads such as whites, linen and towels in warm or hot water to help flush out wash residue.
    • Always clean your washer as per your product manual. High efficiency front-load models have a cleaning cycle and it's imperative that you periodically run this cycle as directed.
    • Check the gasket just inside the door opening and remove any visible debris. You can also wipe it to speed the drying process.
    • Always use HE detergents with high efficiency front-load washers. Specially marked HE laundry detergent is low sudsing and is recommended for these low-water washers.
    • If this advice was helpful a vote with the thumbs up would be appreciated. Thanks.
    Apr 08, 2011 | Ariston Technologies Ariston AWD12 Front...
    RUBBER LINER COLLECTING MOLD
    I have been struggling with the same issue for a long time. Regular bleach and mold-killing products did not work. But I just tried Clorox "Washing Machine Cleaner" and was amazed. I scraped off the loose mold from the rubber gasket and then painted on the product, which is thicker than bleach. After about 20 min. I scrubbed it down with water and painted a second coat on the tough areas. No more mold. I also ran some through the machine per the instructions for good measure and ran another rinse cycle. I am in no way connected to Clorox, but I am so happy to be rid of this problem. Good luck. <!-- from fixya rte -->
    Jul 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
    Mold on and behind the rubber gasket in the front opening of the machine! I need to know how to remove and prevent.
    A combination of bleach, a rag or toothbrush, and your time will remove the mold. Be sure to run a load of whites on the next load. Bleach, you know.
    Leaving the door open between loads should prevent this problem from repeating itself. The machine will have a chance to air dry. Only front loaders seem to get this. The top load machines are not sealed water tight, of course. Good luck
    Jan 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Black mold growing on gray rubber boot inside door.
    Leave washer door slightly ajar after use to air out any moisture. Should prevent any future mold.
    Apr 10, 2009 | Frigidaire Affinity ATF7000E Front Load...
    Black mold
    YES GETTING RID IF THE MOLD WILL HELP YOUR PROBLEMS BUT YOU WILL HAVE TO GET RID OF ALL THE MOLD AND ALSO CONSULT YOUR DOCTOR FOR A CHECK UP SOME MOLD SPORES CAN CAUSE SERIOUS DAMAGE
    Jan 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Black mold growing on rubber gasket and under rubber gasket in Whirlpool Duet front loading Washer
    The solution? Plain old bleach.
    Scrub rubber seal on door. Run the bleach through the machine once a month to keep clean.
    Keep door open after each wash to ensure that it dries out properly.
    d
    Oct 12, 2008 | Whirlpool Washing Machines
    Frigidaire Affinity ATF7000E Front Load Washer Logo
    599 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
