Question about Watches
Time line on map not corresponding with plus/minus hours box.
The World map on the watchface has a time line on it. In the ''world time'' mode, for example, the map shows the time line through New Zealand, with the three letter code ''WLG'' for Wellington, which is correct. But in the ''Home Time'' box it displays +9, instead of the correct +12 (ignore daylight saving).
I don't know. I gave it to a 15 year old, and it was sorted in 10 minutes! Thanks.
Posted on Jan 09, 2009
I need to change the time on my nike wk0006 watch, but nike doesn,t sell it anymore...WHAT DO I DO!!!!????
TRY!
Make sure the watch is facing the correct way. Put the watch on your wrist as you normally would, or pick it up by the strap with your left hand. You should see that the Nike swoosh is right side up. You should be able to read the time.
Find the left side of the watch. This will be your left when the watch is facing you correctly the same way that you would look at it to read the time. You will see at least two buttons. One will be labeled "mode" and the other will be labeled "set."
Press the "mode" button. Press the "mode" button. Continue to press the "mode" button until you have scrolled through the options and are on the correct setting. The correct setting should be "time."
Hold down the "set" button. You should see the currently set time on your watch and the hour should be flashing. You should see a plus sign (+) and a minus sign (-). If your current time says three (for example) and you want to read five, press the button that corresponds with the plus sign. If you want to go backwards, press the button that corresponds to the minus sign. When you are finished hit next.
Change the minutes. Now the minutes should be flashing. Repeat step four: press the button that corresponds with the plus sign to increase the minutes. Press the button that corresponds to the minus sign to decrease the minutes. Hit "next" when you are finished.
Hit "done." Congratulations, you have now successfully set the time on your Nike watch. Now your watch should read the correct time. If you want to get really crazy, you can repeat the steps above to change the date on your Nike watch.
Sep 28, 2014 | Nike Triax WK0006-001 Watch
How to display city code
To display city codes you must first hit the "C" button to switch into World Time mode.
While in World Time Mode press D to scroll through the city codes.
Hope this helps!
Apr 07, 2011 | Casio AW80-7AV Wrist Watch
How do I change 24 hour time to 12 hour
You have to press the ADJUST button then you hold down the MODE button and while you are holding down the MODE button press the G (illuminator button)
Jan 27, 2011 | Casio G-Shock Classic DW6900-1V Wrist...
Cant reset my watch, currently in perth which is 3 hours behind sydney, woul like to have at least the analogue side set to perth time
If you read the instructions you should be able to set your watch so that it reads tha correct time for Perth (on my watch this is achieved by pressing the mode button to enter "world time" - three letters indicating the reference city- and then press the button at 4 oclock to scroll through the alternatives; the setting should be BKK for your time zone)
If you haven't got instructions on how, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Oct 05, 2010 | Casio EFA119BK1AV Watch
How do i set my casio databank to beep every hour
Hello I was in the same problem the last 5 hours causea icant find my owner manual, i put a new battery on my "oldie" but great watch and pusshin and seting i got it....
You have to put in "alarm mode", remember you have to push BOTON MODE. Then you will be at "stand by mode", "data bank(phone) mode", "world time mode", "alarm mode" "chrono mode", and set (analog watch) mode"
then you are in "alarm mode" then push "REV and FWD BOTONS" at the same time, one time, or two times or three times, until the "beep icon and bell icon" are in ON mode
Good look
sareg@hot....
Sep 25, 2010 | Casio Watches
Need manual for g-force watch global atomic
Hi, Since you didn't specify the model or module number of the watch, try this link:
http://world.casio.com/wat/download/en/manual/
Take the four-digit module number from the back of the watch, enter it, and download a PDF of your watch setting-instructions.
I hope this helps you. Thanks, Bill
Sep 07, 2010 | Watches
Settiongs for Weather Data World Clock
Citizen Weather Data Clock Settings.
To set time press and hold for 5sec "set" button
Use advance to add days, years, hours seconds.
Press SET to hold.
Oct 17, 2009 | Citizen Watches
Lost instructions for Lexon world time clock model Planete
to set the alarm, press and release the "alarm" button; then press and hold the "set" button until the hour begins to blink. press "adv" until
the hour AM or PM is correct;now press and release "mode" so that the minutes begin to blink. Set the minutes using "adv"; now press and release "set". Finally,
press and release "adv" once to bring up (or remove) the alarm icon. Then press"alarm" once to return to the main display.
To set main display, press and hold "set" until the hour begins to
blink; press "adv" repeatedly until hour AM or PM is correct. Now
press "mode" so that the minutes blink, and use "adv" to get the
minutes right; then press "mode" so that the next item begins to
blink; use "adv" to advance until it is correct, then press "mode"
so that the next item blinks, and so forth until you're all done.
Finally, press and release "set".
Aug 10, 2009 | Watches
Adjusting the world time??
If your watch is Casio:
If not, give ALL the details.
Rate, please.
Mar 30, 2009 | Casio G-Shock 800D 7V watch
Setting time on casio illuminator watch
Here is how you do it:
Looking at your watch face: the upper left button is A, upper right is B, lower left is C and lower right is D.
Get your watch into "Hand Setting mode" That is the mode witht he digital time and seconds above it.
From Day and Date window it would mean pushing button "C" six times to get to that mode.
Once in "Hand Setting Mode"
Hold down button "A" til time blinks, then press button "D" to advance the hands, to the desired time.
Press "A" to exit mode.
Press "C" to return to timekeeping mode.
Dec 03, 2007 | Casio G-Shock GW300CA-1V Wrist Watch
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
