Question about Dometic NDR 1292 Refrigerator
Consul refrigerator has spark & gas but won't light
I have a small (about 8 cu ft) consul refrigerator which works just fine once going, but has to be manually lit with a match. The ignitor works and the gas is there (because it lights with a match). It will light about once out of 100 tries.
Any thoughts?
Thanks.
  • biff_simpson Jan 29, 2009
    The spark gap is right, but I'll have the gas company check the pressure when they come by to do a delivery and fix another issue. Thanks for your response. I appreciate it.
    Problem Solver:
  • 5 Answers
Test the Lp pressure to see that it is 11 1/2 water column inches. If it is then make sure that the electrode has about 1/4 inch to 3/8 inch gap and that it is sparking good. You can physically watch this. Once you have both in proper working order this should light for you and work. I hope this helps.
Posted on Jan 29, 2009
What size is the glass shelf in a consul 8 cu ft propane fridge
measure the space with a tape measure or order by model number :-)
Aug 18, 2014 | Refrigerators
Petrol problem car wont start ford consul
no spark from coil on a ford 71 consul
Jul 24, 2013 | Cars & Trucks
Heater is a Dayton 3E-133E used very little. weak spark won't ignite gas
yes they do go bad some times they have a hairline crack in them and the will spark but never light the gas they have drove me nuts many a time , for no reason they will not light , then replaced it and wham it works .
Mar 01, 2017 | Dayton Heating & Cooling
Still have turn signal problem wont cancel automaticly,no has been able to solve it yet.?
Has the original flasher relay from inside the meter consul been replaced with one external from the consul, if so the self canceling would not work as the ecu within the consul would not be connected
Jul 26, 2011 | 1999 Honda GL 1500 SE Gold Wing
NEED MANUAL FOR CONSUL GAS REFRIGERATOR CQE 22B OR D
Here is the manual I think you are looking for:
https://www.lehmans.com/product/service-manual-for-pre-1960-servel-gas-refrigerators/
Or, go to http://www.lehmans.com and use the search box to look for "Servel".
Jan 19, 2011 | Refrigerators
Camper fridge does not work on gas.
right where the gas comes out there is an elect igniter do you see or here it clicking some times carbon buildup causes it to ground out inproperly sometimes the bracket gets rusty the bracket needs to be able to fire a spark directly twards the jet good luck
Apr 12, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Electric start gas range
All burners apark at the same time. If they don't light then electrodes (where the spark jumps off of) are either worn out or cracked or there is dirt in the area of the sparking. Clean thoroughly to diagnose this correctly.
Nov 27, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water leaking out of pump
Unplug the washer. The consul is hinged from the top. Remove the two screws at the base of the consul ( at the front or the back) and pull the consul toward you then flip the consul back. You will find two gold colored spring clips under the consul. Use a screwdriver in the front slots, pop the clips out. Unplug the connector to the lid switch, tilt the cabinet forward and set it to the side.
Remove the two hoses to the pump and the two spring clips that hold the pump on. Your half way there. replace the pump and reassemble the machine. make sure you line up the cabinet. Cost should be about $50.
Jan 06, 2008 | Kenmore 27032
Dometic NDR 1292 Refrigerator Logo
691 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
