Question about Hifonics Car Audio & Video
CLIPPING ON ONE CHANNEL HIFONIC FALCON
WHAT TO DO...CHANGE PARTS?
WHAT TO CHANGE AND WHICH PART TO LOOK FOR
  • Scott Frye
    Scott Frye May 11, 2010
    Hi...
    Are there level controls on the amp box?
    Little knobs or screwdriver adjust spots
    Does the clipping produce crappy sound in the speaker?
    Scholar:
  • 125 Answers
Clipping can result from improper wiring or solder jumps to figure this out youll need a continuity tester simply check you inputs and outputs and make sure wiring is correct then if so your amp has a solder jump inside them amp. New amp or send it in for repair you can buy a new amp nearly every brand at dealer cost from this site.
www.godspeedaudioheaven.com
Posted on Feb 04, 2009
Why channel A clipping on soundcraftsmen ma5002a what's wrong
When you have a DC voltage on the output, check your capacitors in the amp. Looks like the big electrolytic is defect.
I don't have a manual of this amp, so I can't verify if I'm right and what cap you should look for.
Nov 21, 2014 | Audio Players & Recorders
How do i enter code for ford falcon xt ba??radio code as it doesnot display dashes for code.
usually use the channel numbers 1-4 and then press channel nunber5,
Nov 18, 2014 | 2005 Ford Falcon
Wats the best way to hook up 3 hifonic hfx12d 12s. Dvc 4ohmd to a 2 channel 2600 watt planet audio. Amp is 2 ohm stable.
Wire each sub 8 ohms(sieries) than connect them in parallel, bridged @ amp, final impedence will be 2.6 ohms.
Jan 30, 2014 | Hifonics Car Audio & Video
The FX portion of the board is clipping with no input signal present, there is no sound output at all. Also, none of the mute/pfl LEDs light up on channels 1-12.
There are several clipping indicators on this board. Do you mean that the small vertical display to the left of the FX selection window is maxed out from top to bottom? I will assume that you have ALL the FX inout knobs CCW for all channels AND the FX slider all the way down. Also does the FX selection knob work to change the effect number? Does the rest of the board work? WILL the effects pass sound when you send it through the effects? You say no sound, but was that just to say with no sound sent to it it still is clipping, or that it will not pass sound?
Oct 18, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Crown CE1000 and CE2000 both clipping with low signals
for some reason channel one of one of our amps started clipping. i first noticed it with the drum kit but it slowly moved to the vocals as well. i haven't noticed this issue before today. what do i need to adjust to keep it from clipping?
Jun 04, 2010 | Crown CE2000 2-Channel Amplifier
How to conect a hifonic amp class d to four
+ too - & - too + & + too - & - too +& + too -
Apr 01, 2010 | Hifonics BXi1608D Car Amp
Why cant I change gears on my bike?
Have you tried the use WD40 or GT85 Lubes on the seized parts? This is usually enough to free this sort of problem.
Mar 06, 2010 | Falcon Cycling
Power Acoustik LT 980-2 clipping while bridged pushing 1ohm load
Hello, your problem is that your amp is rated at 4 ohms bridged mono ans 2 ohms stereo. If your running it in stereo you need to raise the ohms to 2 ohms a channel and if your running it bridged into 1 channel you need to be running it at 4 ohms. Please rate this solution please so I can prgress on FixYa.com. Thanks!
Dec 18, 2009 | Car Audio & Video
No output on channel B OF PEAVY2000AND1200
You missed something. Use the good channel (A) to compare resistance and or voltage readings against the defective channel. Obviously you've removed the dead short issues (AC fuse is holding) BUT your signal path is still askew. Any transistors/diodes under suspect should be removed from the circuit for proper testing....Glen
Apr 14, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Gem Sound clipping problem
First of all the EXA-3940 is rated at 350watts per channel in to 8 ohms. The 1400 watts is bridged into a 4 ohm load. Second, the speakers can handle 1000Wats peak with an average of 600 continuous (i'm guessing). That tells me that the amp is underpowered for the speakers. The sensitivity of the amp is such that the mixer is overdriving the input stage. That is what is causing the clipping. If you are looking for more volume, you are probably better off purchasing another amp and running them in bridge mode, 1 per speaker cab. Be careful though, not to overdrive the speaker cabinets either.
Dan
Sep 21, 2008 | Gem Sound GemSound PA-585 2-Channel...
Car Audio & Video Logo
125 people viewed this question
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
