GMPN goodman furnace: Water leaks from the base.
Water leaks from the base of the my GMPN furnace and none to little water flows through drain pipes.I check the drain pipes extend out of the furnace for any clogging . Pipes are clear.
Please help me out.
Thanks
  • 61 Answers
Check the drain tubes inside the furnace. There may be a loose connection or a split tube.
The unit could also leak from the gasket between the secondary heat exchanger and the vent fan housing. The secondary heat exchanger ould also be leaking or cracked.
Hope this helps.
Matt
Posted on Jan 08, 2009
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Hey, thanks for the post about water leaks from your furnace. My sister had a problem and I haven't heard if she got the problem fixed. I think that hiring a professional might be the best option for her, but I'm not sure if it is a simple problem or not. http://www.dependableaircond.com
Posted on Jan 24, 2017
Water was leaking from the base of my HVAC furnace, and not from the drain hose as it had on other occassions. I blew out the drain hose, changed filters, etc etc. Finally paid a guy $100 to come out. In 30 seconds he fixed it. So I asked questions on HVAC maintenance for another 20 minutes just to get my money's worth in education.
The fitting between the furnace and the drain hose unscrews. Whereas I had pulled the hose off of the 90 degree angled, corregated fitting that looked to be permanently attached with a cement or putty, he easily unscrewed the whole fitting. The clog was in the 90 degree angle part. Detaching and cleaning the hose and fitting are now part of my Spring self-maintenance.
An honest HVAC service would have recommended that over the phone before scheduling the repair guy. It cost me $100, it cost the company a 4 year client. Found a better HVAC guy who works independently.
Posted on Feb 17, 2011
  • Knotied2tigh Apr 21, 2011
    So the HVAC services phone person is expected to troubleshoot your furnace on the phone?
Furnace has water under it, why? Its a Dayton gas furnace.
There are several questions that need to be answered about what type of system you have, but i found this posting that may help:
As your gas furnace runs, is there water leaking at the base? Is the furnace's air filter wet, too?There are a few things that could be happening here. But if you have a high-efficiency furnace, here's the most common cause: a condensation leak.
We'll explain why a furnace creates condensation, and what's causing it to leak out of your furnace.
Note: You'll know if you have a high-efficiency furnace if:
  • The yellow energy guide tag says your furnace's efficiency is 90% or higher AFUE.
  • The vent/flue pipe is white PVC as opposed to metal.
Why a high-efficiency furnace creates condensation
How in the heck does a high efficiency furnace create condensation/water anyway?
It's all about how the furnace extracts heat from combustion gases.
A lower-efficiency furnace extracts some heat from combustion gases and then quickly vents them out the flue pipe.
But a high-efficiency furnace, to extract more heat, has 2 heat exchangers. These allow the furnace to extract heat from the gases for a longer period of time. This causes the combustion gases to cool and then condense.
That condensation then exits out your home through a drain. But if that water is pooling around the furnace, there's a problem preventing it from draining properly.
Causes of a condensation leak around a high-efficiency furnace
  • Clogged condensation tubing
  • Clogged condensation drain
  • Breaks in the condensation line
  • Issues with the condensate pump (if you have one)
You'll need a furnace technician to diagnose which of these is the issue and then fix it.
Other causes of leaking water around a furnace
If you have a conventional, standard-efficiency furnace...then its flue pipe may be incorrectly sized.
If you have a whole-house humidifier connected to the furnace...there may be an issue which is causing the humidifier to leak into your furnace. Your humidifier should be getting annual maintenance from a professional to prevent this.
Dec 13, 2016 | Dayton Heating & Cooling
Ruud achiever 90 plus furnace-water leaks from the drain pipe
This furnace should condense, as long as it goes into the drain. If it is leaking inside the furnace, there may be a seal that needs replacing in either the pvc drain pipe or concentric drain trap needs resealed.
Feb 21, 2015 | Ruud Heating & Cooling
Water leaking / running from top of humidifier
humidifiers have a drain and if there is water going in it will be coming out the drain. check drain to see if it is clear, check hoses going into top of humidifier for cracks, check filter in humidifier.
Feb 05, 2014 | AutoFlo 250 Humidifier
Goodman ac/heater drain pan leaking since instillation 3 years
sounds like the unit needs to be elevated and leveled.
Aug 10, 2012 | Goodman Heating & Cooling
I have a 5-year old Goodman furnace/AC. It has a drain trap on the side which looks like a cup with 2 hoses coming into it from and a drainage pipe coming out into the sump pump. Recently I noticed a...
Hello, it sounds like your condensate line is clogged and not be able to drain into the condensate pump or your condensate pan is cracked and leaking. Best thing to do is clean the condensate line with a shop vac and see if the water will start to drain, if not looks like the pan is cracked.
Jul 13, 2011 | Goodman GMS90703BXA Heater
Where is the main overflow pipe on my goodman furnace ac model number A24/10
follow the white pvc drain pipe to it .the over flow is next to the drain pipe.. this should have a cap over it .if your furnance is leaking water the drain is clogg.. use a shop vac to unclogg the drain pipe where it drains at the floor drain
Aug 22, 2010 | Heating & Cooling
Condensation building up in lower compartment of goodman 45btuh furnace in counterflow position 95%a.f.u.
Make sure all drains and hoses are connected to the lowest positions and that they are free of any blockage or debris. If there is not a vent or stand pipe on the drain line as it exits the furnace cabinet, put one in. A stand pipe is a Tee with a vertical pipe going up approximately 5" and allows the water to drain easily by breaking the vacuum normally experienced by the inducer blower.
Feb 03, 2010 | Goodman Heating & Cooling
Water leaking out bottom of Goodman propanefurnace drain tubes are clear. draining out under the actual furnace
Check the top of the gas flue. Make sure the cap is on it. If not it will allow rain to get inside. If this is only a furnace, this is the only thing it could be. Nothing produces water in a furnace. If it has an A/C coil attached. The condensation drain might be stopped up allowing it to leak.
Oct 13, 2009 | Goodman GMS90703BXA Heater
Goodman furnace leaking water
Yes you can use regular pvc glue. You should use pvc primer before you glue it.
Jan 21, 2009 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
1,471 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
